Old 08-10-2020, 06:26 AM   #18607
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Got this. Now it's off to ceramic coating. Can't wait to finally install it
MrSkubi is offline   Reply With Quote
Old 08-10-2020, 08:04 AM   #18608
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
nice pipes.
flushed the clutch system with fresh fluid. it needed it.
thomasmryan is offline   Reply With Quote
Old 08-11-2020, 02:37 PM   #18609
N_Raged
Drives: 2019 BRZ Sport-Tech RS
New pads and fluid
N_Raged is offline   Reply With Quote
Old 08-15-2020, 03:56 PM   #18610
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Changed my rear brake pads after 52k miles. Man, I love how easy it is on the Brembos!
MS, CSCS, TSAC-F, CPT
Old 08-16-2020, 11:01 AM   #18611
JD001
JD001's Avatar
Drives: Subaru BRZ
Can you see the state of pads without taking the wheels?
Old 08-16-2020, 01:50 PM   #18612
weederr33
weederr33's Avatar
Actually yes! I can get a good idea of how low they are. If you peek at the top or bottom of the caliper you can see. Of course, not for the inside pad though.
Old 08-16-2020, 02:16 PM   #18613
JD001
JD001's Avatar
Drives: Subaru BRZ
Brilliant design!! It'd make quite a few forum members very happy..
Old 08-16-2020, 02:41 PM   #18614
weederr33
weederr33's Avatar
Brilliant design!! It'd make quiet a few forum members very happy..
Except 1 particular member who's name shall not be used. It's never good enough for them.
Old 08-17-2020, 08:06 PM   #18615
spike021
spike021's Avatar
I'm a software engineer that works with a lot of metrics, monitoring tools, and that sort of thing.
So lately I've gotten a bit tired of the 2017+ digital gauge cluster. As nice as the coolant temp/oil temp/battery voltage screen is, it reeeally sucks because it doesn't show exact numbers, and it turns monitoring your car vitals into a guessing-game, which isn't safe while in-motion.
While I do have an Ecutek Connect and a really nice app for it on my phone to make custom dashboards to monitor all kinds of metrics, I didn't really want to use that approach for full-time monitoring because it can be distracting if notifications pop up or if someone calls me, etc., since I have a work pagerduty app and all matters of things that can interrupt the screen.
So anyway, I wanted to start building out some additional monitoring that I can keep an eye on as needed.
I decided to go with a P3 gauge in the AC vent since I can connect it to my OBD for power/ground/data + 2 analog inputs if I ever want to do that, and it can present any data available from the ECU. So for now that'll give me my oil temp as an exact number, but also allow me to switch to other data if I'm so inclined.
I ordered that and should receive it this week; the install looks super easy.
After seeing @Ultramaroon and others mention it in threads that popped up while doing gauge/pod research I ordered a dash-vent block8head pod last night. And then I'll likely be ordering the Defi DF Red Racer N2 Pressure Gauge for oil pressure.
I was thinking about going with two regular gauges on the dash, but I think for now this should be enough, especially since the P3 can show multiple metrics.
I don't need to see _everything_ at once, and I'm only NA so no boost to keep track of so I figured that will all be sufficient!
I'll post when everything is installed! Or maybe the P3 first since that'll arrive first.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 08-17-2020, 08:44 PM   #18616
Chuckls
Moutain Runner
Powdercoated my wheels
Chuckls is offline   Reply With Quote
Old 08-18-2020, 12:41 AM   #18617
Ultramaroon
not playing cards
Ultramaroon's Avatar
You are going to love it. IMO, position and orientation are dead on.
Old 08-18-2020, 02:04 AM   #18618
spike021
spike021's Avatar
I'm excited!
Old 08-18-2020, 12:22 PM   #18619
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
Originally Posted by Kiske View Post
Spent the weekend prepping the ol' Turbo kit for sale. Just waiting on a couple of replacement silicone couplers to arrive. Hope it will bring just enough to let me finish my other engine build. :P
Attachment 191205
You have a buyer yet?
CincyJohn is offline   Reply With Quote
Old 08-18-2020, 03:26 PM   #18620
norcalpb
norcalpb's Avatar
Hit 150,000 miles and did a celebratory drive through car wash.
