View Poll Results: Are you experiencing the same problem?
Yes - I have an aftermarket intake only. 14 9.21%
Yes - I have an aftermarket intake and a tune. 15 9.87%
Yes - I'm all stock. 11 7.24%
No - I have an aftermarket intake only. 43 28.29%
No - I have an aftermarket intake and a tune. 3 1.97%
No - I'm all stock. 66 43.42%
Voters: 152. You may not vote on this poll
Old 09-04-2012, 02:08 PM   #155
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
it is a very short install..do it, see what happens! You will probably be very happy with it.
Originally Posted by pdreams View Post
My AIRAID intake should be coming in within the next few days and now I am hesitant to install it over the weekend.
Reading back on the development thread for this intake, there was good consideration on the MAF location. Also, the AFR readings layered the stock intake AFR well also. I would think AIRAID did not experience any of the MAF issues before they went to mass fabrication.
This is really puzzling.
Having said that there is a 30day money back guarantee so its pretty straightforward to go on from there.
Old 09-04-2012, 02:10 PM   #156
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Wasn't making my post in response to your there 2forme just sharing my exp so far with intakes and bogging. After watching the video I can understand why you would be pissed. I wouldn't blame Airaid tho as if this is happening with other intakes as well as apparently to stock cars it sounds like a design flaw or something but i'm no expert. I wish you the best in finding a resolution to the issue tho that loss unbearable to me.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 09-04-2012, 02:22 PM   #157
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by 2forme View Post
David, maybe you didn't understand what MY experience is with YOUR product. You seem to want to assign accountability elsewhere. Let me break this down for you.
1) My car ran perfect prior to YOUR intake. Never had a bog or single issue. Regardless of what tune or mod I threw on.
2) I added YOUR intake while on the e85 tune. Bogging.
3) I swapped back to stock intake on the e85 tune. No Issues.
4) I swapped back to YOUR intake and changed back to the stock tune. Bogging.
5) I swapped to Viscontis 1.02 tune while on YOUR intake. Bogging.
So to recap:
Tune + Stock Intake = Fine
Stock Tune + Stock Intake = Fine
Tune + AIRAID Intake = Problems
Stock Tune + AIRAID Intake = Problems
Do you see a common denominator in that scenario? The problems are there and VERY real. In case you missed my prior post. Here's a recap:
So tell me, is this normal STOCK TUNE behavior that the car should exhibit? Don't tell me where my problems lie. I'm not stupid. And I'm not accepting your offer unless I can get a guarantee from @AJUSA.com that I'll be eligible for a FULL REFUND after you spend a couple weeks shipping, examining, and shipping again....should the problem still be there.
And if you're so sure, explain to me why YOUR BOSS sent Visctoni a free intake to try and fix the problem?
+1 I'm seeing the exact same thing with my Injen intake. I've approached the vendor regarding a refund. We'll see how it goes...
Old 09-04-2012, 02:26 PM   #158
AIRAID
AIRAID's Avatar
This is very simple. So Mr. Visconti can Test and write a proper Tune for use with the AIRAID Intake, not to "Fix the Problem".
He also stated he would be testing other Intake's to possibly write tunes for those as well. This is not some big conspiracy, it's actually very normal in the performance world.
Thanks,
David
AIRAID is offline   Reply With Quote
Old 09-04-2012, 02:38 PM   #159
Visconti
Drives: 05 STi
Thanks,
David
Strange - I had a very different conversation with Brian.
The intake was sent to see what the car was doing and why it was doing it.
John
Visconti is offline   Reply With Quote
Old 09-04-2012, 02:39 PM   #160
2forme
Originally Posted by SkAsphalt View Post
Could it not be your air sensor and the way you are installing it into the Airraid intake is causing the problem?
There is only one way to install it. The mounting only works in one direction. Besides, I've swapped the intakes a few times now. It's been a consistent problem each time. :-/
Old 09-04-2012, 02:59 PM   #161
t14abrunson
Drives: 2009 STi
It also looks like The Shop is the only tune that doesn't alleviate the dip.
The bog isn't related to the tune, it's related to the intake. I get the same bog with a stock tune.
Dip is not an issue, will be taken care of soon according to Jimmy. If the tune is not the issue why is he not experiencing any bogs on the multiple FT86's they have tuned? Bog was there before the tune, wasn't after.
A step at a time guys, the cars are only a few months old. With a dual injection setup, unfortunately almost all mods are going to be beneficial with a correct tune. The days of just slapping parts on are over in my opinion.
t14abrunson is offline   Reply With Quote
Old 09-04-2012, 03:04 PM   #162
2forme
Originally Posted by t14abrunson View Post
Dip is not an issue, will be taken care of soon according to Jimmy. .
@Visconti has already gotten rid of 90% of the dip. You should talk to him about how to fix it . Dude knows his stuff....
Old 09-04-2012, 03:24 PM   #163
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
I hope it doesn't come to that. I'm fairly sure that between John and Injen/AIRAID solutions can be found.
Symbiont is offline   Reply With Quote
Old 09-04-2012, 03:28 PM   #164
AJUSA.com
AJUSA.com's Avatar
Do you have a tune or no?
AJUSA.com is offline   Reply With Quote
Old 09-04-2012, 03:40 PM   #165
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
If there isn't a problem, why is a "proper" tune needed?
sho220 is offline   Reply With Quote
Old 09-04-2012, 04:38 PM   #166
AJUSA.com
AJUSA.com's Avatar
Simply: to maximize power output.
There are 30 trouble free users for every 1 user that says there is a bogging issue. Its not a common occurrence. We are working to find a solution, but its not the Airaid product specifically causing the issue.
If you look at the poll results (which do not represent every intake on the market) youll see there are more people experiencing bogging who are stock then those with an intake.
So based on those poll results, you could say the intake fixes the problem - we know this is not the case, but lets quit with the finger pointing and accusations instead lets all work to find a solution for the few of us who have run into less than favorable drive-ability.
Old 09-04-2012, 04:38 PM   #167
t14abrunson
Drives: 2009 STi
100% of the dip is a better end result correct? It will be taken care of.
Old 09-04-2012, 04:48 PM   #168
sho220
sho220's Avatar
Thanks for the info. Is there a thread about the bogging issue with all stock setup? This is the first I've heard of that. Guess I have some work to do...
engine bogging, hesitation, intake, jerking motion
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 09:06 PM
aftermarket rubber intake tubing??? 20valvewynn83 Southern California 39 09-14-2012 12:12 AM
Can anyone read Dutch? Buggy51 BRZ First-Gen (2012+) — General Topics 14 12-28-2011 10:48 PM
Toyota READ THIS Mr.Jay Off-Topic Lounge [WARNING: NO POLITICS] 1 12-09-2011 01:13 AM
