Old 08-24-2013, 01:38 PM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by mad_sb View Post
Correct me if i am wrong EcuTek guys... but
Stockfront O2 sensor is accurate down to atleast 12.1:1 without modification
Stock ecu has a map sensor that can be replaced with a multibar sensor
Stock Ecu can control a solenoid valve for boost control
Why can't racerom be used to build in an AFR and Boost pressure based failsafe? You can easily drop to spring pressure using this approach, and optionally limit throttle angle, revlimit, retard timing, dump fuel etc etc.
EcuTek can definitely do a boost based Failsafe, but I haven't seen an AFR based one. I am not utilizing the AEM Failsafe features either. I am utilizing the accurate boost/afr in one gauge and the 3 hours of automatic datalogging with a great sampling rate that I can download from the gauge at any time for a great $300 price. I currently have an igntion timing retard boost failsafe in my ROM, and I have a boost failsafe in my EBC as well. I could very easily create an AFR based failsafe with my gauge and EBC, but I haven't spent the time to do it.
Old 08-24-2013, 07:26 PM   #16
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
I too am running the aem failsafe. With the AVO turbo kit. I am running the Grimspeed EBCS for boost control (factory fit and plug/play). I have it wired similar to the diagram. Basically, on the EBCS it is plug/play to subaru. The wires are simply 12+ and ground. All you do is run that blue wire to one side of the relay (86), 12+ to the other (85). Then cut one of the wires on the EBCS, doesn't matter which one. With the cut wire, run one side to 30, and the other to 87a. This allows it to function just as though there was no relay. Then, when the failsafe has an "alarm" it will trigger the relay, which opens the relay circuit (30 now connects to 87, which is empty), this essentially cuts power to the EBCS and you are now at standard wastegate pressure.
I will draw up a schematic when i get a chance. I have yet to actually setup my AFR alarm, as i am waiting for my tuner to get the EBCS tuned with my new Clutch, so i have it all wired and working properly, but right now running a MBC until i have the EBCS setup.
This will be happening in a couple weeks (hopefully).
gdrider77 is offline   Reply With Quote
Old 08-26-2013, 02:34 PM   #17
gdrider77
gdrider77's Avatar
As promised, here is a diagram i made showing connections.
Old 03-03-2014, 02:46 AM   #18
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
So, the boost level of the Grimspeed EBC is run by EcuTek via tune? Is this a popular EBC to use for EcuTek tuning?
OjiGeorge is offline   Reply With Quote
Old 03-03-2014, 11:05 AM   #19
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
I run a COBB but it's all the same.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 03-03-2014, 11:22 AM   #20
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Where are you guys grabbing the rpm signal from for the gauge?
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-03-2014, 11:40 AM   #21
jamesm
i use both boost-based and afr-based failsafes in my tunes when possible. in order to use the afr-based one you need to have a wideband wired into the ecu. it's very simple, just a custom map that calculates afr error and another to respond to it however you like (cut spark, fuel, boost or close the throttle usually). it works in concert with my full-time closed loop fueling strategy, which i often end up removing after the fueling has been dialed in (it uses up a lot of custom maps).
Old 03-03-2014, 03:25 PM   #22
gdrider77
gdrider77's Avatar
Yeah, pretty much any EBCS will work with the diagram i posted. They are all the same essentially.
With the new option of the wideband feed into the ecu via obd2 signal you could really just eliminate this type of connection, since you can do as @jamesm mentioned and have the ecu detect the true afr and switch to a custom map with fuel cuts, boost cut, etc...
I am having mine tuned currently for some options like this, since i already have the failsafe wired up, will probably just keep it in line as it wont hurt anything, adds a bit of redundancy. But have the wideband wired into the ecu now for true logging of that as well.
RPM signal is under the pass side in a harness. here is a thread about it.
http://www.ft86club.com/forums/showt...ailsafe&page=4
Old 03-03-2014, 11:16 PM   #23
Bigmaxy
Drives: Pegasus GTS86
Is it possible to have a flex setup using the rear o2 sensor, a wideband feeding into the Ecu via the CPC input and an EBCS running from the CPC output all being controlled via Ecutek?
Where do you grab the CPC inputs/outputs? I understand the CPC output is under the inlet manifold.
Just trying to get my head around this stuff.
Bigmaxy is offline   Reply With Quote
Old 03-04-2014, 09:48 PM   #24
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Just making sure you saw this:
Let me know if you need any more help finding it.
Old 03-04-2014, 09:56 PM   #25
Deadspool
Much title. Wow.
Deadspool's Avatar
I did not, completely mr magoo'd that one.
Thanks!
Old 03-16-2014, 04:53 AM   #26
OjiGeorge
OjiGeorge's Avatar
My tuner is telling me that running the UEGO wideband from my AEM failsafe to the ECU is just an over complication of things. That Ecutek already has enough safety features when tuned correctly. Am I just being overly paranoid?
Old 03-16-2014, 12:47 PM   #27
mack4477
Drives: 2013 Firestorm FR-S
Going to be putting mine in soon as well. No failsafe since I don't have an EBCS now. Basically it should just be a matter of installing the wideband and connecting some power wires then correct?
mack4477 is offline   Reply With Quote
Old 03-17-2014, 11:08 AM   #28
King Tut
NASA SpecE30 Racer
King Tut's Avatar
At a minimum yes it is a matter of running the harness from the sensor itself, a boost source, and a power and ground wire.
AEM Failsafe Scalzo Electronics | Audio | NAV | Infotainment 11 06-05-2013 09:10 PM
AEM Failsafe wideband gauge. skatery1989 Interior Parts (Incl. Lighting) 2 04-14-2013 10:12 AM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 01:42 PM
