#141 | |
Drives: 2023 WRB BRZ (MT)
And after it didnt work i didn't use a tap, we held wire to wire so it was a clear connection being made. That's wuts weird. Imma try and get my friends tester to see for sure wtf is up |
#142 |
Drives: Whiteout FRS
Diagram looks fine. Should work. By wire to wire do you mean you unplugged the connector, and stuck the wire in the pin for the pink wire? If so....be like super careful....that's exactly how ecus get fried if even a strand of wire crosses to the green pin.
#143 |
Seriously, don't try using a tester on the connector itself. You most likely will fry the Ecu. Just plug it into the dome light assembly and turn it to the door switch. If the dome light works fine with the door open, then it is your tap, or the wire running from the tap, or the connector at the switch.
#144 | |
ok ill test that out this weekend. just out of curiousity tho. since it sends the door signal too the door lights and i have the kit that has the wires runnin from dome to floors, why can i get the door signal from that wire since i know it clearly has power when the door is open |
#145 | |
#146 | |
#147 | |
Drives: Subaru BRZ 2013 - SWP 6MT
Thanks! Also what stripes did you use? or what did you use for the lights?
#148 |
The way the oem phasetek is set up the outgoing wires are only connected when the dome light is switched to door or on. So, yes you can use the ground wire from that setup, but the footwells will only come on when the dome light is on. (Well at least the door open part of it). To get the floor well lights to work independently of the dome light when the doors are opened you have to tap the pink wire.
#149 | |
#150 |
Yes, that should work just fine.
#151 | |
o and i found my issue. i was tapping the pink at the bottom of the harness, but it was the wrong pink (dark pink) didnt see the light pink in the back till today lol |
#152 | |
#153 |
Drives: Black 13 GT86
#154 |
Drives: Scion FR-S
Bought my leds from ijdmtoy. bought some cheap switch from home depot. took me about an hour honestly. taking apart the center consule took me the longest. just tapped into the cigarette lighter for power.
2013 Ultramarine FR-S 6MT
| Differences In Types of Headlights/Lighting | Asphalt | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-21-2013 08:49 AM |
| HID_Powerhouse offers HID kits and LED lighting for your FR-S/BRZ | KI_ZN6 | CANADA | 2 | 07-27-2012 06:13 PM |
| interior lighting? | fistpoint | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 05-09-2012 02:52 AM |
| Stupid girl 2 foot driving | GenkiElite | Off-Topic Lounge [WARNING: NO POLITICS] | 31 | 07-23-2011 09:33 PM |
| How much do you like heel-toeing or left foot braking? | USMCMike | Other Vehicles & General Automotive Discussions | 20 | 01-15-2010 05:20 PM |
