View Poll Results: If I were to repaint/vinyl wrap this car, what color should I go with??
Stay with Lightning Red! 42 45.16%
Silver 0 0%
Gunmetal 26 27.96%
Black 5 5.38%
White 6 6.45%
Other 14 15.05%
Voters: 93. You may not vote on this poll
Old 01-18-2014, 02:22 AM   #183
ImperiousRex
Track Junkie
ImperiousRex's Avatar
Drives: 2013 Subaru BRZ Limited, 2005 S2000
Originally Posted by botbs View Post
Hi there,
What's the offset on your gold RPF1? +35 or +45 ?
Thanks!
+45 (Note this offset required that I get spacers for my front wheels to fit around the BBK)
ImperiousRex is offline   Reply With Quote
Old 01-19-2014, 01:36 AM   #184
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Would 5mm spacer work? I currently have the same offset wheel RPF1 17x9 +45 but silver. I am thinking of getting same BBK.
Million Thanks !
botbs is offline   Reply With Quote
Old 01-19-2014, 03:19 AM   #185
ImperiousRex
Track Junkie
Million Thanks !
I would recommend 15mm but no lower than 10mm. 5mm would cut it very close and would most likely result in contact at some point between the wheel and BBK.
Evasive recommended the 20mm for me mainly because they know how often my car is tracked and the extra clearance is just a precaution.
Old 01-19-2014, 03:36 AM   #186
ayau
Drives: Some rust bucket
I'm guessing you replaced the OEM studs with extended ones?
Old 01-19-2014, 03:00 PM   #187
ImperiousRex
Track Junkie
Yes. I originally got a bolt on spacer solution to make a track event just after I got the BBK but eventually switched to ARP extended studs to reduce the possible points of failure.
Old 01-22-2014, 01:22 PM   #188
NJA
Drives: Supercharged Saturn ION
very impressive build!
NJA is offline   Reply With Quote
Old 02-01-2014, 05:31 AM   #189
diss7
Drives: AE86, 2x GT86, TE27
Great build. Just read the lot!
diss7 is offline   Reply With Quote
Old 02-06-2014, 12:45 PM   #190
CajunFRS
Drives: Challenger R/T, CRX SI,
I just looked through this thread. Time to do it all over again!
CajunFRS is offline   Reply With Quote
Old 02-07-2014, 09:52 AM   #191
swift996
swift996's Avatar
@ImperiousRex nice build. By any chance do you have some pics of the brake ducting routing and backing plates? I've got a few parts and might pick up the APR backing plates to finish off my kit.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-20-2014, 02:55 PM   #192
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
@ImperiousRex
Maybe you should look into something like this for your bumper:
http://www.ft86club.com/forums/showthread.php?p=1348751
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 03-16-2014, 11:40 PM   #193
ImperiousRex
Track Junkie
Heya @swift996 - so sorry for the delay on this. Been super swamped with work and track events for the last few months. But here's the lowdown on my brake ducting (don't mind all the dirt and dust >.<). After the intial install, I found that my wheel/tire setup was rubbing on the APR 3" hosing that comes with the kit and after my first track event with the hosing, there were some gaping holes :P So Evasive got me some hose reducers and we switched to a 2" hosing up to the backing plates. Here's how the routing is now:
If you have any other questions, feel free to hit me up.
Old 03-16-2014, 11:40 PM   #194
ImperiousRex
Track Junkie
Originally Posted by Acree View Post
@ImperiousRex
Yes... yes I should...
Old 07-05-2014, 11:19 PM   #195
ImperiousRex
Track Junkie
The Importance Of Cooling...
Hi guys, so this update is loooooong overdue and I apologize to those of you who regularly follow the car. But a lack of updates doesn't mean the car has been sitting around doing nothing In fact since my last update the car has been to another 10+ track events and time attack events and the turbo has been through 20+ track days at this point. This equates to a lot of development insights that I'm happy to share with you today (both good and bad).
First of all, I am still running on the original engine and I want to credit @Evasive Motorsports for a solid tune that I wanted geared for hard track days. While it doesn't set any dyno queen numbers for epeen records, it's been very reliable up to this point. We haven't had any catastrophic incidents despite running it quite hard to multiple track records for the platform. However, that's not to say we haven't had any issues.
The DI seal issue reared its ugly head and I had all 4 seals replaced early this year and I've also had to replace the cylinder 1 ignition coil. While I had early signs of both starting to go before the turbo ever went on (i.e. misfire and ignition coil CELs) they both gave up after the turbo was on so neither was covered by warranty as expected.
Beyond those two problems, the main issue we've been tackling is adequately cooling the car. As many of you with turbo experience might know, the front mount for a turbo is not ideal for avoiding heat soak. @CSG Mike had run the car for multiple events and noticed that in the straights the car wouldn't pull much harder than a stock S2K after a couple sessions despite the initial dyno from Evasive showing much more power than a stock S2K would. So we took the car to a couple other dynos and had some testing done. First up, we have dyno runs on a Dynapak dyno at Church Automotive on 100 octane.
As you can see Dynapaks read quite high in comparison to other dynos but this is roughly what we expected compared to Evasive's mustang dyno. We didn't see a parasitic loss here so at our next stop with European Auto Source's Dynojet we secured time for multiple runs back to back with a closed hood and a single fan to simulate the car in motion:
So what you see here is the power on the first run when everything was cool and on a DynoJet vs. power after 6 runs at high rpm's. The whp in cool conditions again corroborate the Evasive numbers but the 40whp loss after 6 runs was eye opening. On track we suspect the car is losing even more power after multiple sessions and the main culprit appears to be the intake ambient temperature (IAT). As you can see there's a direct correlation in this graph:
Now keep in mind this is probably something that daily driven cars will never really experience. This type of heat soak is from sustained high RPMs for extended periods of time. On track this will be up to 20-25mins of 5-7k RPMs during the entire session. (Although in hot summer months this can happen more naturally.)
Another hint that the engine bay was getting too hot was what happened to my stock fans...
We're not 100% sure if the melting caused the fans to stop or if the fans blew a fuse and the lack of pulled air caused the fans to melt. But either way things were getting too hot in there >.< The stock fans are wired across the center of the fans and the proximity to the turbo exhaust manifold may have caused them to melt as well. So as a result, we decided to upgrade to higher flow Spal fans, a radiator shroud from @Carolina Dyno and rewiring the fans along the bottom of the engine bay rather than across the center.
Despite having to use the lower profile versions of these fans to fit in with the turbo kit, simply put they are incredible. They can drop coolant temps 15 degrees in about 10 seconds and if you have a gauge to monitor the temps, it's fascinating to see how quickly they work.
Sadly even with the fan upgrades the Robispec radiator solution has failed me twice now. The first one developed a leak earlier this year after about 4 months of tracking and after taking it back to get checked out Robi suspected that there was electrolysis going on in the radiator which caused the leak. So we replaced it and another 4 months later, the 2nd radiator has fully cracked. Granted the ambient temps have been gradually rising in these 4 months but it would appear the radiator isn't sufficient to handle the temps generated by this turbo kit.
So that brings us to today. I'm now looking at a Koyo radiator and Greddy oil cooler solution and we should have some data to look over in the coming months. Robi may still be right about the electrolysis though and I'm going to get my electric system diagnosed soon to see if we have anything excessively drawing power.
Old 07-05-2014, 11:32 PM   #196
ImperiousRex
Track Junkie
Additional Upgrades
Not everything has been bad news though! The car has seen a few more upgrades in the past few months. First off, I had all the intake piping for the turbo kit ceramic coated to help keep IAT's down.
I've also replaced the ACT Lightweight Street Clutch kit with an Exedy Stage II Cerametallic Clutch Kit. The ACT was ok but the engagement point was really close to the floor and had some engagement issues on track. The Exedy in comparison is just grippier and has a higher engagement point and on track it's been very solid so far.
And lastly my favorite upgrade in the past few months is the addition of a Cusco Type RS Limited Slip Differential:
The LSD was configured by @CSG Mike for 1.5 way and 80% engagement I believe. Ask him for any questions on the specifics. My experience with it so far is that I love the additional grip mid corner and how it works with the Sport Traction Control system. I drive the car with both TC off and STC on and my main complaint with the STC is that in a high speed sweeper, the STC tends to cut power when I want it the most. With the LSD, it's far less intrusive and is basically doing what I mainly turn it on for - which is keeping me on track when the back end snaps. While pricey I would highly recommend this LSD over almost any other mod that I have (the JRZ coilovers being the exception).
At this point I think I'm good with the car for the next few months. The only other mod I'm looking at is upgraded rear axles but that's more for necessity than anything performance related.
Here's how the car looks at this point (the stickers have changed a few times since the last update):
Thanks to everyone who follow the car and I'll try to keep the journal updated more regularly!
LIGHTNING RED BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 409 03-01-2025 12:28 PM
StockySnail's Lightning Red 6MT BRZ Limited Build Thread stockysnail Member's Car Journals 206 09-23-2024 12:40 PM
The lightning lap Gixxersixxerman FR-S / BRZ vs.... 35 09-17-2014 02:15 PM
Lightning Red Ft 86 Acid18 Member's Car Journals 6 12-28-2012 03:27 AM
SD: Lightning Red BRZ Limited 6MT tastefully modded epson1 Cars for Sale/Trade 2 09-24-2012 01:56 PM
