Old 02-27-2015, 02:48 AM   #141
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Best description ever! Good times dicing it up today.
You should come out to our monthly races, lots of great battles to be had
Decay107 is offline   Reply With Quote
Old 02-27-2015, 03:26 AM   #142
Ultramaroon
not playing cards
Ultramaroon's Avatar
Oh, I'm all in. Got the card and everything.
You guys are friggin' fast!
Old 02-28-2015, 12:06 AM   #143
504
504's Avatar
Drives: 2014 86 GTS
so @Ultramaroon, you have the smaller slave cylinder with helper spring installed and a clutch adjustment?
omg.. here we go again.. trying to hold back that urge to play with the clutch, trying to convince myself "its good enough" but knowing I'll eventually give in. ARGH!
took many painful hours to remove that spring from a RHD
504 is offline   Reply With Quote
Old 02-28-2015, 03:39 AM   #144
Had a chance to drive @Ultramaroon 's car today, This makes the car feel like it has an actual clutch. The stock clutch by comparison, feels kinda like stepping on an overripe grapefruit connected to a random number generator which determines when the clutch will grab.
AHHH I want to drive his car too! Not fair.
Old 02-28-2015, 03:40 AM   #145
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I drove it too
Old 02-28-2015, 03:44 AM   #146
I drove it too
Oh god I hope you mean the car!
Old 02-28-2015, 03:48 AM   #147
Andrew025
Andrew025's Avatar
All night baby.
Wait, what?
Old 02-28-2015, 03:50 AM   #148
All night baby.
Wait, what?
Based solely upon my self imposed rule of not jacking a tech thread we will leave it at that!
Old 02-28-2015, 04:05 AM   #149
JB86'd
JB86'd's Avatar
Drives: JAWS
I have the smaller slave installed, spring removed, and clutch adjustment. I really like it. I'd advise you do the smaller slave replacement, it makes a bigger difference than removing the spring.
Old 02-28-2015, 06:20 PM   #150
Ultramaroon
not playing cards
No. I was saying I hate that thing. @Andrew025 convinced me to pull it. I'd say it's an essential part of the overall mod.
1. Slave cylinder
2. Adjustment
3. Spring removal
Tight quarters up next to that tunnel? I don't envy that. I considered removing the whole pedal assembly to remove the remaining parts of that device.
Old 02-28-2015, 06:23 PM   #151
Ultramaroon
not playing cards
All night baby.
Wait, what?
Old 03-04-2015, 09:42 PM   #152
morerevs
Drives: GT 86 and Civic track car
Hi dudes,
I have been following this thread for a while now and have since ordered a clutch slave cyl, whiteline postive shift kit, mtec shifter springs and the mtec clutch spring.
Everyone seems to love the shifter springs but I can't seem to find any info on the replacement clutch spring. From what I gather it is just a lighter spring than OEM. Perhaps its a nice medium between the OEM and having it removed all together. Has anyone else installed the mtec spring?
Please note it will most likely be a few weeks before I get the parts/get around to installing them, but I will post up findings.
Cheers.
morerevs is offline   Reply With Quote
Old 03-29-2015, 06:53 AM   #153
morerevs
Findings:
Whiteline positive shift kit (Transmission mount insert) - Initial impressions where that It gave the clutch better feel which I was a bit surprised at. I thought that I might only feel it through the shifter, which is helped slightly as well but biggest improvements where in the clutch feel.
The other thing was that it does at a little bit of NVH. Initially it seemed like too much to deal with but it seemed to settle down and you get used to it pretty quickly. Since I spend a lot of time driving, I have decided I will be swapping the whiteline insert for the TRD engine and trans mounts. Pricey in comparison but hopefully a decent improvement after seeing other people reviews of them.
Mtec clutch spring - I have only just installed this today but initial impressions are just as predicted. It adds a bit of weight to the clutch pedal but no actual improvement in feel. The mtec spring is roughly half the tension of the OEM spring just pushing it on the ground. I havent actually tried the clutch with the spring removed completely.
At this stage, I would only recommend the mtec spring if you are used to a heavy clutch, but having said that, you could probably achieve that removing the spring all together (and its a free mod).
*NOTE: I had to do this on a RHD car. This is a complete PITA unless you remove the R/H side strut bar, clutch master cylinder and clutch pedal assembly. Which is not as difficult as it sounds. Much easier than trying to do insitu.
Will hopefully install the slave cyl soon...
Old 03-29-2015, 02:23 PM   #154
Ultramaroon
not playing cards
I've wondered about that. I think I'm repeating myself but my OCD kicks in whenever I think of the bottom half of that spring assembly flopping around.
C'mon, man! You've R&Red the pedal cluster and still haven't installed the slave? Get on that shit.
clutch line, slave cylinder
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 07:31 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 09:14 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 11:22 AM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 02:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 06:32 PM
