Old 10-03-2014, 03:37 PM   #2073
Racecomp Engineering
Originally Posted by rs999 View Post
I have been reading up on Sam Strano's AutoX setup on this forum and he uses a relatively simple setup of summer tires, Strano front sway, and Koni Sport shocks.
What I want to know is how important are shocks in this setup? Are they necessary to control additional body roll or to tune out undesired body dive?
Would Bilstein B6's work better or would it be better to use RCE Tarmac Zero's?
I am looking for simple AutoX, Track, and spirited driving setups. I don't really care about lowering as well.
And Sam's setup looks to be the most simple and best bang for the buck.
Sam's set-up you mentioned is for C stock where you're extremely limited in what you can do.
For STX class you would want to coilovers to be competitive.
Are you out to be competitive in a certain class or just trying to have fun?
- Andy
Old 10-03-2014, 04:13 PM   #2074
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Originally Posted by Racecomp Engineering View Post
How does the car feel? Hard to make suggestions without knowing where you think you're slower. Alignment specs sound good.
- Andy
Sorry, was in a hurry. I was pushing entering corners and did a temporary remedy of letting air out of the tires but I had to take them down to 28PSI hot to do anything. It helped but I'm needing to srub off more speed to keep things in check. The rear is wanting to step out as well. I've gotten it to lose grip with less speed than I was exiting with before. My current rear camber is -2.2 so I'm hoping adding a bit will make it stick a bit more. I've thought about going to full soft on the sways or even unhooking it.
digital_assassin is offline   Reply With Quote
Old 10-03-2014, 04:29 PM   #2075
rs999
rs999's Avatar
Drives: VW MK6 GTI | 13 Mustang GT
- Andy
I'm competing in C class now in my FR-S. However, I do more track days and time attacks than autocross. Also, I only do AutoX for fun but it would be nice to place in the top 75 instead of the bottom 75 of Tidewater Sports Car Club's AutoX events.
Would a STX build be better for that? I would prefer a neutral setup instead of a tail happy car like the FR-S is stock or with a rear sway bar only.
I did read this thread: http://www.ft86club.com/forums/showthread.php?t=52755
And it looks like the Tarmac 0's are a good choice but with the stock bars or only front upgraded bar.
Should I instead start with the Tarmac 0's then add a front bar or start front bar then do T0's?
Sticky summer tires will be on both setups.
SOLD FR-S Build | MK6 GTI Build | I might be getting another FR-S
rs999 is offline   Reply With Quote
Old 10-03-2014, 05:10 PM   #2076
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
So I am currently debating between running in CS or STX for the next season of autocross (my first full season).
For CS, I like the idea of being able to make my car fairly competitive (not factoring in the driver mod lol) for relatively cheap. I already have a 2nd set of OEM wheels for winter that would function as track wheels during the autox season.
However, I also like the idea of being able to modify my car even more to my liking with STX. One of my concerns with STX comes from changing between daily wheels (17x7 OEMs) and track wheels (most likely 17x9 RPF1s).
Once I get coilovers (planning on SACHS since I get a significant discount) will I run into any issues with the tuning of the suspension or ride quality going back and forth between such different sized wheels?
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 10-03-2014, 05:13 PM   #2077
IMO an STX build is more fun since you aren't as restricted. You can dial in the handling quite a bit more to the way you like it. So if your focus is fun and your track days are more frequent than auto-x days I'd go with an STX type build.
RCE T0 are a great choice and work well for track and auto-x. If you know they're in the plans then I would start with them as that will be the most dramatic change. You may like them without changing bars at all.
One note, a hardcore, dedicated, nationals level STX car may not be ideal on the track. BUT a well set-up track car will still be pretty quick for auto-x.
- Andy
Old 10-03-2014, 05:17 PM   #2078
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Best to measure from center of hub to fender for ride height measurements. Get one side right and measure threads or something so you can get the other side the same. Measure twice. Corner balance if necessary then align.
You should be able to adjust without removing endlinks.
- Andy
The situation is that if I go by strut measurement and get both sides even then when I measure the hub-fender distance, it'll be different or the car won't look even. I opted for adjusting coil over so it's visually when and disregard strut length.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 10-03-2014, 05:17 PM   #2079
Some quick armchair thoughts:
1. I would think about softening the rear sway if you raised the rear (and I do think that raising the rear was a good call).
2. The slight bit of extra rear camber you added also is probably good.
3. I was a little confused on what you did for your damper settings. I would soften the front rebound a bit if you're understeering on entry.
4. Can you not reach your rear adjusters?
- Andy
Old 10-03-2014, 05:19 PM   #2080
That's fine and it happens. Doesn't always come out visually even and you can adjust to get it perfect.
- Andy
Old 10-03-2014, 05:27 PM   #2081
yomny
yomny's Avatar
- Andy
Thanks for your time and believe it or not a means the world to some of us that you guys take the time just to answer. Any time I need parts your webpage is the first visit. Got my track pads from David at csg.
Old 10-03-2014, 05:47 PM   #2082
gramicci101
Off Topic
@rs999, @Shark_Bait88,
Check this thread out.
http://www.ft86club.com/forums/showthread.php?t=72735
This would put you in STX, but it's a good deal. Especially with the upgraded springs included.
Old 10-03-2014, 05:50 PM   #2083
Shark_Bait88
Thanks for the suggestion! Saw those earlier, but I really need to get wheels and tires first. haha Plus, I can get a better deal on a brand new set of SACHS Performance Coilovers.
Old 10-03-2014, 05:54 PM   #2084
gramicci101
Off Topic
I mean, I suppose that'll work too.
Old 10-03-2014, 06:01 PM   #2085
digital_assassin
- Andy
Thanks. I did soften both compression and rebound. They were previously set nearly at full firm by GC so I moved them right into the midrange on each setting. I can't do the rears because I can't see the adjuster. The instructions show doing it out of the car with the shock in a vice. Ain't gonna happen today. If I'm missing something about how to adjust the rears please tell.
Old 10-03-2014, 06:19 PM   #2086
Not a bad deal at all!
- Andy
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
