| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#169 | |
Drives: '23 BRZ
FA24: 20% more displacement with bigger bore at same stroke. F22C: 10% more displacement with increased stroke, same bore. FA24: peak power rpm unchanged. F22C: peak power rpm dropped 500rpm. FA24: slightly higher redline. F22C: redline dropped 1000rpm ("only" 700rpm for rev limiter tho) F22C was a big disappointment for me. Don't hate it, but it was an almost pointless exercise IMO. If I had one 1st thing I'd do is reflash for lower-rpm VTEC engagement and 8500 rev limit... They did make about 10rwhp more than the F20C (~205 vs. ~195), but are hampered by narrow 6000-8000 VTEC range and lack of usable rpm headroom above peak power rpm. The AP1/F20C and AP2/F22C cars put up similar acceleration numbers. FA24 is going to be significantly quicker/faster than FA20... There look to be ZERO downsides to the FA24 vs. FA20. +23hp and ~20% more torque throughout the range. I *wish* Honda had taken the same approach with the F22C! Last edited by ZDan; 12-05-2020 at 11:15 AM. |
#170 | |
You have fixated on one point that I was trying to establish early on and disregarded everything I have said beyond that. I will put it all in one spot: 1/ He was very clear that he felt that the graph was a real life number. He stated outright that it "was taken from the test mule". This is not accurate nor even remotely true. It is a laboratory formed number based upon a bench tested engine with many correction factors applied. 2/ It was his contention that the graph was a fully accurate indication of the engine abilities. I went into the fact that it is not dynamic as part of my attempt to clarify that what that gauge shows on the dash is not in fact what the car is actually doing. Even at the crank you will not see those numbers unless you meet the absolutely ideal conditions under which they were calculated. When driving the gauge follows the graph perfectly and that is nearly impossible. This is why I focused on the fact it is not dynamic and a false impression of the cars true performance. It is not my only point it is but part of the whole picture. 3/ In true paper racer form he insists on using only those two number to establish what the performance of the car will be. As pointed out many, many times by several people other than just myself there is far more involved. Something as simple as some more conservative gearing especially in the final drive could easily negate the 15% increase in power and torque. We have no idea what the rest of the specs are yet and it s possible (not probable but still possible) that the true performance of the car will be no better than the first gen. Yes there is some nice low end torque according to that pretty graph but how well does the overall car use that? Did they have to compromise something else to get it? 4/ His very thread title says "where will it sit?" but as soon as anybody tries to say anything other than oh it is perfect he throws some random bullshit into the ring to counter them. If the question was rhetorical and he has already determined from the HP and torque that it is THE greatest then why pose it? Everybody that says wait and see or tries to provide facts is somehow a "fool", "troll" or "not sane" in his eyes. Yes I like a good debate with facts, and data used to support a position but when these things are totally disregarded then it is no longer a debate and just turns into a brawl. He has repeatedly resorted to insults and name calling which right away tells me he doesn't have a real point to make and just hopes I will go away so he can find fellow believers to join him in his circle jerk. At this point I don't give a flying fuck what he or you think about what I have tried to get across in this thread but there have been over 5,000 views of this thread and if just one person walked away and said "that makes sense" then I am content.
#171 |
Drives: Crapcan
My mistake. I thought the rev limit was decreased.
#172 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
What chew talkin bout Willis?
"I gotta rock." -- Charley Brown |
#173 | |
Drives: '23 BRZ
I'm *guessing* they'll go with something like 5% to maybe 10% taller overall gearing, which would be equivalent to either 4.1 or 3.9 with existing transmission ratios. Although they might widen transmission ratios (kinda hope not). ANYway, here's what torque to the wheels vs. speed should look like '22 with different ratios vs. '17: Last edited by ZDan; 12-05-2020 at 01:15 PM. |
#174 | |
Drives: '23 BRZ
#175 | |
#176 |
Drives: Crapcan
![]() Sent from my iPhone using Tapatalk
#177 |
Drives: '23 BRZ
Yeah, not gonna know for sure until we get one on a dyno... I'm *assuming* the curve shown in the dash graphic is accurate as far as the shape of the hp curve, based on the accuracy of the dash graphic in my car, where the torque dip is proudly displayed!
#178 |
The Dictater
Drives: '13 Red Scion FRS
I bet that there are going to be aftermarket solutions for the FA24 which add a bit of top end power but also a torque dip. And then torque dip will suddenly be cool.
#179 | |
Drives: Crapcan
There is a “ chips and dip” joke in there somewhere. Sent from my iPhone using Tapatalk
#180 |
Drives: 2017 Toyota 86 (860 SE)
#181 |
Three actually. There was another one in between!
Although it proves there is indeed a replacement for displacement.
#182 | |
I wasn’t suggesting lowering the redline was something they would do. The AP2 lowering the redline was my only reference to redlines. The FA24 is bored more to get the extra displacement so it has the same piston speeds but more valve surface so theoretically it could run a higher redline. If you follow threads about oil pressure on the FA20, larger pumps never solved the problem. The fixes came in the form of changing oil galleries. Boring some and even tapping in secondary lines. I wouldn’t be surprised if Subaru made some oiling improvements on the FA24 but time will tell. At least they added an oil cooler. Oil pressure isn’t too much of an issue until the temps get high so maybe that is why Subaru never addressed it. It’s a popular track car but still probably represents a very small fraction of their user base. |
| How to get that classic high-pitch 4cyl sound from brz? | yEEt42069 | Engine, Exhaust, Transmission | 45 | 04-08-2020 12:51 PM |
| i just realized... 2016 turbo 4cyl CAMARO vs FRS/BRZ | Shinchu | FR-S / BRZ vs.... | 98 | 09-28-2015 04:18 PM |
| COMPLETE OEM engine harness! Great for tuck | Nizz300Ft86 | Audio/Visual, Electronics, Infotainment, NAV | 2 | 03-13-2014 01:23 PM |
| COMPLETE OEM engine harness! Great for tuck | Nizz300Ft86 | Engine, Exhaust, Bolt-Ons | 0 | 11-25-2013 06:19 PM |
| MPG of a 600hp 4cyl. Engine | chuttney1 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 03-15-2012 10:06 PM |
