Old 09-03-2026, 03:53 PM   #127
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
Yep, got those same LCAs. I'll probably want to order to the toe arms sooner rather than later. Whatever it is in the car right now, although adjustable, is probably a no-name brand and likely bad quality.
Yep. Having a aggressive negative camber front and rear is a game changer in DST.
Good luck with the build. It's just going to get better and better.
RongTurnRacing is offline   Reply With Quote
Old 09-20-2026, 07:46 PM   #128
strat61caster
strat61caster's Avatar
SPC lower control arms are not ST legal last I checked, they use a spherical bearing on the inboard side instead of elastomer.
https://www.spcalignment.com/product/67660
"Get the ultimate in performance and handling with this stamped arm featuring our new xAxis Sealed Joint which performs like a pillow joint but lasts like an OE joint."
Cheap and easy (should be <$300) is the whiteline version that puts a polyurethane bushing in that spot. Although I've had issues with it slipping (pretty much entirely due to street driving) - haven't roughed them up yet in an attempt to get better bite, but that's all I can think of to fix them without spending $$$.
https://whitelineperformance.com/us/...-kta216a.html?
Seems like swapping the upper control arm is the latest hotness, but at >$600 I'm not excited about it, at least you can shed some weight and stiffen up those bushings in the process.
ineedyourdiddly
Old 09-21-2026, 10:06 AM   #129
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Cusco upper arms are ~$400 imported from Japan, wildly cheaper than the US distributor pricing and cheaper than the "good" lower arms that people spend a LOT of money on.
Old 10-14-2026, 12:36 PM   #130
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I rode in with Evan LeBlanc this past weekend and holy shit. I've sat with fast drivers, but Evan is different.
Also, I still hate 2nd gear on the 18 BRZ. Im thinking mimicking his setup which the main difference is he has an Equal Lenght Header and ECUTEk instead of OFT. The header was weird, part of the piping would stick up near the radiator fan.
Old 10-18-2026, 02:14 PM   #131
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
It's a double edged sword depending on your lot size and course design. Our smaller lots love it. I like when you're just getting to limiter or maybe even well under it. Then when it's a wide open venue or course and you're having to go into 3rd or stuck on the limiter a while - eh, 100% with you. It sucks.
I'm on 245/40 vs 45. Might do 45 next year. We'll see.
.... I should really get around to doing a header and tune. I was like 7th in raw out of 65 at the last event here locally and that extra power could have been a little bit more needed. Couldn't hurt, right?
cmiovino is offline   Reply With Quote
Old 10-20-2026, 11:24 AM   #132
spcmafia
spcmafia's Avatar
100% Agree. With other group I run with, courses are on a skidpad and you won't ever really hit the limiter, but on tight turns that 2nd gear lower RPM is a killer.
Old Yesterday, 02:04 PM   #133
spcmafia
spcmafia's Avatar
Is there anything else that I can do squeeze some extra HP out of the car?
Currently on, Drop in Air filter, Perrin Inlet, JDL UEL catted headers, OEM front Pipe, and ARK grip cat back with OFT Tune by Steve99.
I was talking to Evan and hes on Grimmspeed Intake, P&L EL gutted cat header, HF Front Pipe and OEM exhaust, but on Ecutek.
Old Yesterday, 07:03 PM   #134
RongTurnRacing
Berk catted front pipe. The OEM pipe is more restrictive. JDL 4-2-1 header. In DST you only need one cat and it just needs to be located near one of the OEM cats (within 6 inches). I would say to go with the JDL over pipe since it's properly sized as well. Stay with OEM intake and wrap it in the DEI gold foil since that produces the most power and the tape reduces heat. A proper dyno tune would be your best bet to squeeze the most out of it (ECUTek or OpenFlash for tuning).
2025 SCCA Time Trials Rules - General Discussion RongTurnRacing Tracking / Autocross / HPDE / Drifting 13 01-26-2025 03:42 PM
SCCA T4 Build thread rice_classic Tracking / Autocross / HPDE / Drifting 278 08-09-2023 01:29 PM
SCCA XSA thread Breadman Tracking / Autocross / HPDE / Drifting 31 07-14-2023 06:42 PM
2019 CDC & SCCA Autocross Thread JakeRogue Mid-Atlantic 15 05-17-2019 10:58 AM
2015 SCCA Solo Nationals Thread Jawnathin Tracking / Autocross / HPDE / Drifting 140 09-15-2015 02:00 PM
