#183 |
^^ Great info. What kind of temps were you getting before the oil cooler was installed?
2013 Subaru BRZ
#184 |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
Unfortunately I didn't have anything to monitor temps before I got the oil cooler. The cooler and a Scangauge were part of the parts-pile that was growing while the car hibernated over the winter.
#185 |
Drives: 2013 SWP BRZ
#186 | |
Site Moderator
Drives: Stuff
![]() The max I've seen at Sebring with the cooler have been 235. Edit, err 239F.. 115 celsius.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#187 | |
What did you see before you had the oil cooler? And what kind of ambient temps were you in when you were seeing a high of 239*? Also, kind of getting to the root of the issue; where is everyone getting the arbitrary numbers of "anything over 2xx*f is dangerous"? I know over 230* people claim the engine pulls timing, which is no big deal as its going to be a tad slower for the sake of reliability, it looks like even with an oil cooler we'd hit that on track down here in FL. But where are people getting the fact that over 2xx* it's dangerous? I know cooler temps are ideal, and it never hurts to run an oil cooler, but where's the science to show that having 300*f oil temps is detrimental? Reading into the new synthetic oils, they're claiming to protect up to 500*f, so it doesn't seem like the oil will "fail" or break down at 300*f. |
#188 |
Drives: 2013 Firestorm FR-S
I believe someone asked one of the gt86 engineers the question about oil temps and the response back was 260 was the maximum safe temp. I'm not sure what the specific issue was with temps over 260. I know other cars can handle near 300+ oil temps without issue from poking around on bobistheoilguy's forum. I'm sure those temps reduce the oil life, but a lot of folks change their oil after a track weekend.
2013 Firestorm FR-S, MTX, build date 1/13.
#189 |
Drives: '12 C63 P31, '23 GRC
If the car's factory engineers claim that 260 is the maximum safe temperature they why didn't they include an oil cooler from the factory? Seems to me that this car was built specifically for people to have fun with it, DRIVING IT HARD, be it on mountain roads or on a race track. So why develop it with an inherent flaw like this?
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#190 | |
Drives: 2010 BMW M3, 2013 Subaru BRZ
#191 |
How do you get the oil removed from the cooler when you do an oil change? I'm planning on doing 0W-20 for streets and 0W-30 for track so I don't really want to mix them up.
#192 |
#193 |
I believe it will be a pita so just use 0w30. It will be much easier. Why 0w20 for street? Better fuel economy? Then remember that if you use 0w30 once then swapping it out for 0w20 youre wasting an oil change... You can use the same oil for at least 3 track days granted that its quality oil.
#194 |
Drives: Black frs project
I take off a line at the take off plate add my custom an blowpipe adaptor and us air to push the fluids back into the engine gets about 90% of the oil out...depends on the coolers height and orientation..or if the fittings are on the bottom just drain the cooler directly (messy...usually)
#195 | ||
![]() Quote:
#196 |
Water cooling? Like... computer water cooling?
Just use whatever you'd use on track. The MPG hit will cost you less than the oil change cost. |
| Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 09:10 PM |
| ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 05:30 PM |
| One-Off Oil Cooler? | wootwoot | Engine, Exhaust, Transmission | 37 | 07-18-2014 06:42 PM |
| Oil Cooler kit for FI applications, getting one? | JoeBoxer | Forced Induction | 84 | 01-20-2013 10:48 AM |
| Cooler than drifting! | Rampage | Other Vehicles & General Automotive Discussions | 8 | 04-03-2012 01:55 AM |
