Old 04-06-2013, 09:42 AM   #211
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Originally Posted by civicdrivr View Post
You sir, are a scholar and a gentleman.
I'm curious as to where the two wire terminate though.
Sent from my Nexus 4
According to the manual they terminate at the end of each harness that feed the headlight assemblies and parking lights with the actual fog light connectors. No connectors that I see so I'm assuming they are just wrapped up in the cable bundles.
Originally Posted by Retro86 View Post
Holy shiiiii!!!! thank you for this!!! good thing i only got the stalk installed. i was ready and gonna install the rest this weekend, good timing guys!! thank you thank you
okay im on stand by!
You're welcome. You have as much info as I do. Get out there and answer the final questions.
FRSFirestorm is offline   Reply With Quote
Old 04-06-2013, 10:32 AM   #212
norm24
Drives: TSX
Seeing as you're in Vancouver, where did you purchase the stalk?
norm24 is offline   Reply With Quote
Old 04-06-2013, 12:02 PM   #213
Manny4115
Drives: Infiniti g35, scion frs
Looks like I will wait to install my fog lights. Thanks for the info
Manny4115 is offline   Reply With Quote
Old 04-06-2013, 12:46 PM   #214
FRSFirestorm
Red is Fastest
One of the wires in picture under the hood is indeed the wire for the LH side fog light. The red/white. Probed and confirmed with on and off of the fog lights.
After looking at how well the harness is wrapped up, tight spaces and the probable need to remove the front bumper to properly tap into these wires near the fog light location I've pretty much decided to splice into them at the Body ECU and run new wires out to the lights. I'll take some pictures as I go and post up later.
In the process I'll be removing the Nigel harness and removing the ground for that harness I currently have attached at the white wire from the stalk under the steering column.
Old 04-06-2013, 12:52 PM   #215
Retro86
Retro86's Avatar
Drives: Awesome
i got it from our club member. he supplies it for us at a good price photomike is his username on here
Retro86 is offline   Reply With Quote
Old 04-06-2013, 04:07 PM   #216
FRSFirestorm
Red is Fastest
I'd be done by now if I hadn't decided to cut through a wire that shouldn't have been cut and damn near impossible to splice back together while removing the Nigel harness.
Anyway it works 100%.
I removed the fog light connectors from the nigel harness.
Ran the ground for the LH light here.
Spliced into the Red/White wire at the BCM connector here and ran that to the other side of the fog light connector. Red/White wire is for the LH Fog. White/Red for RH Fog.
Turn on the fog lights at the stalk you get this.
They also work as they should. Leave the fog light switch on and they turn off when you turn off the headlights and back on when when you turn the headlights back on. Bright they turn off. Parking lights they turn off. Only work with the low beams.
Old 04-06-2013, 04:34 PM   #217
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Is there any way that you could make a separate, and clear DIY on how to do this? I have only done a little bit of wiring on my MR2 out of necessity. I am by no means a capable of understanding half of what you have said in this thread. Thanks for your help.
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 04-06-2013, 05:35 PM   #218
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
+1 to this @FRSFirestorm
lbroskee is offline   Reply With Quote
Old 04-06-2013, 06:02 PM   #219
FRSFirestorm
Red is Fastest
I really didn't take enough pictures to make a really good DIY but I'll try and throw one together over the next couple days.
Just finished it up. It works great.
Old 04-06-2013, 08:31 PM   #220
MemphisR
Memphis
MemphisR's Avatar
I like how your method keeps the molesting to the factory harness to a minimum. Thanks for all the efforts you and everyone else put into making this thread!!
Old 04-06-2013, 08:36 PM   #221
norm24
Drives: TSX
^ Totally agree. I'd still like to find out where the red-white, white-red wires terminate in the engine bay. can't thank FRSFirestorm enough!:happy0180:
Old 04-06-2013, 08:39 PM   #222
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Would greatly appreciate it! You're awesome man
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-06-2013, 09:45 PM   #223
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I'm headed out to the garage this evening to take a look. I'll keep you guys posted.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 04-07-2013, 03:45 AM   #224
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Ok, just as @FRSFirestorm said, the red/white wire terminates at the connector for the passenger side headlight.
Whats odd is on the other side of the connector (the harness for the headlight bulbs), a green wire comes out of that pin. I wasn't able to get a picture, but I'll be taking the bumper off later this week to take a better look.
I didn't have the time to take a look at the driver side connector, but I'll look again tomorrow.
Parting out HERE
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 11:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 01:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 06:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 04:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 01:53 AM
