Old 12-29-2017, 05:16 PM   #169
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Originally Posted by DarkSideFRS View Post
thanks! one post I read said that he was able to slide a cardboard between the perch and rims, but did not state how much camber he was running.
do u know which hubcentric ring I can buy?
It was super tight between the shock and the wheel on my car, probably less than 5mm but keep in mind, that was the 9.5" wheel.
You can get the hubcentric rings anywhere these wheels are sold at.
PERRIN_Chris is offline   Reply With Quote
Old 12-29-2017, 06:16 PM   #170
KryptoNate
KryptoNate's Avatar
Drives: '14 Asphalt FR-S
couple questions for ppl running this setup...
1. Do you need hubcentric rings?
2. for those dropped 1" on springs, running 245/40 tires and run significant camber (I am at -1.7), will you hit the spring perch? I know it is very close, but a lot of posts I see saying that it will fit with no rubbing does not specify the amount of camber they are running.
1. Get hubcentric rings. I got mine from the place I bought my wheels.
2. If you are running stock struts, the spacing to your spring perch will not change with lowering. Lowering will just reduce your clearances to the fenders, wheel wells, etc.
That being said I have 57DRs in 17x9 +38, running 245/40R17 Firehawk Indy 500s. I have stock spring/strut combo with SPC camber bolts in the top strut hole at around -1.4 degrees. If I recall the clearance is around a centimeter. (See picture)
Keep in mind different tires have slightly difference side profiles, so clearances can vary.
Sent from my SM-J510MN using Tapatalk
KryptoNate is offline   Reply With Quote
Old 12-29-2017, 06:16 PM   #171
DarkSideFRS
Drives: 2013 pearl white FR-S
i'm buying used, so gonna source the rings elsewhere
the 5mm clearance was with natural camber, correct? that should be around -1.0?
DarkSideFRS is offline   Reply With Quote
Old 12-29-2017, 06:22 PM   #172
DarkSideFRS
this was very helpful. looks like i'll be a lil more closer to the perch as my camber is slightly more... gonna be close!
Old 12-29-2017, 07:39 PM   #173
KryptoNate
KryptoNate's Avatar
No problem, man. It will be close, but I think you should be fine.
This thread helped me decide on wheels, so I will post my setup.
- Gramlights 57DR 17x9 +38 in Gunblue
- 245/40R17 Firehawk Indy 500
- Stock suspension
- SPC front camber bolts
- Camber: -1.4F, -1.2R
- Toe: 0F, 0R
I have daily driven this setup for the past year with absolutely no rubbing issues.
Old 01-09-2018, 01:59 AM   #174
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
- Stock suspension
- Toe: 0F, 0R
Thank. I wondered if 17 x 9 with 38 offset would fit stock suspension or not.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 04-01-2018, 12:38 PM   #175
TheLowlyThird
Drives: '17 Toyota 86
Went from 18x9.5 +38 RPF1`s to these 17x9 +38 57DR's. The car still feels great, but I feel it's not nearly as planted as it was on my previous setup. Still pleased! Moving up to 255/40's next go 'round.
Stats/Specs:
17x9 +38 Rays 57DR
245/40R17 Toyo Extensa HP
Lowered roughly 2"
Front: -2.2/Rear: -2.3
Tein Flex Z's
Voodoo13 Rear LCA's
Lots of other little suspension bits
TheLowlyThird is offline   Reply With Quote
Old 07-06-2018, 02:16 PM   #176
DarkSideFRS
quick question... did u guys swap out your oem tpms over to the 57dr?
Old 07-07-2018, 09:26 AM   #177
KryptoNate
KryptoNate's Avatar
I bought new TPMS sensors from Tire Rack. I still use my OE wheels for winter and switch codes with the Ateq Quickset.
As far as I know, there shouldn't be a problem using the OE sensors on these wheels.
Old 07-17-2018, 01:08 PM   #178
DarkSideFRS
got them on yesterday... dialed in my camber to -1.4F and -1.2R... would have kept them at -1.7F and -1.3R tho... btw, the fronts WILL fit with -1.7 camber up front on stock struts and TRD springs... there was abt 3mm clearance from the strut perch
Old 12-07-2021, 03:43 AM   #179
tc3191
tc3191's Avatar
Drives: 2019 BRZ Limited
57DR 17x9 + 38mm
Hankook Ventus Rs4 245/40/17
Tein Flex Z
Camber 3.2F/2.0R
tc3191 is offline   Reply With Quote
Old 12-07-2021, 08:07 PM   #180
buruguduy
Drives: 2013 Scion FRS
17x9 +38
Semi gloss black
Michelin pilot sports as4
Tein flex z
Camber fr -1.1
Camber rr -1.5
O toe
buruguduy is offline   Reply With Quote
fit, oem tires, rims
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 WorkoArt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-18-2017 07:46 PM
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 12-04-2014 11:56 PM
Gram Lights 57DR - 17x9+38 in Gun Blue 00vsmcoupe Wheels and Tires 17 01-08-2014 09:02 AM
WTB Gram Lights 57DR 17x9 +38 in Gun Blue or Enkei RPF1 18x9.5 +38 in SBC Shiro86 Want-To-Buy Requests 2 11-08-2013 11:18 AM
