Old 05-16-2014, 02:52 AM   #1653
xkwizt
Drives: 86 GT
Anyone using this kit in Australia?
xkwizt is offline   Reply With Quote
Old 05-16-2014, 03:55 PM   #1654
jordBLP1
Drives: Stock white BRZ
Did vex do the install too? My buddy has an evo x down there (red with carbon trunk and hood and gold wheels) but its been down there for a while now and I'm thinking it might be too close to summer if the wait times are this long.
jordBLP1 is offline   Reply With Quote
Old 05-16-2014, 04:06 PM   #1655
69Marshall69
69Marshall69's Avatar
Drives: 2013 Subaru BRZ-S
omg
Dude you're a life saver, it was exactly that man. The pipe came right off somehow when i was putting the front bumper back on. I couldnt even see it until i jacked it up and took the bottom plate off. I owe you one!
Dan
69Marshall69 is offline   Reply With Quote
Old 05-16-2014, 05:58 PM   #1656
mashal
DADA
mashal's Avatar
Drives: 2013
Yes vex did the install, I'll post final dyno numbers
mashal is offline   Reply With Quote
Old 05-17-2014, 12:12 AM   #1657
Howardwei
WALBRO 485 install manual NEEDED
Does anyone have the manual.. I thought the kit with adapter shouldn't need any drilling
Plz help!!!
Howardwei is offline   Reply With Quote
Old 05-17-2014, 12:13 AM   #1658
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
What?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 05-17-2014, 12:41 AM   #1659
mashal
DADA
mashal's Avatar
Drives: 2013
Plz help!!!
You shoulda got install instructions from FBM if that's what your looking for
Old 05-17-2014, 09:26 AM   #1660
The Slow One
Track Junkie
Drives: Argento Scion FR-S
@Howardwei and I have those instructions but it is vague on what to do to install the fuel pump assembly into the bucket. it is not anywhere near clipping in together.
we attached a photo with some circles to get a better idea, sorry for the poor phone editing skills lol
The Slow One is offline   Reply With Quote
Old 05-17-2014, 09:27 AM   #1661
The Slow One
Track Junkie
Also we have no idea what the big ring is for, I'm assuming it's a spacer that goes between that goes between the lip and the fuel pump assembly.
Old 05-17-2014, 09:54 AM   #1662
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Plz help!!!
The clips will not clip and that is fine. It was designed to not clip and not need any clamps holding it down. When you push down the whole canister into the tank, it will be steady.
Remember, the OEM design holds the FP inside the canister by the force applied on the clamps. FBM design holds the pump in place with the billet piece on the bottom.
The large metal ring goes all the way onto the top of the top canister cover on the bottom part of it. (see pic below). Note and make sure the rubber gasket that usually sits on the mentioned top cover needs to be removed for this. Also, the small rubber o ring on the metal ring needs to face up to the sky.
Good luck and let me know if you need anything else.
Old 05-17-2014, 02:47 PM   #1663
Howardwei
Thanks sports guys. Do you know if the cone like spring that came in with te electric fans cushion are there for a purpose? Where do they go? @Sportsguy83
Old 05-17-2014, 03:28 PM   #1664
Sportsguy83
Drives: Limited BRZ
I don't have FBM turbo kit but @King Tut might be able to help.
Sent from my SM-N900A using Tapatalk
Old 05-17-2014, 10:50 PM   #1665
Reaper
Reaper's Avatar
Drives: violent
Didnt use mine
Old 05-17-2014, 11:34 PM   #1666
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Is it necessary for no track use to run a fbm radiator and shroud in Texas?
Sorry if it's been asked but I couldn't find
I think it will be fine. The only issues might be in stop and go traffic where the slim fans can't push enough air through the radiator and A/C consdensor, but all other times you should be fine.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
