Pepe Le Pew Wannabe
High performance and race engine oil tests
This is the first test of a series. The future test will test for metal content. So stay tuned.
http://www.animegame.com/cars/Oil%20Tests.pdf
My middle age crisis started prematurely… at 16!
I'm also independently very, very..... dependent! |
#2 |
Because compromise ®
Drives: Red Herring
I am replying with very limited knowledge on the subject but I'm not sure if this test (film strength test) is the most important criteria in a motor oil.
I appreciate that marketing probably influences this statement but maybe there is some truth to it as well: "There are certain oils in the market today that use EP (extreme pressure) additives in their engine oil that are really designed for gear oils and not engine oils. Extreme pressure additives are typically not used in engine oils for a number of reasons but the most important is because they can cause engine corrosion over time. The rigs being used in these demonstrations are primarily designed for industrial applications like gear oils where extreme pressure is an important performance feature you need. These demonstration rigs have very little to do with modern engines and that is the reason that market leading oils in the industry perform poorly in these tests." https://www.mobiloil.com/USA-English..._Strength.aspx |
#3 |
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
I have used RP with very good results. Currently this is in my FRS 0/40wt
#4 |
Drives: Four wheels, two seats, etc
That artical was retracted in a subsequent issue of Street Commodores. The test they did was for grease not oil.
#5 | |
Site Moderator
Drives: Stuff
This. The Timken test is for grease and other EP fluids. There are many household fluids (shampoo, chlorine, etc) that would beat many engine oils in that test. That certainly doesn't mean it's an ideal engine oil substitute ![]() That test is 100% worthless as far as engine oil testing is concerned.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#6 |
Pepe Le Pew Wannabe
huh... well I guess I'll be using Vidal Sassoon in my engine the next time I head for the track!!!
I'd actually be interested in questioning how the oil "age" could be tested with respect to the protective addetives and internal metal wear. I'm familiar with oil analysis/degradation and results, but not much testing is out there comparing aged oil, as much as there are for good aged bottle of St Emilion wine!!! lol
#7 |
Drives: Red Herring
#8 | |
Street Commodores retraction.
http://www.streetcommodores.com.au/n..._aint_oils.php Quote:
#9 |
Pepe Le Pew Wannabe
I wonder if it still provides some info in relation to motorcycle oil where the transmission (gears) baths in engine oil.
#10 | |
Site Moderator
Drives: Stuff
RP just has EP additives in their oils, worthless for an engine, but it makes them look good when people do testing like that. Slick 50 and various other snake oils did the same testing on TV ads back in the day.
-Dave
#11 | |
Motor Sports slut
The Bearing's look great upon teardown and the piston where able to be reused. Say what you want but that stuff coats the engine. I've seen it with my own eyes. |
#12 | |
Site Moderator
Drives: Stuff
![]() The slick 50/snake oil bit had nothing to do with RP. The fact is engines do NOT need EP additives and the Timken test is for EP testing, making it invalid as an engine oil test.
-Dave
#13 | |
Motor Sports slut
#14 |
Site Moderator
Drives: Stuff
I used to run Amsoil. Lately I've been using Mobil 1 since it's easy to find. It's not my preferred choice but it works for now until I want to stock up on lots of good oil.. When I do a run to the Amsoil distribution center I usually grab ~$1k of oils and I just haven't felt like doing so lately.
-Dave
| all season high performance or winter performance tires? | Aloxi | NY / NJ / CT / PA | 29 | 03-24-2015 10:23 PM |
| New England (HPDE)High Performance Driver Ed Schedule | HAZMAT | New England | 24 | 03-26-2013 01:08 AM |
| High compression engine fuel requirements | Ben_G | Engine, Exhaust, Transmission | 3 | 01-16-2013 12:44 PM |
| $28K High-Performance Two-Door Comparison | Asterisked Accolade | Other Vehicles & General Automotive Discussions | 3 | 06-07-2012 01:20 PM |
