Old 04-17-2017, 10:45 AM   #15443
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Got rid of the sound generator.
Quite surprised that it sounds better than when it was plugged.
Scrappydoo is offline   Reply With Quote
Old 04-17-2017, 11:52 AM   #15444
It made a notable difference? I have been knocking around the idea of a full delete but didn't think there would be enough change to warrant the work. If it does I need to dig out my tools.
Old 04-17-2017, 03:42 PM   #15445
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
I'm a bit surprised too tbh. You know how cynical I am about modifications. No tools needed other than a 8 and 10mm socket. Rest can just be removed manually.
Don't really need a plug either as the glove box one works. Mine just remained in place when I pulled out the hose.
I used a generic version of the Perrin type of inlet hose. Could have been slightly longer but seems ok. I'll keep an eye on it. If necessary I'll buy something more expensive.
Mid range seems much better and the car just feels less tinny and cheap.
Old 04-17-2017, 03:44 PM   #15446
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
And it was a noticeable difference.
Old 04-17-2017, 03:55 PM   #15447
JD001
JD001's Avatar
Drives: Subaru BRZ
Something that I hadn't considered but you've made some very persuasive points....grrrrr!!
In years to come the sound generator paraphernalia will be much sought after. I'm going to request all redundant generators are posted to me as I will make a killing in year 2035!!
Old 04-17-2017, 03:59 PM   #15448
I shoved the glove box plug into the sound tube before I even drove the car off the dealer's lot. The sales staff were totally baffled as to what I was doing. If it does indeed make a big difference with all that stuff pulled then I have a project for some point on the weekend.
Old 04-17-2017, 04:01 PM   #15449
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
True. Worth keeping in a bag just in case.
Is the car equivelent of a tapeworm. The helmhotz resonator is its fat gut. Yuck.
Old 04-17-2017, 04:03 PM   #15450
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Are you replacing the inlet tube?
Old 04-17-2017, 04:08 PM   #15451
Probably just plug it and see how that goes.
Old 04-17-2017, 10:33 PM   #15452
ztrevs
ztrevs's Avatar
Drives: 17' CWP BRZ ------- 15' GLA45 AMG
Paint Corrected + Opti-Coat Pro treated!
ztrevs is offline   Reply With Quote
Old 04-18-2017, 01:17 AM   #15453
imnotsureaboutbrz
Drives: between cars...
What kind of paint correction does a brand new car need?
imnotsureaboutbrz is offline   Reply With Quote
Old 04-18-2017, 01:24 AM   #15454
justinco
justinco's Avatar
Drives: 2022 GR86
You would be surprised. Most new cars that I have detailed (I had a detailing side business for some time) usually need a mild polish to clear up dealer installed imperfections (swirls/scratches/poor dealer prep/etc).
This is especially important when applying a coating like he did.
justinco is offline   Reply With Quote
Old 04-18-2017, 02:02 AM   #15455
ztrevs
ztrevs's Avatar
Adding to that as well... I picked up my car around September last year.
Being that it is my daily, it ran it through all the salt/snow any my paint was pretty scratched up.
Like mentioned above, paint correction is super important and is pretty much essential for any type of coating/sealant. Opti-Coat Pro is a 2 stage correction process. First is the obvious polish and scratch removal where the second is the primer stage for the coating.
Old 04-18-2017, 04:51 AM   #15456
tomm.brz
Drives: brz 2017 hksv2
nice job with the paint correction and coating...
What I hate about my BRZ '17 is the crazy amount of orange peel
