Software Tuning Discuss all software tuning topics. |
06-10-2024, 05:16 PM | #1 |
Smiling
Drives: BRZ 2018
File Selected not Compliant
Hi,
Ordered tune files from WayneRoms and picked K00G as it's the one showing on my OFT But after downloading the .bin file and trying to add it to OFT, I am getting an error The selected file is not compliant. Scrolled up a bit on OFM and saw that the CAL is showing as N01C Emailed WayneRoms via their Paypal email (Only contact info i can see on the site) and currently waiting for their response but hoping someone could help me out on this? Thank you!
06-11-2024, 12:08 PM | #2 |
Smiling
Drives: BRZ 2018
This is resolved. Got the new files from Wayne. Thank you
06-11-2024, 01:30 PM | #3 |
Drives: Toyota GT86
To explain why, all OFT roms (including Wayne's) are Cal id hacked.
OpenFlash only uses 4 tunes in total and those are: 2012-2016 ZA1JA01G (MT) and ZA1JA01I (AT) 2017-202x ZA1JK00G (MT) and ZA1JK00I (AT) Those are Eurotunes and used because those are the easiest to work with and most defined in the definitions. The tablet however marries itself to the VIN number and the Calid, that's why you will see (in this example) ZA1JN10C while up/downloading files but when reading the ECU itself it will show the real Calid (ZA1JK00G) So for anyone who is questioning which Calid he needs to flash tunes, just look at the up/download screen. Bonusinfo: This method will create problems when trying to edit the OpenFlash/Wayne tune yourself. You need modified definitions, In this example you will need definitions for ZA1JK00G, but modified to look like ZA1JN10C, Using 'real' ZA1JN10C definitions with the OFT tune will most likely brick your ECU when flashed.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
The Following User Says Thank You to elBarto For This Useful Post: | Muchikori (06-13-2024) |
06-11-2024, 01:31 PM | #4 |
Drives: Toyota GT86
Dubbelpost because the server was drunk
06-13-2024, 02:40 PM | #5 | |
Smiling
Drives: BRZ 2018
Thank you very much for this info and warning @elBarto! will use the Definitions that Wayne provides to make sure i dont brick my ECU
Similar Threads | ||||
New to OFT, "file not compliant" | Wingnutt | Software Tuning | 1 | 02-20-2022 02:13 PM |
oft "file not compliant" | Nah | Software Tuning | 14 | 03-22-2016 03:57 AM |
Selected gear indicator on dash for Manual transmissions. | Rumbaar | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 02-14-2016 08:56 PM |
OFT - The File Selected Is Not Compliant | Kody | Software Tuning | 8 | 08-18-2015 05:01 PM |
OFT - Mode file not found. Cannot create a tuning file. | focobrz | Software Tuning | 11 | 07-17-2015 09:22 PM |
