Old 02-17-2014, 04:37 PM   #1
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
What's this on my wheel?
I washed my car yesterday for the first time since installing my new wheels and I noticed these on all four.
What is it and can I remove them?
eSOLOR is offline   Reply With Quote
Old 02-17-2014, 04:39 PM   #2
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
Wheel weights. Don't touch them. That's what they put on when they mounted and balanced your tires.
ProTekk is offline   Reply With Quote
Old 02-17-2014, 04:39 PM   #3
Yruyur
Yruyur's Avatar
You can paint them black or ask for black ones so they stand out less
Sent from my SCH-I545 using Tapatalk 2
Old 02-17-2014, 04:40 PM   #4
kALMIGHTY
Drives: TRD Ultramarine '13
When I was plastidipping my wheels, I noticed these but in a few spots, I could tell some of them were missing because only the sticky residue was left behind. Do they really come off easily on their own?
Old 02-17-2014, 04:41 PM   #5
Redlinedfrs86
Redlinedfrs86's Avatar
Drives: 2013 Firestorm FR-S
Very important that you leave those on.....
Redlinedfrs86 is offline   Reply With Quote
Old 02-17-2014, 04:41 PM   #6
Scavanger
Avid searcher of things
Scavanger's Avatar
Drives: Scion Fr-s 10 series
Weights for the wheels, but that's an odd place to put them usually they are located on the lip of the rim
Scavanger is offline   Reply With Quote
Old 02-17-2014, 04:43 PM   #7
wparsons
wparsons's Avatar
Middle of the barrel is a very typical place for sick on weights, I've never seen them really close to the lip at all. Mine are further away from the spokes, but definitely not at the inside edge.
flickr
Old 02-17-2014, 04:53 PM   #8
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
I'm used to seeing the wheel weights right there as the OP's wheel has them, but on my previous car with black rims, I did what was already suggested, colored them black (with plastidip).
malave7567 is offline   Reply With Quote
Old 02-17-2014, 05:38 PM   #9
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Depending on the type of wheel, basic steel wheels will typically have a different type of weight mounted on the outside and inside lips, most aftermarket wheels will have these stick on weights on the inside and outside of the barrel like in OP's pick.
Flat Black VW is offline   Reply With Quote
Old 02-17-2014, 05:54 PM   #10
stugray
Drives: 2013 GBS BRZ Limited
[sarcasm]If you would like to shed a few pounds of unsprung weight, you can remove all of them[/sarcasm]
because it's all about every pound of weight right.....?
Old 02-17-2014, 06:04 PM   #11
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Thanks guys, it's my first time purchasing aftermarket wheels and I didn't know they actually stuck on weights to balance the wheel. I never see them on pictures either.
It's not about the weight. They just look ugly and out of place where they are located and would've liked to remove them if they were unnecessary.
Old 02-17-2014, 06:18 PM   #12
stugray
It's good I was kidding. My statement above is for those that think changing the pulley "for a couple of pounds" is a good idea,...
You can put duct tape over them to make them less visible and less likely to come off.
Since you can get duct tape in almost any color, just find the closest to the rim color
Old 02-17-2014, 06:23 PM   #13
frslee
Just drive it
Drives: 13' FR-S
you must be new to wheels!!
but anyways, you can ask the wheel balance place to relocate those weights.
frslee is offline   Reply With Quote
Old 02-17-2014, 06:26 PM   #14
FunCon5
FunCon5's Avatar
Wheels have to be balanced every time you get new tires. The residue is from the last set of wheel weights. They can come off on their own, but they usually do not.
FunCon5 is offline   Reply With Quote
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 03:23 PM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
NRG Rim/Wheel LIP PROTECTOR up to 22" Wheel - Various Colors - FREE SHIPPING!!! YURparts Wheels and Tires 3 12-16-2013 10:07 PM
OK wheel gurus, wheel are here, now for tires FRSGT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-12-2013 02:36 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
