Old 07-30-2012, 07:51 PM   #155
Tujin
ALWAYS CONNECTED!!
Drives: 13 FR-S PINK 6MT
Originally Posted by vividracing View Post
Restrictive Muffler and cross pipe. The numbers are what they are. Each run has a list. No ECU tuning.
The AFR's are listed on the bottom black line. All was running very rich. Found nothing lean. A tune can lean out the fuel and and adjust other tables and make more power.
The torque will also come up on the header back as well after a tune.
Do you guys have plans to get tuning software anytime in the near future?
Tujin is offline   Reply With Quote
Old 07-30-2012, 07:52 PM   #156
vividracing
vividracing's Avatar
In the works yes..
vividracing is offline   Reply With Quote
Old 07-30-2012, 09:43 PM   #157
knapper
knapper's Avatar
Drives: '13 Scion FR-S - Whiteout
I still own my HKS twincharge AW11. 68k miles on the clocks. Going to be taking it out of storage here soon. Have a fully rebuilt small port motor for it.
This was my dream car when I was like 6 years old, I still remember the artcile in my dad's car magazine about it. Fuck me, I would kill to drive one. I had an NA AW11 as well, loved it so much.
knapper is offline   Reply With Quote
Old 07-30-2012, 10:46 PM   #158
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
PM'ed you with quote request for full system including pulley and takeda intake
clayrush is offline   Reply With Quote
Old 07-30-2012, 11:24 PM   #159
CBR600RR
Drives: Raven Black
Is it too much to ask to get a dyno run with just the CatBack and Pully???
To mee this combo seems like it might just be the best bang for the buck and still keep the car smogg legal.
Old 07-31-2012, 12:22 AM   #160
wootwoot
Drives: FRS
I would like to see this combo as well. Cat back+pulley and Header-back+pulley. This is what I will most likely go with at first. Adding the tune and the head further down the road maybe.
wootwoot is offline   Reply With Quote
Old 07-31-2012, 01:28 AM   #161
E92M3Guy
Drives: BMW E92 M3
Originally Posted by SkullWorks View Post
There is alot of DYNO MYTH being spread in this thread for some reason.
there is no skill, REPEAT THERE IS NO SKILL!!! in making a dyno pull, outside of minimizing the temp/humidity/airflow and engine operating temps, there is nothing you can do OR THAT AN OPERATOR SHOULD DO to make runs repeatable. end of story, you get the car rolling on the dyno to desired gear/rpm, start sampling, hold pedal to floor. there is no driver competency involved in making a power pull on the dyno, anyone who tells you otherwise is blowing smoke or running a janky engine or dyno.
in regards to an earlier post about inirtial dyno's "guessing" at HP numbers...this stuff makes my blood boil, do you even understand what horsepower is? it is a measure of work done vs time, accelerating a known mass is the most direct way to measure that. if anything, a load bearing dyno is a guess, it relies on calibrations to approximate the load being generated, which varies greatly based on type of resistance/load etc.
Out of respect for the OP, I'd prefer to have this discussion in a different thread about dynos. When I start the official dyno database thread, maybe that would be a good place to discuss it.
E92M3Guy is offline   Reply With Quote
Old 07-31-2012, 04:16 PM   #162
EZWood
BAMF
EZWood's Avatar
Here is one of the Dyno runs. I think it's the second run with the full exhaust and pulley.<object width="400" height="240" ><param name="allowfullscreen" value="true" /><param name="movie" value="http://www.facebook.com/v/451566588208184" /><embed src="http://www.facebook.com/v/451566588208184" type="application/x-shockwave-flash" allowfullscreen="true" width="400" height="240"></embed></object>
Oops. Looks like its not working. I uploaded to YouTube from my phone. I will try to e mail it to my computer and upload it from there. Sorry guys
Old 07-31-2012, 05:03 PM   #163
Opposed
Drives: 2013 Asphalt FR-S
How does the car fell overall EZ? Im use to putting N/A bolton's on my old S2k and couldnt really tell much difference. Is the drivability and overall performance noticable while daily driving as it looks on paper?
Opposed is offline   Reply With Quote
Old 07-31-2012, 05:12 PM   #164
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
please people if you don't know what you are talking about don't "school" people,
and vivid Great job on the break down but
1. don't feed the trolls
2. shame on you for feeding the poor understanding of dynos, Jason may be the nicest guy in the world but when he is "driving on the dyno" his only function in life should be that of a brick in relation to the throttle pedal...give credit where it is due, and accept it under the same circumstances.
RandomHero is offline   Reply With Quote
Old 07-31-2012, 05:27 PM   #165
xcelir8brz
Drives: 2013 BRZ Limited
VERY GOOD POST! THANK YOU!
xcelir8brz is offline   Reply With Quote
Old 07-31-2012, 05:36 PM   #166
SkullWorks
Drives: SSM LT MT BRZ
That is all well and good however.
1.) the mods will delete if they see a problem (and there is no problem with what/how I posted)
2.) it is relevant here. (unlike your comment) last thing we need is for people to start bench racing their dyno operators...ala....my dyno operator makes smoother plots than your dyno operator, or XXXsmitty at XYZ dyno sucks he never gets the same HP as Johnny57...we have alot of noobs here, I'd prefer if they had the ability to sort the flyshit from the pepper and didn't get led astray.
SkullWorks is offline   Reply With Quote
Old 07-31-2012, 05:57 PM   #167
EZWood
BAMF
EZWood's Avatar
The acceleration and throttle response have improved. I haven't had much time to drive it. I've put probably two hundred miles on the car with the parts. The part I like the most is that it is easier to get the rear tires to break loose. I can't wait for an intake and a tune for this thing. I think it just might hold me off till cams and valve springs are available.
Old 07-31-2012, 06:22 PM   #168
Opposed
Fantastic! So it does "pull" harder then...that is good to hear. Thanks for the input.
Agency Power Exhaust vividracing Engine, Exhaust, Bolt-Ons 17 07-23-2012 03:40 PM
Agency Power (headers) Polo Engine, Exhaust, Transmission 1 07-21-2012 07:27 PM
Enjuku Racing - Agency Power - New Products Released Enjuku Racing Engine, Exhaust, Bolt-Ons 0 07-16-2012 05:46 PM
FRS on a heartbreaker dyno (Vivid Racing car) Lonewolf FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 06-14-2012 07:29 AM
