Old 07-04-2014, 02:09 PM   #1947
xwd
What kind of coolant are you using? I would use mostly water with the MoCool and maybe just a tiny bit of antifreeze to raise the boiling point.
Did you remove the guides which direct flow into the radiator? If air isn't hitting the radiator properly it's not going to do much cooling.
Old 07-06-2014, 09:28 AM   #1948
Boba_kz
Motul Inugel Expert Ultra
Could you please show the picture of those guides?
Boba_kz is offline   Reply With Quote
Old 07-06-2014, 09:33 AM   #1949
Boba_kz
Tested again yesterday on short uphill. Don't know is Mocool works or no, but temperature was:
Outside +18C
Water +102C
Oil +120C
Old 07-06-2014, 10:09 AM   #1950
M1K3
M1K3's Avatar
Drives: vrooom...
Outside +18C
Water +102C
Oil +120C
Your Oil temp is high but that Water temp is not good especially on a short uphill, I really wonder if your thermostat is working properly.
M1K3 is offline   Reply With Quote
Old 07-07-2014, 11:24 AM   #1951
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by pleong View Post
Anyone have the oil cooler? My socket walls are too fat for that bolt that bolts down the spacer and sandwich plate
I don't think you will find a socket that fits properly. You kind of have to just tighten it down and torque it with the socket not fitting perfectly.
Old 07-07-2014, 11:26 AM   #1952
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Tracking
Yes we bleed the system
Fans are working
Do you have any ceramic coating or heat wrapping of the manifold and down pipe? Do you have a turbo blanket? At this point I would do anything I could to reduce engine bay temps and try to get more air to your radiator. Are your cooling fans working properly? Have you tried venting the hood?
Old 07-07-2014, 11:54 AM   #1953
xwd
I believe they are just the styrofoam pieces which a lot of people take out when doing the FMIC. I haven't taken my bumper off just seen pictures of it.
I would say for track duty (or anywhere where freezing isn't an issue) your best bet is mostly distilled water with the MoCool added in and maybe a small amount of normal coolant for additional lubrication and to raise the boiling point. A high pressure radiator cap might also be useful to raise the boiling point.
Also make sure your fans are working, a few people on here have had the FBM slim fans fail...
If you don't have an air pocket you definitely are having issues with airflow or coolant flow.
Old 07-08-2014, 12:56 AM   #1954
Boba_kz
Yes, I have ceramic coated intake pipes, turbo blanket and exhaust manifold wrap.
It seems that fans working well, but when I turn on AC, temperature drops about 7-8C degree.
Will make additional ventilation this week on the hood and front bumper.
Old 07-09-2014, 02:18 AM   #1955
Boba_kz
Only way to make it cool )))
Old 07-09-2014, 03:14 AM   #1956
Boba_kz
Would like to change intake filter, anybody knows part number of this filter?
Old 07-09-2014, 02:39 PM   #1957
King Tut
NASA SpecE30 Racer
King Tut's Avatar
LJ @FullBlown should know, otherwise just take measurements and go to www.kandn.com and you can find a part number.
Old 07-09-2014, 09:07 PM   #1958
KPark
Drives: none
question before I buy it.
Is this gonna pass emission test?
my state do obd plug in test thing.
Also... if I buy ECUtek cable then I do not have to ship my ECU right?
KPark is offline   Reply With Quote
Old 07-09-2014, 09:08 PM   #1959
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
No.
Old 07-10-2014, 12:13 PM   #1960
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I have not ever seen a clear answer to this. If all they do is an OBD plug in test to check for working emissions systems then there is a small chance. The problem is that the Full Blown kit turbo manifold removes all the cats and places both the pre-cat and the post-cat O2 sensor very close to each other meaning that the check of the post-cat O2 sensor needs to be diabled by EcuTek or you will throw a check engine light. I am not sure if in the process of diabling that check that it will still report as working properly for an OBD plug in test.
You will definitely want an EcuTek cable to be able to datalog your car. No forced induction owner should be without one.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
