Old 04-20-2019, 07:00 PM   #1
Jamestl
Drives: None
Help - Loss of Power / No Engine Light?
So I was playing with my Solo DL / Smartycam today, and after plugging it in and started driving I got a check engine and traction light. I pulled over and put the OFT in there to read the error code, and it was a U0073. I looked it up, and unsure of what it was, I erased the code and tried to plug in the Solo DL again, and it produced the same thing, so I erased the code and stopped fiddling with the DL...
So I thought everything was cool - but then the car was really struggling after. I almost stalled it starting in 1st, and it seems like the car lost 1/3 of the power somehow. I pulled over again and pulled the battery to reset the ECU, but no change. All this time there's no engine light or anything. The only difference seems to be the tone of the engine when I'm giving it greater than ~30% gas, and it sounds really really raspy, almost like there's an exhaust leak? The car was working just fine right before, and it seems to be running fine otherwise, but it's just got no power.
Power mods: EL headers, OFT, Perrin intake pipe
Side note - the car did have the valve spring recall done ~500 miles / 3 months ago. I thought it could be related, but the engine isn't making any weird mechanical sounds - just the raspy sound when I'm pushing power.
Any ideas, folks?
Jamestl is offline   Reply With Quote
Old 04-20-2019, 08:47 PM   #2
steve99
Drives: FT86
When you clear codes it resets ecu, same as pulling battery terminal.
After reset you need to let the csr idle for a couple of minutes to ensure the vvt system calibrates and acrivates. If vvt does activate car will be way down on power.
Jist start car
Et it idle for couple of minutes should be ok
Old 04-20-2019, 09:36 PM   #3
Jamestl
Drives: None
Jist start car
Thanks, Steve. Tried that. Reset the ECU and let it idle. Same issue. Also used the OFT to re-write the stage 2 tune - same thing...
Old 04-20-2019, 09:46 PM   #4
steve99
Drives: FT86
Use oft to log vvt intake and exhaist make sure cams moving, log afr vs commanded afr ignition timing knock might give some clue
Old 04-20-2019, 10:15 PM   #5
Lantanafrs2
Drives: 2013 frs red
Sounds to me like cams not moving. Mine did same thing couple of years ago but cleared itself out and no problem since.
Lantanafrs2 is offline   Reply With Quote
Old 04-20-2019, 10:34 PM   #6
Jamestl
Drives: None
Will try to take logs tomorrow (getting late here).
@Lantanafrs2 - how was it resolved? I actually had a P0018 code about 18 months ago, replaced an OCV, and ultimately had to replace the ECM to get rid of the code. My guess is that the engine did not like 5w30 oil (syn) during the colder half of the year (I think it first happened in Nov/Dec, so maybe around 30-45 degrees?). Ever since it's been fine.
Old 04-20-2019, 10:39 PM   #7
Lantanafrs2
This happened within 5 thousand miles of complete engine replacement. I had just unplugged my oft after it told me I couldn't do real time analytics. Had a check engine light and car was sluggish but eventually it cleared itself. Been fine ever since.
Old 04-21-2019, 04:44 PM   #8
Jamestl
Drives: None
Alright, here is a short datalog file that I logged via OFT.
https://ufile.io/a04twc8o
I'm not an expert in reading these logs so any help would be much appreciated!
I also replugged in the Solo DL, and now it's just flashing... Without the OBD connection it starts up fine.
Old 04-21-2019, 04:44 PM   #9
Jamestl
Drives: None
So you didn't do anything else? Just went away?
Old 04-21-2019, 05:30 PM   #10
tomm.brz
Drives: brz 2017 hksv2
you didnt log cams, but they are definitely activating from what I see... it knocks A LOT if it s a stage2 oft tune, -5 of flkc is a very much
also ltft a but high, could be a little exhaust leak?
Old 04-21-2019, 05:33 PM   #11
Jamestl
Drives: None
Originally Posted by tomm.brz View Post
you didnt log cams, but they are definitely activating from what I see... it knocks A LOT because if it s a stage2 oft tune, -5 of flkc is a very much
Thanks much! I'm not sure on the exhaust leak, but it's def possible as it sounds like crap (like it's struggling for air or something) under WOT (also way diff than prior). The part that I don't understand is why the leak happened at exactly the moment the check engine light came on, and why I'm not getting a CEL?
Would logging the cams be helpful?
Old 04-21-2019, 05:52 PM   #12
tomm.brz
try logging them
leak wouldnt necessarily bring a CEL, fuel trims compensate... does it stink a lot and consume a lot?
Old 04-21-2019, 06:09 PM   #13
Jamestl
Drives: None
not more than usual? i avg 30mpg on highway yesterday for about 50 miles.
will re-log
Old 04-21-2019, 09:05 PM   #14
Lantanafrs2
Yes, I just drove it lol
Engine Immobilizer Light Blinking with Power Off yackery Issues | Warranty | Recalls / TSB 4 01-01-2018 04:50 PM
Loss of power/stall under light throttle. Model Citizen Forced Induction 49 10-21-2014 09:50 AM
Hi rev power loss? lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 09-29-2012 10:47 PM
CEL, Loss of Traction Light, Loss of Power pituala Issues | Warranty | Recalls / TSB 19 09-05-2012 12:23 PM
DI and engine power loss over time Sport-Tech Engine, Exhaust, Transmission 7 06-27-2011 06:49 PM
