Old 07-24-2014, 03:47 PM   #1401
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Has anybody messed with the intake at all? I wana be able to hear the s/c a bit more. I'm considering plumbing the old intake sound tube into the breather line attached to the air box.
bee_are_zee is offline   Reply With Quote
Old 07-24-2014, 04:46 PM   #1402
ft86me
ft86me's Avatar
Drives: 2013 FRS
Questions and Discussion on Vortech Supercharging Systems
I have a custom cold air to where the air filter is under the toyota badge in the front bumper. 90 degree bend then quick 180 to air filter under the bumper. You can def hear the blower more buuuuut you will hear flutter a loooot more so that's the trade off. Apparently so I've been told, the airbox muffles the flutter a lot. I could be wrong.
Sent from my iPhone using TapatalkAttachment 85984
ft86me is offline   Reply With Quote
Old 07-24-2014, 05:04 PM   #1403
bee_are_zee
Drives: GBS BRZ
I do like your setup. I may try the sound tube thing first but will probably start sourcing some pipe and elbows, see if I can't whip something up.
Old 07-24-2014, 05:06 PM   #1404
ft86me
ft86me's Avatar
Drives: 2013 FRS
Good luck man! Hope somethin works out for ya!
Old 07-25-2014, 02:54 AM   #1405
Cal3000
Drives: Panda FR-S
Originally Posted by Dezoris View Post
I never used the snorkel and wonder now if it makes any measurable difference.
From what I know, Q=VA. Flowrate=Velocity of flow x Area.
I don't know what the snorkel diameter is, but I would figure you would choke mass air flow probably killing power due to the smaller diameter duct.
Hence why I don't think they dont recommend using it.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 07-25-2014, 10:51 AM   #1406
rs999
rs999's Avatar
Drives: VW MK6 GTI | 13 Mustang GT
Perrin or Vortech owners do you still go to the dealer for any work?
I don't care about warranty coverage but would a Toyota dealer refuse service work if you showed up with a Vortech under the hood?
I already have two independent Subaru shops in my area that could be the next care takers of my car. But they won't be able to do Toyota firmware flashes or factory recalls if those occur.
SOLD FR-S Build | MK6 GTI Build | I might be getting another FR-S
rs999 is offline   Reply With Quote
Old 07-25-2014, 11:03 AM   #1407
bee_are_zee
Drives: GBS BRZ
Small general question on top of all of that. Can an oem even deny recall work on a modified car?
Old 07-25-2014, 11:18 AM   #1408
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
No, but they'll try to blame mods if the recall isn't performed and then it breaks, if you've got mods that might effect the system that the recall pertains to...
The 2G DSMs had a recall for the front lower ball joints, they would get dirt inside the joint and over time it would wear out and fail. (then the suspension would collapse) I didn't know about the recall until the ball joint failed on my '95 Eclipse. Luckily for me it failed as I was pulling into a parking space, not 5 minutes after I pulled off of the highway where I was going ~70mph. The service manager tried to blame suspension mods that I didn't even have. The car was stock everywhere but under the hood.
Sellout is offline   Reply With Quote
Old 07-26-2014, 12:58 AM   #1409
HRTROB
HRTROB's Avatar
Drives: Toyota 86
So I pulled my airbox off the other day to do some work on the car not related to the SC (had to wrap and clamp the rattling flex joints of my Borla header). I noticed a little bit of oil on the blower inlet around the impeller. Have any of you observed the same? I have dual Radium catch cans installed, and the side that goes to the intake is still clean, no trace of oil in the can and inside the airbox. Car has a little less than 2,000km on the SC. Blower lubricant has recently been replaced and I made sure not to overfill.
I'm also thinking of removing the snorkel behind the bumper. Will the additional airflow affect my current tune? Right now the AFR readout from my AEM gauge goes down to the high 10s when I go WOT and peaks at 11.3-11.4 at redline.
HRTROB is offline   Reply With Quote
Old 07-30-2014, 06:38 PM   #1410
misooscar
misooscar's Avatar
Drives:
Almost done with Vortech install with a used kit, and I'm anxious to fire up... yet 2 issues I need to resolve...your help is appreciated, I owe you a brew...
1) I'm missing the PCV breather check valve which is spliced onto the top of the passenger side intake manifold.
It's not Vortech ' s fault, it was a used kit...
Is it ok to run on the street for a week or so, driven gingerly, until it arrives from Vortech? Or do you know of any off the shelf dealer parts that I could pick up today, perhaps a factory FI vehicle has the same part, it's a check valve spliced onto the intake manifold with 3/8 in hose barbs?
2) How do you jump the fuel pump relay, so that I can run Vishnu Tuning ' s oft 300 93 map? Currently I have a 3/4 tankfull of e85...any experience draining the fuel tank...I owe you 10 gallons of e85...?
Or perhaps, is there a quick and easy way to tune the oft 300 93 map so that I can get the oft 300 map to turn ovet, I suspect it need more fuel on cold start up?
Thank you!
Sent from my SM-N900T using Tapatalk
misooscar is offline   Reply With Quote
Old 07-30-2014, 09:28 PM   #1411
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Thank you!
You could just remove the hose and cap off the port on the manifold while you wait for the check valve. Be sure to use a hose clamp on it. I would recommend getting a 3/8" to 1/2" hose coupler and using new hoses when your check valve arrives, that way you can reuse your unmolested stock hose if ever you go back to stock. How much was the check valve from Vortech?
I've never drained the fuel tank so I can't help you with that
Old 07-30-2014, 10:00 PM   #1412
bee_are_zee
Drives: GBS BRZ
No clue how to clear the tank. Why did you not finish off your tank of e85 before starting all this?
Old 07-30-2014, 10:20 PM   #1413
DJCarbine
Thupercharged
DJCarbine's Avatar
Autozone usually has universal vacuum check valves on the shelf in the "help" section with the other random bits (Throttle cables, window crank handles, etc.)
2013 FRS
Vortech V3 11psi
Old 07-30-2014, 10:48 PM   #1414
misooscar
misooscar's Avatar
Drives:
25 dollars through vortech plus shipping
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 06:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 04:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 07:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 06:06 PM
