#14365 |
Drives: '06 AM V8V Coupe
@Dimman you know I'm thinking maybe a Hayabusa motor conversion would be easier than building a 1NZ...even with custom adapter plates and stuff, it might even cost less.
Hayabusa motor modifications to make it more street friendly: -stroker (not completely necessary) -smaller exhaust cam, adjust intake cam (if the LFA can get away with proportionally smaller valves then this can get away with less lift) -300M rods, ceramic coat everything that's not already coated in exotic s*** -remanufactured case and mating to transmission... ![]() -modify the throttle bodies Preferable: 14:1 comp pistons EMS: standalone 1NZ modifications to make it racy: -new titanium? valves ($$$$), valve springs -oil pump -water pump -new cams on both exhaust and intake -new pistons, highest they go is 12.5 before you need custom ones :/ -major headwork -300M rods, ceramic coat everything that's not already coated in exotic s*** EMS: standalone Comparison: Rev limit realistically can only be 8000ish without a destroke on the 1NZ aka limited to ~170hp, Busa wins massively on power and will sound more glorious. Busa fuel economy will probably be worse. Primary reduction gears from Busa can be adopted as in the Miatabusa project but mated to a Toyota transmission this means 4000rpm cruising which sucks. Hmmm. |
#14366 |
Hayabusa motor modifications to make it more street friendly: -stroker (not completely necessary) -smaller exhaust cam, adjust intake cam (if the LFA can get away with proportionally smaller valves then this can get away with less lift) -300M rods, ceramic coat everything that's not already coated in exotic s*** -remanufactured case and mating to transmission... ![]() -modify the throttle bodies -modified oil pan Preferable: 14:1 comp pistons EMS: standalone 1NZ modifications to make it racy: -new titanium? valves ($$$$), valve springs -oil pump -water pump -new cams on both exhaust and intake -new pistons, highest they go is 12.5 before you need custom ones :/ -major headwork -300M rods, ceramic coat everything that's not already coated in exotic s*** EMS: standalone Comparison: Rev limit realistically can only be 8000ish without a destroke on the 1NZ aka limited to ~170hp, Busa wins massively on power and will sound more glorious. Busa fuel economy will probably be worse. Primary reduction gears from Busa can be adopted as in the Miatabusa project but mated to a Toyota transmission this means 4000rpm cruising which sucks. Busa requires more custom work. Hmmm. Last edited by serialk11r; 05-19-2013 at 09:55 AM. |
#14367 |
Drives: Sexy Frs Firestorm M/T
I was actually thinking of trying to find something for her on that site -sadly tho they can be a bit pricey. either there or
http://www.uncommongoods.com/ since she said she liked the site....only they're kind of expensive too....and she just moved so she still needs things that you would find at say bed bath and beyond but I don't know what? Shes not the kind of person who will tell you what she needs because she doesn't like people spending money on her so I gotta listen super closely. I think Ill go with a puzzle of long island, or something closely related to it since she moved to ohio...She did say how she wanted to put it together with her bf and hang it up lol...now I just gotta figure out where the hell am I going to find one... |
#14368 |
Drives: 2013 Whiteout FR-S
#14369 |
Drives: N/A
The one and only E85 pump in town reopened. The pumps are so old the E85 stickers are discolored. I was a little bit excited so I bought premium fuel and some sodas at that particular station. But E85 was 10 cents less than Regular from a different station. F@ck that. It should be under $3 about now.
#14370 |
That Guy
Drives: 2013 asphalt FRS MT
I need a garage and a lift. Ouch.
Also, RCE Yellows are worth the hype! The whiteline catalog im not sure about yet, waiting for some bushings to break in. Sent from mission control |
#14371 |
MODERATOR-SAMA
Drives: Swagtron Scooter
out of surgery, had some crap removed from intestines, which are inflamed and infected.
Now im on a Bland Liquid diet for 2 weeks. taking a shit combo of meds. which make me nauseated, give me headaches, and constipated because i cant eat solids. So for the next 2 weeks ill be in pain, vomiting, headaches, dizzy, constipated and hungry.... FUCK.....MY.......LIFE
#14372 | |
Drives: 1985 P-Type
DO YOU KNOW HOW MUCH IT HURTS TO LAUGH WHEN YOU'VE JUST HAD ABDOMINAL SURGERY? Hang in there. Stay away from jokesters. |
#14373 | |
Site Moderator
Drives: ichi 86 Project
#14374 |
Kuruma Otaku
@serialk11r
Once you get your financial job, and people throw money at you to game the markets, maybe. I'd go 'Busa (if they can put one in a smart car, they could put one in your Spyder), because racebike. (Also because tuning parts/knowledge base is established in 2 wheel land.) Until then 2ZZGE + 6M. Easy, established, powerful and high rpm screamer.
Because titanium. Last edited by Dimman; 05-19-2013 at 04:12 PM. Reason: theN... |
#14375 | |
Im am actually going to do this voluntarily this week. Juice Diet to clean out all the toxins in your body. As much as the first few days suck it feels good after. Although with your pain and meds I am not sure how good it will feel Pro Tip is hit up that coconut water and drink lots of it Hope you feel better !
#14376 |
Drives: N/A
I found this the other day. Really great base for an engine swap, could even sell the engine/tranny to help pay for the build. I wish I could but I can't.
![]() http://www.kiastoreeast.com/used-car...-Louisville-KY Can't touch an MX-5 of the same year for less than $10k but there's an RX-8 for half that. |
#14377 |
Drives: 1985 P-Type
@Allch Chcar what are the popular engine swaps into the RX8?
#14378 |
Wayward Member
Drives: Hot Lava 86
So my best friend's dad bought him a 300ZX that needs some work for his birthday.
| h6 swapouts? any thoughts or advice? | f1ver | BRZ First-Gen (2012+) — General Topics | 53 | 11-22-2014 12:46 AM |
| Aspera's thoughts on AWD/RWD... | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 89 | 11-16-2013 03:55 PM |
| random casual discussion on dynamic brakes | serialk11r | Other Vehicles & General Automotive Discussions | 4 | 07-16-2012 10:34 PM |
| The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 08:59 PM |
