Old 08-22-2014, 04:43 PM   #2003
TmP
TmP's Avatar
Drives: A bunch of 'em...
I'll use my Gtech.
That's a touch more accurate.
Also, instead of doing the hokey dyno thing, I just do a 1/4 pull and calculate it out of the trap speed.
TmP is offline   Reply With Quote
Old 08-22-2014, 07:23 PM   #2004
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Originally Posted by RaveSolid View Post
^ I would contact kraftwerks about it. Make sure you speak to a kraftwerks professional. Most of the time a skunk 2 rep will answer and they don't know much about the kraftwerks. At least it has been in my experience.
Yeah, they physically inspected my car and said everything was tight and the movement is "normal" with a cogged belt system. It's just odd that others aren't seeing this. I ordered a new crank pulley and crank pulley bolt and will try that next.
nlowell is offline   Reply With Quote
Old 08-22-2014, 08:28 PM   #2005
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Originally Posted by Sleepless View Post
I had a look at Cem's broken belt and it had a pattern of missing rubber chunks on one side. This to me seems like the belt/pulleys were not aligned perfectly which in my experience can cause the belt to break. I wonder if a pulley is coming loose?
Originally Posted by glamcem View Post
I am not really sure but I have been periodically checking my belts from both outside and inside and also making sure the tension bolt is within specs.. maybe I should check my pulley to see if it is coming loose like you mentioned
Although we cannot see all the wear in the pictures we have issued a shipping label to glamcem to bring back the belt for inspection. That way we can physically inspect every inch of the belt and coordinate with Gates themselves to see if this is an isolated issue or otherwise.
In the mean time, his new belt should arrive Monday. =D
@RaveSolid - Do you have any questions left unanswered currently? Is there anything specifically that you were looking for a bit more clarification on?
KraftWerks is offline   Reply With Quote
Old 08-22-2014, 09:00 PM   #2006
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Thanks for the great communication and handling this in a timely manner
glamcem is offline   Reply With Quote
Old 08-22-2014, 09:15 PM   #2007
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Was your OEM ever removed before. If so was it put back correctly. There's a good DIY about the pulley in the DIY section, and also a sticky about the cautionary things you need to know about removing the OEM pulley. Don't forget your O-rings.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 08-25-2014, 07:41 PM   #2008
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
Just an update on my brz: we just installed DW 700cc injectors and DW fuel pump, stage 3 competition clutch, mtec shift springs, motul tranny oil and the 12 psi small pulley on e85, we did a base map with little timing and drove around the neighborhood and the car felt awesome then after we got the afr dial in we started adding timing and Jesus Christ !! The combination of a fresh clutch and the smaller pulley really changed the way this cars behaves, I'm a drag racer so I'll be posting my time slips pretty soon we should be in the low 12s or maybe better. Looking to get around 350 hp on this set up ... Maybe more, I'll keep you guys posted.
Taino-BRZ is offline   Reply With Quote
Old 08-25-2014, 07:51 PM   #2009
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
All you people and your E85.... I'm jealous
Freeman is offline   Reply With Quote
Old 08-25-2014, 10:11 PM   #2010
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
That's great, two of us here at the shop are now looking to get our own, C30 and a C38.. I cant wait to bolt on that C38 and run it.. i haven't decided on E85 yet, can you post up Dyno numbers when you get them please.. We currently have a local with a BRZ running the C38, but dont think the tune is proper as he ran a 14.5 at 98mph.. about 225 at the wheel, but we are trying to get the tune sorted out..
86SPEED is offline   Reply With Quote
Old 08-25-2014, 10:14 PM   #2011
Taino-BRZ
Taino-BRZ's Avatar
Kraftwerks Supercharger Owners Thread
We did 301 hp on e85 with the previous pulley, best time was 13.8 when the clutch gave up. I'm confident we are going to be in the 12s,car feels way faster now with all the new upgrades.
Old 08-25-2014, 11:35 PM   #2012
captain_jack
captain_jack's Avatar
Yeah a 14.5 isnt great at all. Im at about 3200 ft here and with a just a safe tune i ran a 14,7 @97mph. Car came alive when it was finished being tuned, oh and that is on a c30 on 91 pump gas.
Old 08-25-2014, 11:38 PM   #2013
nlowell
nlowell's Avatar
I just dropped my car off at Infamous for upgraded Grams 550cc fuel injectors and then it's going next door for Bill @DeliciousTuning to do his tuning magic on the dyno. He's going to load the flash-n-go tune scaled for the new injectors then do some fine tuning on the dyno. Should have results by Friday. Looking forward to seeing the results on e85 with the fuel limitations removed!
Old 08-26-2014, 12:33 AM   #2014
Taino-BRZ
Taino-BRZ's Avatar
Im on a custom tune now ,I'm very high altitude too, I had the delicious tune but it was crazy lean for me and the whole e tune wasn't working out for me, so I hired a local Subaru tuner and he squeezed 301 hp from the c30 on stock injectors and pump, my delicious tune was crazy fast but not safe for my setup, I wish I was closer to bill. My tuner said we have a lot of room for more power with the 700cc and the pump. But we are finishing the tune at the dyno/track.
Old 08-26-2014, 12:36 AM   #2015
SPCorBUST
SPCorBUST's Avatar
Did you up the pump?
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 08-26-2014, 12:37 AM   #2016
captain_jack
Just a heads up to all of your as well I'm selling my kit with engine oil cooler and flex fuel kit. I decided to go another route asking 4k for all of it, blower is new as is filter and rotrex oil. Kraftwerks will xfer warranty as well since blower is new. I posted it up in the az thread as I'd prefer to not ship it.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
