Just flashed OFT Stage 2 UEL
I just flashed OFT UEL Stage 2, and I've been driving easy. I am full catless with Grimmspeed CAI. immediately after flashing, my FLKC dove to -5 degrees steadily over the next two minutes. My IAM is 0. KC learned spikes up to 3-4 degrees when I accelerate. I'm running 92 octane on a 91 tune. I haven't even broken 20% throttle.
Data logs to follow as soon as I get home, but I feel like this isn't normal. Can anyone chime in? |
That doesn't sound right, is your oft template up to date? (Download from oft website and update through openflash manager if you haven't yet).
I don't help people with no cats and i would urge others the same.
Pretty sure the template is up to date. I'm going to check shortly. I can't hear any knock, so there's that. I remember the knock sensors on my STi were shitty. Hmm.
This isn't a discussion about cats vs. decat.
I flipped back to the stock map probably 50 miles ago and drove pretty easy until this morning. Here's a long cruise from home, then a WOT run. Long Cruise WOT Run, 3rd Gear Regardless of if I'm running the OFT OTS maps or stock, it behaves the same. I've only seen actual Knock Correction jump that once in the first log. |
| All times are GMT -4. The time now is 10:44 AM. |
User Alert System provided by
