Old 02-19-2014, 03:26 PM   #1
kuhlka
Drives: 2013 BRZ Limited AT
Best Offset/Width for autocross?
I'm seriously considering getting a set of OZ Ultraleggeras, but I'd like opinions from people with track time to see if there is a golden combo of width and offset that noticeably improves stability and handling.
The Ultraleggeras are pretty light and I was considering the 17x8s because I'm staying NA for a while. I'm mostly looking for gobs more front end grip for slalom and hard braking turn-in. Zero interest in 'stance' showboating, pure utility/performance here with bang-for-buck consideration.
Big thanks in advance for tips from the racing crowd.
kuhlka is offline   Reply With Quote
Old 02-19-2014, 04:14 PM   #2
jflogerzi
jflogerzi's Avatar
stock off-set so 45 or even 48 should be fine
Will this fit? (width, offset and tire size Qs) DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4468 04-15-2024 01:31 AM
235/40/18 on 8.5 rim width, all around. recommended offset? terenshu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-05-2013 11:27 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
