Old 04-02-2014, 04:21 PM   #1401
quicksilver30
quicksilver30's Avatar
Drives: '13 LR BRZ Limited| '07 Jeep GC
I know its early...but have any of you guys that already have the header installed see any issues with heat since its not wrapped or have any ceramic coating?
quicksilver30 is offline
Old 04-02-2014, 05:39 PM   #1402
JaguarXJ6
JaguarXJ6's Avatar
Drives: 2015 GT-R, 1993.5 Supra, 1995 XJR
#4263 checking in, arrived on Monday 31st and I was in middle of the pre-order batch.
My appointment and tune with Evasive is on the 14th so between now and then, I will be doing pre-install videos in and out of the car with my intake and header-back exhaust system. See sig.
Then, same videos in and out of the car on the same road and same speeds after the header. Of course, before/after dynos will be shared. I'm currently pig rich on stock tune with the mods in sig, been waiting for the header before I tune.
2015 GT-R Pearl White with Ivory, Premium | Stock, DD
1995 Jaguar XJR | Turquoise Metallic | I6 4.0L | Eaton M90, 11psi | 4L80E | 1 of 12 of 400
1993.5 Supra Turbo | Baltic Blue | 6spd | 3.77 Torsen LSD | SP57 | RPS manifold | ViPEC V88 | 525/500rwhp/tq
JaguarXJ6 is offline
Old 04-02-2014, 06:02 PM   #1403
TwinturboCamry
Drives: 4 wheels
So will this cause a CEL without a tune?
TwinturboCamry is offline
Old 04-02-2014, 06:05 PM   #1404
JHarperFRS
JHarperFRS's Avatar
Drives: 2013 Scion FR-S "White Out"
No...it will not. If you've read or followed the thread, @FT-86 SpeedFactory has said that it will not.
Sent from my SCH-I545 using Tapatalk
JHarperFRS is offline
Old 04-02-2014, 06:12 PM   #1405
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Excellent, looking forward to hearing some updates.
leicaboss is offline
Old 04-02-2014, 08:11 PM   #1406
nunonuna
nunonuna's Avatar
Nice~
when you are updating more info, please show us afr before tune~ please~
Sent from my Galaxy Nexus using Tapatalk
nunonuna is offline
Old 04-02-2014, 10:19 PM   #1407
JaguarXJ6
JaguarXJ6's Avatar
Originally Posted by nunonuna View Post
Nice~
When I get home I'll show you a before and after dyno that shows me getting to under 10 AFR and lower at redline with my current mods on the stock ECU and tune with about 4k miles. This is from memory when I did the dyno in Feb.
On a completely stock car, it was fine, but the ECU overcompensates, excessively so in my experience, when you increase flow with a full intake and header back.
Old 04-02-2014, 11:07 PM   #1408
JaguarXJ6
JaguarXJ6's Avatar
So here is a stock tune (blue line) at 1,500mi and then the black and red after intake, Perrin overpipe, Berk catted front pipe, Perrin 2.5" resonated cat back installed at 3,000mi and dyno'ed with 3,500mi.
Fuel trims were rich under power, but fine under cruise. Now after things are broken in, rich all over the place even on cruise. My mileage is suffering big time putting around Santa Barbara stop light to stop light under 3,500rpms. By a factor of 1-2MPG a gallon worse.
Rev matching I can hear the effect of too much fuel being dumped in from the motor stumbling when I give the accelerator a quick stab instead of rising lazily, but smoothly, like it did when completely stock.
Short term fuel trims in closed loop can only accommodate so much before the fuel and timing tables are too far out of whack for the new flow of the motor. I was hoping to avoid a tune and stay on the stock ECU but you know what, its just the daily and only needs to last me a couple years. Time to go ECUTek!
Old 04-02-2014, 11:16 PM   #1409
Luis_GT
Did you try resetting the ECU by disconecting the battery?
Luis_GT is offline
Old 04-03-2014, 12:42 AM   #1410
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
^+1 was about to ask the same thing
BigFatFlip is offline
Old 04-03-2014, 01:41 AM   #1411
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
look at what i got today. #4264. wont get installed until i get my nameless combo pipe and i'm really debating on getting the header coated.
once i get everything installed it will be FT86SF catted header<Nameless combo pipe with cat and res<FT86SF V1 CBE.
Sypher is offline
Old 04-03-2014, 01:45 AM   #1412
JDogg
JDogg's Avatar
Drives: 2013 Black Scion FR-S
Do you know what number you were in line for the headers? Like for example, I was #22 to order the headers.
JDogg is offline
Old 04-03-2014, 01:57 AM   #1413
Sypher
Sypher's Avatar
Based on the initial list someone drew up I was 10th I think but I never did ask FT86SF what number I was
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's
Sypher is offline
Old 04-03-2014, 01:58 AM   #1414
leicaboss
Coffee Snob
leicaboss's Avatar
Damn son you got yours already!
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 11:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 01:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 01:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 01:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 11:12 PM
