Old 08-21-2014, 01:40 PM   #1989
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
on a side note I was able to improve my best lap time at The Ridge Motorsports Park by 1 second before the belt goes bad, cannot wait to receive my belt and test the new tires
[ame="http://youtu.be/D-mPfYoUFns"]http://youtu.be/D-mPfYoUFns[/ame]
glamcem is offline   Reply With Quote
Old 08-21-2014, 04:35 PM   #1990
Calum
That Guy
Drives: 2013 asphalt FRS MT
You mean missing the gear and going into neutral? Because a money shift would have blown the engine.
Isn't a sudden change in load what happens every time you shift hard, whether it's a down or up shift?
I missed a shift at the drag strip in my old neon. I went from 7500 rpm in 3rd to 2nd, and side stepped the clutch. Other than the power steering belt slipping off and the engine stalling nothing wrong came of it. I restarted, picked up my belt, nursed it back to the pits. Put the belt back on and run another dozen or so passes that day. I put another ~150,000 km's on that engine afterward, and a couple hundred drag passes, and I never once opened the engine. If a shit box neon can do it once, I'm sure this engine can do it once.
Old 08-21-2014, 05:24 PM   #1991
Timing belts and timing chains have a different consequence with over revs... And the neon valve springs are stronger than the frs's (!!!)
Old 08-21-2014, 06:00 PM   #1992
Calum
That Guy
The neon has a belt, not a chain.
I can't speak about the FA20's valve springs, but the DOHC neon springs were pretty bad.
The SOHC's were decent though. We can thank BMW's influence for that.
Old 08-22-2014, 05:50 AM   #1993
glamcem
glamcem's Avatar
my favorite engine bay shot
Old 08-22-2014, 02:38 PM   #1994
Sleepless
Drives: 2016 FR-S
I had a look at Cem's broken belt and it had a pattern of missing rubber chunks on one side. This to me seems like the belt/pulleys were not aligned perfectly which in my experience can cause the belt to break. I wonder if a pulley is coming loose?
Sleepless is offline   Reply With Quote
Old 08-22-2014, 02:50 PM   #1995
glamcem
glamcem's Avatar
I am not really sure but I have been periodically checking my belts from both outside and inside and also making sure the tension bolt is within specs.. maybe I should check my pulley to see if it is coming loose like you mentioned
Old 08-22-2014, 03:37 PM   #1996
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Was your belt stable or did it have any movement in it while spinning? I'm nervous now because my belt still moves back and forth indicating something is out of alignment...I need to get that figured out before the next track day...
nlowell is offline   Reply With Quote
Old 08-22-2014, 03:42 PM   #1997
RaveSolid
Fabricator
RaveSolid's Avatar
Drives: Kraftwerks sc Hot lava FR-S
I have mine installed on my car. I just now found this thread lol have had the kit on for almost a month now.
"You can't buy happiness, but you can buy horsepower. And that's kinda the same thing."
RaveSolid is offline   Reply With Quote
Old 08-22-2014, 03:54 PM   #1998
RaveSolid
Fabricator
RaveSolid's Avatar
http://hotlavagt-86.deviantart.com/a...253A1408733137
Old 08-22-2014, 04:01 PM   #1999
glamcem
glamcem's Avatar
It was stable , did you check your tension bolt? And pulleys? Or better yet contacted with KW?
Old 08-22-2014, 04:08 PM   #2000
RaveSolid
Fabricator
RaveSolid's Avatar
^ I would contact kraftwerks about it. Make sure you speak to a kraftwerks professional. Most of the time a skunk 2 rep will answer and they don't know much about the kraftwerks. At least it has been in my experience.
Old 08-22-2014, 04:23 PM   #2001
TmP
TmP's Avatar
Drives: A bunch of 'em...
K, just figured I'd give you guys an update on my BRZ.
Thing has been sitting for a while, due to lack of spare time.
All buttoned up now, with oil cooler etc.
Car is still slow, but at least not painfully so any more. LOL
Definitely an improvement. WAYYYY more fun to drift.
Will have some power guestimates based on GPS data as well as lap times (track, not strip) in a few days.
TmP is offline   Reply With Quote
Old 08-22-2014, 04:38 PM   #2002
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Really do have any clue of what power your putting down on the wheels. Try Virtual Dyno and just input your pull logs and basic car info.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
