#1905 |
building life
Drives: Raven Black, 6MT
Ordering my FBM base kit on the 7th along with the FBM single exit turbo back exhaust.. Still debating on if I should upgrade the turbo or not.
Sent from somewhere |
#1906 |
Which turbo do u plan to get? ^
#1907 |
building life
Either the GT2871 or GTX2867
#1908 |
in orbe terrum non visi
Drives: violent
I have the gtx2867 you can search my build thread. Do you have e85?
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#1909 |
building life
#1910 |
Go with the gtx if u can afford it. The GT is a terrific turbo, I know I had one. But from what I'm reading the gtx is just that bit better at higher numbers. I will say get the aluminium oil pan if nothing else it makes running the turbo drain way easier and it's just cool looking lol
#1911 |
building life
Hmm, I do want around 350 or so.. might get the gtx. yes im getting the base kit
#1912 | |
NASA SpecE30 Racer
1. PCV stands for Positive Crankcase Ventillation. It is possible for the crankcase to build up pressure especially if you are getting blowby past your piston rings. The port on the back of the passenger side of the block allows any pressure to be sucked out and into the intake manifold in normal operation. 2. Our car DOES NOT have a PCV VALVE. There is no check valve or any other type of valve anywhere on the car. The result is that if you leave the PCV line connected to the intake manifold, you will be pressurizing the crank case with boost pressure. 3. This can be fixed by either running a VTA (Vent To Atmosphere) catch can, or by adding a one way check valve that will let the crankcase vent to the intake manifold but not let any pressure go back into the crankcase when you pressurize the intake manifold with boost.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#1913 | |
NASA SpecE30 Racer
- King Tut
#1914 |
NASA SpecE30 Racer
That will be very difficult on a stock motor with 91 octane and a GT28 size turbo.
- King Tut
#1915 | |
Drives: Scion FRS Firestorm
I plan on getting rid of the cusco can and going with the dual radium setup since my cusco can seems to be pretty useless. I was planning on getting a silicone T house coupler just after the air filter and bring the breather line in to there after it passes from the breather to the can. Also, putting a check valve between the pcv can and intake manifold.
#1916 |
Also, does anyone know the diameter of the pipe that the air filter connects to?
#1917 |
building life
#1918 |
I have the same goals as you on 91.
As I saw it, I could either go with a built, lower compression shortblock, or go with methanol injection. I went with the WMI. I should be able to hit my 350whp goal with gtx2867 FB turbo kit, 3" Nameless catless front/overpipe, Tomei titanium 80R exhaust, tuned with Hydra standalone and Hydramist WMI. I'm right around 300 now with 10lbs boost. I'll be running more boost soon. |
| Tags |
| best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 11:46 AM |
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 04:10 AM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 01:36 PM |
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 10:46 AM |
| WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 10:15 PM |
