Old 05-18-2014, 04:56 PM   #169
Shit Luck
Drives: red frs
Originally Posted by nelsmar View Post
Flex fuel and pump / injecors!
Well I have only a few e85 pumps in my area. I have 93 and 100 readily available...
I would prefer not having to switch maps all the time.
I will do both eventually I am just trying not to spend a fortune prior to spending a fortune to get tuned.
Shit Luck is offline   Reply With Quote
Old 05-18-2014, 05:54 PM   #170
Kdej1
Colten Drew
Kdej1's Avatar
Drives: '13 Fr-s // '95 Civic // '09 Vette
Colten! Text me I'll take you for a drive and I think you'll make your decision right then.
Totally down.. Jason tells me you'll convince me to build/turbo mine..
I wanna ride by your side one of these dark lonely nights
Kdej1 is offline   Reply With Quote
Old 05-18-2014, 07:11 PM   #171
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
If @nelsmar can't get you a ride I'd be glad to give you one in my car. This thing on my higher boost setting pulls about as hard as my Evo did when it made 550whp. Funny thing is if I want more I can strap it back on for a few more hrs and make some really stupid numbers. I have a feeling I will run out of injector before I can maximize this turbo.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 05-18-2014, 07:18 PM   #172
nelsmar
Personally I just blend my fuel... I tuned my car using a flex fuel setup and i typically run E40-E70. I just run some ethanol to cool it down. I make more power than I can possibly put onto the pavement so the extra power at this point is just not a bit deal past E40 for me. I just put whatever in at the time and typically fill all the way up if I'm at an ethanol station, and then if I know i wont be getting ethanol I fill up on gasoline when I'm at 1/2 a tank and that ethanol gets stretched to last a long while.
The only reason to upgrade your injectors is if you are maxing yours out and it is limiting you. If you go flex fuel you will likely need new injectors to handle the extra flow required for ethanol.
My flickr - Canibeat
Local magazine scout
Old 05-18-2014, 10:15 PM   #173
Shit Luck
Drives: red frs
so for maxing out on 93 octane you think I should just stick with the stock fuel system?
Old 05-18-2014, 11:36 PM   #174
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Mines like driving on ice now too haha
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 05-18-2014, 11:54 PM   #175
evo4g63
evo4g63's Avatar
Spinning is winning in our case. If it were to hook real good axles would be needed ASAP. I am actually thinking of buying a set of DSS anyways.
-2016 Subaru WRX
Old 05-19-2014, 12:13 AM   #176
AZFA20
AZFA20's Avatar
That's one of my next investments as well
Got my intake tube back from powder coating.
Old 05-19-2014, 03:13 AM   #177
nelsmar
Yup you should be fine. What are your power goals?
Old 05-19-2014, 03:14 AM   #178
nelsmar
Fuck it. Stay on slippery tires and just have stupid fun EVERYWHERE! Haha
Old 05-19-2014, 06:48 AM   #179
steveoexige
Drives: UK GT86 in White with alcantara
Guys, my tuner has just gone to fit the FBM 485 pump kit and is concerned as it doesnt seem to fit properly. It just seem to float around in the bottom of the tank (his words). Any suggestions or a link to some install instructions ? Just like my JDL turbo kit FBM didnt ship their pump kit with any instructions
Few other things:
The JDL exhaust doesnt reach to the pipe work after the turbo (could it be because my header didn't fit properly and is causing other issues further down the exhaust line so to speak??).
I still haven't received any water fittings for the turbo.
The 3 inch over/front pipe doesnt fit and is having a crease put in it later today (just as we had to do with the header as it was hitting the engine block).
I cant expect my installer to keep pushing my car around getting it in and out their workshop every other day. Fuck knows what my labour bill is going to be, car isnt even close to getting on the dyno yet. Anymore grief and I can see the lot coming off and going back to Phoenix in a big box at this rate.
Some support would help. Jesse are you there? I've sent a few emails and no reply....
steveoexige is offline   Reply With Quote
Old 05-19-2014, 10:21 AM   #180
diss7
Drives: AE86, 2x GT86, TE27
Steve, just to let you know that I've experienced the same thing.
First it was the flanges, no instructions either (hey it only goes together one way, but would still have saved time) insides of pipes not finished properly. All pipes and IC end tanks full of 'flack'. Air intake pipe fouls on headlight plug, needed adjustment. Overpipe touching head (although I accept I had the first rhd one and was seeing if it was going to fit) but it wasn't my steering column causing the issue. No turbo coolant lines or fittings (were these apart of the kit, I would have thought so. If not, it should be made clearer.) . My installer didn't like how the downpipe sat, (had to force it to me the turbo) so while the flanges were being changes, he has added about 5mm to the top of the pipe. So lots of little niggley things. Just gotten sick of coming back here and updating.
I'm over it too, so don't worry. I'm just lucky I have a fabricator at my disposal. Between him and my mechanic I've just told them to do what they need to do make it perfect. Am taking photos of all the issues. Lots on my fb page. Otherwise I'll put them all up in one post when I do a review once it's all on.
Kit is still decent. It's just not the absolute premium this forum has made it out to be.
I'd hate to think what others are going through with some of the other junk kits.
Maybe I'm too fussy. I don't think so.
All the stopping and starting, fiddling, adjusting, it eats up so much time. Time I'm going to get billed.
Pay to play I guess. The point I want to stress is that if you're considering this kit, there is still fiddle work, tidying, finishing, adjusting. Time. Money. It's not a "install in your garage with minimal tools in a few hours" certainly not based on my experience so far. Although I'd like to think these issues lead to better kits for others moving forward.
diss7 is offline   Reply With Quote
Old 05-19-2014, 11:09 AM   #181
Shit Luck
Drives: red frs
I am trying to break 300whp for sure. I will take whatever I can get with safe numbers... lol
Old 05-19-2014, 11:21 AM   #182
steveoexige
Yeah unfortunately I don't have a fabricator in my phone book and tbh had I thought this kit needed one I'd have gone elsewhere.
It's crystal clear my actual kit and exhaust (in gtx config) was not mated up and test fitted before being shipped. It It would have been good if this could have been done knowing that I'm thousands of miles away.
MAPerformance turbo kit thread! MAPerformance Forced Induction 277 02-14-2023 03:49 PM
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 04:55 PM
All TURBO kits compilation thread subatoy Forced Induction 112 04-10-2015 10:14 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
Synack Turbo Drift/Drag/Road Thread Synack Tracking / Autocross / HPDE / Drifting 5 09-20-2012 02:20 AM
