11-28-2023, 09:33 AM | #617 |
The Dictater
Drives: '13 Red Scion FRS
The ocean is a pretty big net though. Parachutes like that are neither accurate nor precise.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
11-28-2023, 11:22 AM | #618 | |
1st86 Driver!
Personally, I think SpaceX has the right idea, and have proved it's a viable solution with direct fueled landings.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
11-28-2023, 12:06 PM | #619 |
chicken tonight
The SRBs do float. Once the fuel is gone, they're just empty cans. I don't know how, or if water is kept from entering the big hole at the bottom.
Did I read that correctly? Each of those parachutes weighs a ton? Never mind trying to steer the thing into a small target, it's literally a massive waste to lift anything that isn't actually payload. Every extra part that isn't actually rocket goes to the wrong side of the scaling issue. Also, Elon wants to land on Mars and come home. Regardless of how one feels about that project, I feel safe in assuming that plays into his current decisions.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (11-28-2023) |
11-28-2023, 12:13 PM | #620 | |
1st86 Driver!
I saw that too on the chutes and was surprised at the total weight. Still lighter I would imagine than enough fuel for the SpaceX landing which subjects the same weight penalty.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 11-28-2023 at 02:00 PM. |
The Following 3 Users Say Thank You to Dadhawk For This Useful Post: |
11-28-2023, 12:18 PM | #621 |
chicken tonight
Ah! Good point. Thanks.
11-28-2023, 01:47 PM | #622 |
Drives: Q5 + BRZ + M796
I would imagine side thrusters and the winglets could correct for wind, but that is just me guessing wind would have a low impact against the inertia and momentum of 500 tons.
11-28-2023, 02:04 PM | #623 |
chicken tonight
Think about the chutes themselves, flying kites, even umbrella in a slight breeze should bring some perspective.
11-28-2023, 03:32 PM | #624 |
1st86 Driver!
It's one of those diminishing return things... How much fuel do you need to fly the fuel that flies the fuel that flies the fuel for landing.....
11-28-2023, 04:15 PM | #625 |
chicken tonight
Oh, yeah! I smacked my forehead as soon as you mentioned it. Good stuff.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Dadhawk (11-28-2023) |
11-29-2023, 12:13 AM | #626 |
LMGTFY
Drives: 13 FRS, 91 Miata
Cost/time of water landing and recovery w/ parachute then prep for relaunch vs Land and reuse.
Figure the parachute way is initially cheaper but removing all the equipment and personnel for is must save a bunch. Wonder where the break even point is. Hope it's less than 20-50 launches before landing it starts to become cheaper. (for Falcon-9) |
The Following 2 Users Say Thank You to x808drifter For This Useful Post: | Dadhawk (11-29-2023), Ultramaroon (11-29-2023) |
11-29-2023, 07:15 AM | #627 |
1st86 Driver!
The other factor is that sometimes you need every ounce of fuel to get to lift the payload. Even SpaceX has plans to recover some rockets and "sacrifice" others for the good of the mission.
Also, if I recall correctly, SpaceX doesn't recover the center booster of the Falcon Heavy, only the two outside ones. there is a similar plan for Starship where sometimes they'll recover the first stage and sometimes they won't.
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | Ultramaroon (11-29-2023), x808drifter (11-29-2023) |
11-29-2023, 11:37 AM | #628 |
30 minute maintenance
Drives: My18 wrxsti My19 brzts
Like Apollo 11. Enough fuel to break earth orbit, fly to the moon,power land, take off again and break lunar orbit for the return. All in, fuel hungry, 70`s tech.
Wait until my Flex capacitor hits 88
The Following 3 Users Say Thank You to gen3v8 For This Useful Post: |
11-29-2023, 03:19 PM | #629 | |
When I went skydiving, we landed on a ten by twenty foam mat from 30k feet. There are GPS guided parachute systems already in use for dropping supplies and Humvees (Source 1, Source 2), so I have to imagine that with the grid fins, side thrusters, GPS systems, and with the sheer mass of the object, that landing in a reasonable zone would be achievable. The reentry puts the booster fairly vertical, so it would be a matter of devising a way of catching a massive object.
11-29-2023, 03:51 PM | #630 |
Meow
Drives: GT86, Volvo 996
For something as sensitive to defects as aerospace, I'm surprised the booster having been immersed in seawater (and not being cleaned for probably several hours) doesn't require to change / clean / repaint every single panel, for a higher cost than building new one.
Maybe boosters are that expensive. |
Similar Threads | ||||
Which Space Saver will fit? | Andrew666 | AUSTRALIA | 25 | 06-18-2020 09:07 AM |
Cockpit Space | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 03-15-2014 03:24 PM |
First run 86's (Space Saver question) | DriftEightSix | AUSTRALIA | 11 | 01-10-2013 07:25 AM |
FR-S space saver | sierra | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 11-29-2012 12:18 AM |
Trunk space? | tranzformer | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 04-13-2011 12:29 PM |
