Oil Brand/Oil Change question
I have a few quick questions and concerns, sorry if they are obvious but I would rather be safe than sorry. I purchased my FRS a few months ago and was able to get a killer deal due to it being on the lot for a vast amount of time. (175+ days) I was looking at some of the other threads to decide on what oil I was going to run. For reference I will not let any Toyota dealerships work on my car unless its a recall due to experiences with my Tacoma. I got to thinking about when I should change it due to it sitting for a long period of time on the lot. I have now had it for under 3 months and the odo is at 2600 miles. Do I need to change the oil now? Will it hurt to wait? I know changing the oil wont be bad, but should I worry about how broken down it is from sitting for so long and then putting that many miles on it. Sorry if I sound stupid, I was just super curious because when most shops change oil its xxx miles or xxxx date til next change. My other question revolves arout what brand will be safe to use for Indiana Weather. I am originally from NW IN but am currently living in southern Indiana. I have seen nothing but good reviews on the eneos sustina 0w20 and that was what I was probably going to go with, but just wanted to make sure it wasn't going to be to thin for where i drive at. I read somewhere that eneos was the thinnest of the 0w20 where as redline was one of the heaviest if that makes any sense. Sorry for story!
If you are worried, go ahead and change it just for the peace of mind.
As to what brand of oil, any good 0W20 will be fine. |
Dont change the oil. Too early at 2600. Wouldnt hurt to but waste of $$. Eneos sustina 0w20 is very good if not the best. I planned on running the 5w30 but costs $100 for 5qts here. Motul costs me about $50. Im supercharged hence why i run w30
Alright thanks for the responses. My main concern was the oil not lasting as long due to it sitting on the lot for so long cycling between hot and cold weather as well as a few short test drives. I will hold off until around 5k miles
Welcome to ...... The Forum, @Ginger Academy ........:clap:
Like @jvincent says.... it's not necessary, but change it if it makes you feel better. Yep, I agree, any 0w20 full synthetic oil, will do just fine, for average driving in Indiana. humfrz |
Anyone else got any thoughts on OCI for Eneos 0w-20? I drive so few miles that I've been changing after 8-10 months, but with the most recent change it's been in there for an entire year.
I did my first change at 7 months and ~3k miles and second six months after that at ~7k miles. Third was done last November with ~9k. I'm now at 13k and planning on changing it with Eneos Sustina 0w-20 on Thanksgiving coming up here in a few days. |
Like others said change it if you want. FYI what ever is in there is still good oil doesn't go bad in months. It takes a few years of abuse.
As far as brand goes. Go with synthetic anything. But. Here's the truth behind that rare special order brands like Enos, Motul, and Royal Purple. Say your just a bit out of town, a quart low and all the auto parts stores are closed? Your pretty much screwed cause you can't find it anywhere. Now if you go with Mobil 1, Castrol, Penzoil or any of those other brands guess what? They are everywhere. So just a little something to think about. |
Strange comment. Not sure why you'd ever be driving around "a bit out of town" and suddenly be an entire quart low. Ideally you'd be checking your oil while the engine is cold and the car is on a flat level surface every 3-4 weeks or so and topping of as necessary. (This is what I have to do, thanks soft under 4k break-in!)
Even if you were a quart low, it's not going to cause some sort of negative chemical reaction if you top off with a typical off the shelf brand of synthetic oil, as long as you ensure it's the same weight as what you're currently using. Quote:
Hell, I probably won't notice any difference and will just go back to the M-1. |
Say your out in vacation on a road trip 4-6 hour drive or a couple of days. Unless you pack a few quarts of your own oil, your kind of out of luck finding your special order oils. It kind of doesn't matter what kind of oil you put in when your low, but that's kind of pointless spending more money for special order oil when you dump some other brand when it's low. |
Oil does not go bad just sitting there but I'd probably change at 5000 |
| All times are GMT -4. The time now is 12:23 PM. |
User Alert System provided by
