Old 07-31-2014, 01:11 AM   #1849
Jcl
Drives: 2014 BRZ
Anyone have problems with the car not holding idle after kws map?
Jcl is offline   Reply With Quote
Old 07-31-2014, 02:19 AM   #1850
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Did you change the map sensor to the KW map sensor and not the denso one that originally came with kit?
mit_peid is offline   Reply With Quote
Old 07-31-2014, 06:20 AM   #1851
zERoTu
Drives: 1st RBv2 10 Series FRS
I have same problem too. And there is a kw map sensor? I got the denso one.
zERoTu is offline   Reply With Quote
Old 07-31-2014, 10:38 AM   #1852
Jcl
Drives: 2014 BRZ
This is what came with.
Old 07-31-2014, 02:30 PM   #1853
captain_jack
captain_jack's Avatar
That's the one included in the kit, it doesn't look like mine but I have an earlier kit. The newer kits have that one. I'd call them if it were me.
Old 07-31-2014, 09:21 PM   #1854
Jcl
Drives: 2014 BRZ
Thanks to Joe @KraftWerks I am up and running. Looks like the map sensor they sent was a 2.5bar vs their regular ones.
Old 07-31-2014, 09:50 PM   #1855
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Glad we could help!
KraftWerks is offline   Reply With Quote
Old 07-31-2014, 11:48 PM   #1856
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Anyone have pics of the oil cooler kit installed? Thanks...
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 08-01-2014, 12:00 AM   #1857
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Kraftwerks Supercharger Owners Thread
Size:  249.7 KBName:  ImageUploadedByTapatalk1406861994.210667.jpg
That's all I got for now
If you need me to snap some more I can try
Also the instructions don't mention it, but clamp the ends of the lines. Otherwise lines will pop off....
Freeman is offline   Reply With Quote
Old 08-01-2014, 01:47 PM   #1858
KraftWerks
KraftWerks's Avatar
Originally Posted by Freeman View Post
Attachment 86727Attachment 86728
@Freeman - The line and fittings are rated to up to 250psi without a clamp. You should not have any issues with these while running without clamps.
Old 08-01-2014, 02:09 PM   #1859
Freeman
Freeman's Avatar
And according to the instructions the lines and fittings are supposed to come pre-assembled. Mine weren't so I assembled myself. I should have put hose clamps on them, rookie mistake. Then this happened....
Attachment 86803Attachment 86804Attachment 86805Attachment 86806
... So I say again, good idea to put hose clamps on.
Old 08-01-2014, 07:18 PM   #1860
Calum
That Guy
Drives: 2013 asphalt FRS MT
The link is broken.
Old 08-01-2014, 09:05 PM   #1861
Key words.. "up to". Not "at least".
Old 08-01-2014, 09:31 PM   #1862
KraftWerks
KraftWerks's Avatar
We're not quite sure what your motor is referencing but the average pressure on one of these motors at operating temperature would be something like 80-105psi at a maximum? This would not come close to even an 'up to' rating.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
