Old 06-20-2014, 02:33 AM   #1835
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Could this be causing a p0441 error code and full boost cut at 4k?
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 06-20-2014, 09:53 AM   #1836
pleong
Drives: 2013 Whiteout FR-S
Here's a quick clip of my setup.. One of the techs took this video for me.. It's a moddified FBM Base kit. I had a custom straight pipe made, no cats, no resonators, with 5" exhaust tips. Right now as it sits it's making 325whp on a mustang dyno on e85. I'll post up more when I pick it up today.
[ame]http://youtu.be/GvYTeXwP788[/ame]
pleong is offline   Reply With Quote
Old 06-20-2014, 10:00 AM   #1837
blackfireball5
Last night I was not able to build boost, it would just cut atc4k. This morning car drives normal and can build boost. What would cause that?
Wheelwell Profile
Old 06-20-2014, 10:11 AM   #1838
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
325 on e85? Is something wrong?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 06-20-2014, 10:12 AM   #1839
pleong
It's a mustang dyno.. Reads lower and I've heard this particular one seems to read lower than other mustangs but it's only at 10psi I believe
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
Old 06-20-2014, 10:19 AM   #1840
Reaper
Reaper's Avatar
Drives: violent
I looked up specifics on the mustang dyno your right. My bad. 10psi is still conservative on e85. How loud is that exhaust?
Old 06-20-2014, 11:11 AM   #1841
pleong
Yeah my tuner is pretty conservative when it comes to tunes. I'll drive around for a bit and see how I like it. If I want more, I'll probably contact Delicious Tuning and get a remote tune.
Honestly I haven't even heard it in person yet. I'll let you know tonight when I pick it up.. I had it done and the tune all at the same time.
From what the tech tells me is it has a nice deep tone at idle but it's loud AF at wot, which is expected with no restrictions... It's not my dd so I'm ok with it being loud
Old 06-20-2014, 01:45 PM   #1842
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Hard to say without more information. Next time it happens try to datalog it with EcuTek.
Old 06-20-2014, 01:49 PM   #1843
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You got a fuel surge tank? You gonna be tracking it?
Old 06-20-2014, 01:50 PM   #1844
pleong
Yes and yes
Old 06-20-2014, 02:05 PM   #1845
blackfireball5
Yeah, I will.
Old 06-20-2014, 03:29 PM   #1846
69Marshall69
69Marshall69's Avatar
Drives: 2013 Subaru BRZ-S
BOV inquiries
If your BOV doesn't open up at all when you shift, then there is something wrong with it.
Hey, just wanted to ask again about the BOV setup for the FBM kit. i picked up the kit from a buddy in NY a while back and found that there is a 13lb(brown) spring inside the BOV. At full boost my BOV doesnt release, creating the "gobbling sound" instead of the norm. Now as little as this affects the actual performance of the car, I hate the noise lol. I wonder if this is actually the normal setup for the FB kit or not. I tried a 9 lb spring, which obviously was too soft and stayed open at idle causing the car to idle badly. Are these cars set up to actually use the BOV properly or is there more i need for the kit other than a proper spring to have the BOV to release like its supposed to.
cheers
69Marshall69 is offline   Reply With Quote
Old 06-20-2014, 03:35 PM   #1847
King Tut
NASA SpecE30 Racer
King Tut's Avatar
cheers
I would say the correct spring is an 11 or 12 psi spring. I ended up most happy with an 11 psi spring and a couple aluminum washers I got from McMaster Carr. This will vary slightly depending on how much vaccum your car pulls at idle and where/how you are getting the vacuum/boost reference that you are running to the BOV.
Old 06-20-2014, 04:01 PM   #1848
mike the snake
Does the BOV spring pressure need to be changed when running higher boost?
Or is it more about how much vacum you have at idle?
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
