#141 | |
Drives: Some rust bucket
I'm guessing if I ordered 2 290x, I won't get 900x2 kilohashes. How many hashes do you get if you run 2 cards, 3 cards, etc? |
#142 |
Depending on the card, and how the bios is setup, you can get close to the same hashing power on both... both my 7950's do 640khash be it single or both on the same rig.
#143 |
blowhard
Drives: frs, project forester
I have one slow system (on new parts). All cards are the same.
Also. I had a 290x for a few days. It was more like 850khash but I didn't tweak it much either My 270x get 420-430 each on most. 380 ish on another couple on the slow system. Cost about a third of 290x Assuming retail 280x is the amazing card. Which is why it has $100 markup |
#144 |
280X = 7970, it does around 750khash
#145 |
Now w/ over 400 womprats!
Drives: BRZ LZR
I still haven't found a way boost my 7970s to 750... They're both sitting at about 640.
I think I'm going to try changing drivers again... Nothing else has seemed to work...
- The Ancient BRZ Sacrament by Zaku |
#146 |
Cancelled my 290x order and ordered 2 280x instead. Better hash/$. I'll be limited to 2 video cards for now unless I upgrade my PSU.
#147 |
#148 |
Drives: BRZ LZR
Beautiful!
#149 |
Drives: BRZ LZR
I think I froze my cards last night...
I have the computer at a window with a box fan. I let it run for a bit and saw it was running a bit hot, so I opened the window and turned the fan on. It was -3F outside and after about 10 minutes I noticed that one of the cards was running it's fan at a very high speed... I turned on my monitor and checked, and both cards read 0 degrees and were hashing at like 10KHs. One Fan was at 100rpm, the other was at 4100 rpm... Needless to say, I'm regulating the heat now, and everything is running smooth. But my room is really freaking cold...
#150 |
LMAO... although as long as it doesn't ice up you should be fine... people have run this card under liquid nitrogen... lol
#151 |
Hmm... I'll need a bigger PSU to run more than 2 cards.
#152 |
Audio & Bacon Junkie
Drives: 2013 WRB BRZ Ltd
I have a Seasonic 1000w Platinum running four 7950s. It seems to do just fine.
I tried the Litecoin BAMT and have had some issues. I think I am going to try and put together a Xubuntu build on a USB3 flash drive. I've undervolted all of them to 1.081v and cards three and four slow down after a little bit. None of them make it above 80C. Is it a config issue or a power issue? I forgot to check my KillAWatt when I noticed that issue. |
#153 |
Which pci express riser cards do you guys recommend?
#154 |
blowhard
i got the cheap ones off amazon that shipped sooner than 3 weeks out, won't matter till i build a case/ enclosure
micro center got 280x in locally today @ retail. 4 in stock when i first noticed, 1 in stock by time i got to cart. |
