Old 01-21-2015, 08:13 PM   #211
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
The camshaft sensor and misfire DTC tsb looks more updated from Subaru than Toyota.
Darryljr11 is offline   Reply With Quote
Old 01-28-2015, 03:55 PM   #212
RustyShackleford
Alright, so I finally got my car to the dealership today for the appointment I scheduled. I was in there for only about a half hour before they came out and told me that the P000B should be fixed with a reflash which they did on the spot. I was only able to drive about 20 miles so far but aside from the throttle relearning the car seems okay for now.
I didn't hear or feel any mechanical issues before the fix aside from the occasional idle hunting so I don't have anything to really judge yet, but the car did not idle hunt at all on my drive home (which it would mostly seem to do only after the car was fully warmed up).
I will update if I run into anymore problems.
Edit - I posted an update in the CEL / Idle (where this post probably should have gone) but it's still a TSB issue I suppose so it's not totally out of place. Check the CEL / Idle thread (starting at post 2882) for any posts I've made about my issue.
Last edited by RustyShackleford; 01-29-2015 at 06:45 PM. Reason: Because I'm a dope
RustyShackleford is offline   Reply With Quote
The Following 3 Users Say Thank You to RustyShackleford For This Useful Post:
Asphalt TG (04-06-2015), notout86 (01-28-2015), Tcoat (01-28-2015)
Old 01-28-2015, 05:04 PM   #213
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Originally Posted by SillySaxon View Post
Speaking of the cricket TSB.
The new one is still in effect, sent mine in for it today, they're replacing it with a newer part number fuel pump tomorrow. Will advise
Probably the same TSB from October 2013 I had installed the day it was released and had both Toyota and Subaru engineers inspecting my car. They also tried to use sound insulation on the pump itself. None of it worked and I got sick of wasting my time with it so I just gave up.
The crickets are going no where and do not waste your time. A company called Champion manufactures the fuel pump and until that changes, don't bother.
2016 Camaro SS is offline   Reply With Quote
Old 02-06-2015, 05:39 AM   #214
73TORANA!
Drives: Orange GTS
I accidently put 95 obtain 10 % ethanol in mine about 6 months ago here in Australia and it chirped until I put 98 octane back in the tank. This was the only time my car has chirped in 20,000 Kms.
73TORANA! is offline   Reply With Quote
Old 02-10-2015, 07:03 AM   #215
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Excuse my ignorance here. Looks like a laundry list of tsb's available. At this time I am really only interested in having those that could result in direct harm to my car done. In order for this to work I simply need to call the dealer and tell them I would like this tsb serviced? That's it? Their need not be a problem or code thrown before they take action?
I'm mostly interested in tsb s-sb-0033-13 for acvs applied.
This raises my next question. I have UEL headers and OFT tune. Would you recommend I reinstall the OEM EL headers and flash stock before service? I understand they can't deny care as nothing has been broken as a result of my mods but will they flag this in a database somewhere?
Any other tsb's to have serviced re: car safety to consider while I am there?
Thanks
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 03-06-2015, 02:21 AM   #216
Sugi
Sugi's Avatar
Drives: 2015 FR-S - Halo
Thanks for the post @sign-on_Rice I've had the idle drop and with your help can finally get it resolved.
Sugi is offline   Reply With Quote
Old 04-06-2015, 03:41 PM   #217
Asphalt TG
Captain Stabbin
Asphalt TG's Avatar
Drives: 2013 FRS Asphault
Has anyone had the TSB (S-SB-0023-12-Rev2) For the Chirps completed at their dealership and actually fixed the issue permanently? If not i'm not even going to waste my time and just keep on chirpin... Thanks.
Asphalt TG is offline   Reply With Quote
Old 04-06-2015, 03:43 PM   #218
As far as I know they are on rev 3 or 4 so far and still no fix.
Asphalt TG (04-06-2015), Dadhawk (04-06-2015)
Old 04-06-2015, 03:46 PM   #219
Asphalt TG
Captain Stabbin
Asphalt TG's Avatar
Figured so... Thanks @Tcoat
Hey @RustyShackleford any idle issues since having the re-flash completed? I also sometimes have issues with Idle dipping.
Old 04-06-2015, 04:32 PM   #220
RustyShackleford
I actually traded my BRZ in and moved on from it, but the last week I had the car I was starting to get minor idle issues again. They weren't as bad as before the dealer flash as the car wasn't stalling and didn't have a P0017 code (just the P000B code that it's always had intermittently), but it was enough to feel it once maybe twice during my 45-60 minute drive to work.
Old 05-20-2015, 04:57 PM   #221
Waffleicious
Waffleicious's Avatar
Drives: 2015 BRZ Blue Edition
I just got my BRZ back from the dealership after telling them about the chirping TSB and having them install a new fuel pump... I've only had it back for a day now, but the chirping is currently gone... Fingers crossed that it's gone for good, but we shall see!
Waffleicious is offline   Reply With Quote
Old 05-20-2015, 05:23 PM   #222
HunterGreene
Hail Magnet
HunterGreene's Avatar
I just don't have the heart.
It has priests in it?
The Following 5 Users Say Thank You to HunterGreene For This Useful Post:
kch (05-20-2015), Kevinn (05-20-2015), ScoobsMcGee (05-21-2015), Tcoat (05-21-2015), tyrantcf (05-21-2015)
Old 05-20-2015, 05:26 PM   #223
Kevinn
Drives: 2014 BRZ Limited, Black, Manual
Why are they even still wasting money on replacing fuel pumps?
Kevinn is offline   Reply With Quote
Old 05-20-2015, 05:30 PM   #224
Waffleicious
LMAO I don't have much hope that this will last but hey, as long as angry bastards like myself keep complaining, we milk the companies for money... which -in my mind- will make them more inclined to fix the issue for good xD
The Following User Says Thank You to Waffleicious For This Useful Post:
Kevinn (05-20-2015)
chirping, high pressure fuel pump
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 11:39 AM
FRS recall? totally Issues | Warranty | Recalls / TSB 8 08-30-2012 01:01 AM
Recall! already earthsscum BRZ First-Gen (2012+) -- General Topics 1 06-07-2012 08:00 PM
Owners Manual Recall Opie BRZ First-Gen (2012+) -- General Topics 8 06-05-2012 11:09 PM
Did anyone get a call from toyota about a recall yet? AustinTCLN Scion FR-S / Toyota 86 GT86 General Forum 2 06-05-2012 12:45 AM
