#211 |
Drives: 2022 BRZ and some other cars
If I understand correctly, front is strut clearance challenged and rear is fender.
#212 | |
Drives: 2022 GR86
#213 | |
Drives: 1996 Turbo Miata
Crazy how conservative the fitment setups have to be with the second gens, first gens seemed to fit wider and lower offset wheels with a lot less drama. I don't have the car yet, but I've been eying 57dr's and thought it would be possible to fit the 18x9.5's, now I'm looking at 18x8.5 et37 and that may still be too aggressive lol. |
#214 | |
Drives: 2022 BRZ Limited
#215 |
AutoX Nut
Drives: 2020 Toyota Supra
Anyone with aftermarket wheels on their Gen 2 skip installation of TPM sensors? If so, any issues other than a TPMS light on the dash? I usually don't bother with TPM sensors for auto-x/track wheels and just wanted to make sure the Gen 2 cars wouldn't cause that to be a hassle with turning off traction control and keeping it off.
#216 | |
Drives: 2022 GR86
I can imagine the real-time pressure monitoring being quite handy at track days. Although would be cautious that the readings of those sensors can be slightly off the real pressure. That being said, if you want to keep any of your sets of wheels without TPMS sensors, I don't anticipate any issues other than the warning light. |
#217 | |
Drives: 2024 GR86/ 2015 FRS
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#218 |
Drives: 22 BRZ
![]() ![]() ![]() Just got my wheels and suspension on the car. Went with RaceComp Engineering Tarmac II coils and Works Motorsports top hats. The wheels are 17x9 et42 Apex EC-7R in Anthracite wrapped in 245/40 tires. We went with a 1.5" drop front and rear which caused us to pick up -2.5 camber in the rear, so we chose to match it with the front to have a good balance. Its a street car and my original goal was run -2 on all four corners but we had issues with the RLCAs and ended up not being able to use them. That meant I was stuck with the -2.5 that the stock rlca provided but after it was all done I really like the look of it. Clearance in the front is great, I dont have the stock spring perches anymore so there were no clearance issues on the inside of the barrel, and the outside of the wheel clears just fine. I think it would honestly look even better with a 7-10mm spacer just to match the rear more closely. Clearance in the rear is surprisingly good too. Even at 1.5" of drop there is no danger of rubbing on the trim piece or fender liner. I think we could have easily gotten away with the -2 camber I originally intended and still not had any issues. I have put about 300 miles on the car since the change and gone pretty hard through corners and over a few larger bumps and experienced zero rubbing. |
#219 | |
Drives: 2022 GR86
I’m surprised there are no clearance issues or rubbing. Do you think it’s because your tires are narrow for a 245? Previous posts with the same wheels and 245 tires had some issues with hitting the fender liner in the rear. I’m considering pulling the trigger on some TWS 18x8.5 +42 and was worried that would be too aggressive… but perhaps not? Hmm |
#220 |
Drives: '22 BRZ
Picked the car up from the dealership last night. Immediately swapped the stock wheels/tires to a set of RPF1s 18x8 +35, with winter tires in 225/40r/18. I am thrilled with how it turned out. Zero rubbing, and plenty of clearance to the front strut tower. I plan to lower the car modestly, eventually. Cheers!
#221 |
Drives: 2022 GR86
#222 | |
Drives: Mini
Only thing I worry about with dropping the height on my current car or my future BRZ would be ride comfort with my bad back and all. Health > everything else. |
#223 |
Drives: 22 BRZ
The issue was a quality issue with the LCA, not the car or fitment. The adjustment bolts and offset washers were much too soft and basically just rounded out instead of actually adjusting the camber. We had them sitting on the shelf so we grabbed them, but I'm going to pick something much nicer when the need arises.
#224 | |
Drives: 2022 GR86
| Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 11:05 PM |
| Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 07:09 PM |
| Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 08:08 PM |
| Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 05:09 PM |
| Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 04:34 PM |
