Old 06-03-2014, 01:47 PM   #1779
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
Drives: '13 Asphalt FRS MT
My downpipe was ceramic coated and heat wrapped, and my slim fans also worked fine for over 15,000 miles.
sweet, thanks for the reassurance bro . I plan on getting this done with my kit when i purchase it.
FRS_FIEND is offline   Reply With Quote
Old 06-03-2014, 01:57 PM   #1780
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Reaper View Post
I burned up my slim fans and now have the oem fans in. I have 2 pieces of aluminum wrap on the upper support bar as seen in the pic.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I tagged you in a post in the Southeast section, go and check it out. I am interested in your response. It's about OBD2 inspection in GA.
Old 06-03-2014, 02:34 PM   #1781
xwd
Originally Posted by xDBOYx View Post
for the guys with the spal upgraded fans.. what did you guys do at the connector? did you cut the spal connectors and the oem connectors and just wire them up?
i want it to be as plug and play as possible... but looks like getting oem connectors is impossible.
@FullBlown what about the shop car?
Some had mentioned pulling the pins out of the slim fan connector and just sticking them in the stock plug and wrapping it up with electrical tape. I'll probably end up cutting off both connectors and using some Weatherpak ones, and just keeping the stock plugs around to put back on if need be.
Old 06-03-2014, 02:37 PM   #1782
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Someone buy my slicks!!!!!!
I love boost!!!!!!
Old 06-03-2014, 06:59 PM   #1783
carlossanchez89
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
Originally Posted by blackfireball5 View Post
I'd be interested to see what you did.
I'll take pics later today and post up.
carlossanchez89 is offline   Reply With Quote
Old 06-04-2014, 10:07 PM   #1784
dabocx
dabocx's Avatar
Drives: Scion FRS
On e85 how far can I push the gtx30 on the stock block? Currently doing 370whp at 15psi with a gtx28 but I want more...
dabocx is offline   Reply With Quote
Old 06-04-2014, 10:39 PM   #1785
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
@dabocx I made 450whp and 373 wtq on a gtx28. Ive seen the gtx30 to over 520whp but it made less wtq than me and bew up.
Old 06-04-2014, 11:04 PM   #1786
Sportsguy83
Drives: Limited BRZ
I made 548 whp and 471 wtq @19 psi GTX3076R.
496 whp 383 wtq @ 17 psi
439 whp cant remember the torque @ 14 psi
It's a different kit than FBM but can expect similar.
Old 06-05-2014, 12:14 AM   #1787
dabocx
dabocx's Avatar
Drives: Scion FRS
That sounds horribly tempting, I really wonder how long the motor could take that.
If anything ill do it and start saving for a built motor on the side
Old 06-05-2014, 12:20 AM   #1788
Sportsguy83
Drives: Limited BRZ
I fear for the transmission at 471 wtq. Only run the 496 whp map occasionally.
Sent from my SM-N900A using Tapatalk
Old 06-05-2014, 12:28 AM   #1789
Reaper
Reaper's Avatar
Drives: violent
Why are people so quick to dump the gtx28 on street cars? Im at 373wtq right now at 17psi. The gtx30 is great but without a tranny and rods it seems like a waste. The gtx28 is ment to be a 450whp turbo which is about all I'm comfortable with on this bottom and and drivetrain and produces awsome wtq. Yes I'm getting a gtx30 or maybe a 35 someday but not until I replace a lot of things first.
Old 06-05-2014, 01:20 AM   #1790
sw20kosh
Drives: 2013 Black FR-S
It is pretty incredible how much more headroom E85 gives over pump gas.
I am limited to 280 whp on 91 pump on the GT3076R while you are having to de-tune down from 550 whp. lol that's like almost double the power.
Old 06-05-2014, 01:39 AM   #1791
Sportsguy83
Drives: Limited BRZ
I agree with you mostly, but when the gt30 behaves so good on low boost and then will give you the head room when built for 600+ whp why not go straight to it and skip the hassle/cost of having to upgrade down the line.
I do believe if money is not an issue at all your plan is very solid and has some benefits over my do it once approach.
Old 06-05-2014, 01:48 AM   #1792
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
You guys ARE CRAYCRAY! lol all this HP and PSI and you want more and im over here like i just want 290whp. I Guess maybe at one point you guys were only wanting that much whp too! lmao
BOOST=ADDICTION ?
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
