Old 06-23-2014, 01:21 PM   #1863
Dipstik-sportech
Dipstik-sportech's Avatar
Try tapping the housing, couldn't hurt to make a dedicated line for the wastegate
The Frozen North
Old 06-23-2014, 02:30 PM   #1864
sw20kosh
Drives: 2013 Black FR-S
you can get into a situation where the car could stutter and possibly stall in those engine braking situations when you quickly stick the clutch in.
This used to happen all the time with my ptuning kit. Jamesm was able to tune most of it out so now i get a slight idle dip which is enough to cause the lights to dim every once in a while. We never considered it could be the BOV...hmmm
@jamesm
Old 06-23-2014, 02:59 PM   #1865
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
@jamesm
Nope. Your BOV is prior to the intercooler and won't cause any issues with flow across the MAF.
Old 06-25-2014, 12:27 PM   #1866
Dipstik-sportech
Full Blown Turbo BRZ - 11 second quarter mile: [ame]http://youtu.be/wyuB0CeMVi0[/ame]
The Frozen North
Old 06-26-2014, 02:35 PM   #1867
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Anyone have any issues with oil being blown out the breather tube? Took it to the track today and I'm getting a lot of oil coming out of the tube. Someone here said I need a PCV valve. I'm using a bottle to catch some of it. Name:  uploadfromtaptalk1403804122590.jpg
Suggestions?
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 06-26-2014, 03:30 PM   #1868
Dipstik-sportech
You need a catch can. That's normal on a boosted engine hence the need for a catch can, are you running the stock pcv back into the intake by chance?
Old 06-26-2014, 03:36 PM   #1869
blackfireball5
I have the cusco catch can running from the intake manifold, i thought I read that the breather tube can just vent? I need two catch cans then? Where is the stock pcv located?
Wheelwell Profile
Old 06-26-2014, 03:45 PM   #1870
xwd
Is there a check valve in the stock PCV hose? The stock PCV is probably what you have the catch can hooked up to now. Having two catch cans is probably the best idea.
Old 06-26-2014, 03:56 PM   #1871
blackfireball5
Where is the stock pcv valve located? I can post more pictures of that would help?
Wheelwell Profile
Old 06-26-2014, 04:16 PM   #1872
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Its behind the manifold near the bellhousing on top. That needs to be removed and ran to a catch can.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 06-26-2014, 04:19 PM   #1873
blackfireball5
Here's a pic of my setup.
Wheelwell Profile
Old 06-26-2014, 04:23 PM   #1874
Dipstik-sportech
You need to run both the pcv line and the breather in the pic to a can
Old 06-26-2014, 04:29 PM   #1875
Reaper
Reaper's Avatar
Drives: violent
Running that catch can to your intake mannifold is a bad idea. Under boost you are pressurizing that can and trying to force oil/air back through the pcv valve which is known to not hold boost.
Old 06-26-2014, 04:29 PM   #1876
blackfireball5
Alright. Thanks! Hopefully I can get away with not being one for the weekend... Lol. Question. Can they run to the same can? Or would that cause problems?
Wheelwell Profile
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
