Old 06-09-2015, 07:50 AM   #211
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by carbonBLUE View Post
60 - 80 lbs fromt he engine and the rest might be from the transmission swap. not to mention beefed up drive shafts,different rear dif, more fluids, ect ect
The beefed up alunimum drive shaft weighs 12lbs, stock two piece drive shaft is easily double that....same diff.,... I do have Drive Shaft Shop beefed up axles...Ill take a 10lbs penalty there....more fluids?...maybe, if so the lighter drive shaft easily cancels that out.
cf6mech is offline
Old 06-09-2015, 12:22 PM   #212
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
A fully dressed, dry LS1 + T56 without the exhaust manifolds weighs about 610lbs. The T56 alone is about 125lbs dry. The stock flywheel and clutch is pretty heavy too, about 30-40lbs IIRC. Subtract a few pounds for the power steering stuff that we don't need, so it probably is about a 90lb increase. The bulk of that weight is low, so I don't think it would throw off the CG by much at all. But that's just by eyeballing placement of the engine/transmission.
Originally Posted by Tboxer View Post
...im ready to buy the wepons grade kit...
DON'T.
Parting out HERE
civicdrivr is offline
Old 06-09-2015, 12:22 PM   #213
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Forgot to post couple days ago.
Follow this link.
The first post, top right side.
There's Thread Tools, right next to that is Display Mode.
CLICK Linear Mode!
http://www.vorshlag.com/forums/showt...near#post57858
Lots of info.
They will keep it up to date.
They also state they understand the interest in their swap.
They will let us know, There.
Don't call them, let them work.
Also for pics
http://vorshlag.smugmug.com/Projects...8839&k=t45GCwQ
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
Old 06-09-2015, 12:25 PM   #214
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
^ Unfortunately their last update is from December.
Parting out HERE
Old 06-09-2015, 12:33 PM   #215
Floggin Tires
Understood.
Just hoped it would help with (lots of) general questions.
ZC6-CBS, is home
Old 06-09-2015, 08:26 PM   #216
Streetthrowback
Drives: 2015 brz
I can't wait
Streetthrowback is offline
Old 06-10-2015, 02:39 PM   #217
cf6mech
He is currently working on an update to bring things up to date......stand bye.
cf6mech is offline
Old 06-10-2015, 02:45 PM   #218
cf6mech
Something that I found very curious and disappointing about this car and how they missed the mark in the powertrain quoted below by Mr Fair at Vorshlag.
" All this high tech wizardry doesn't magically make this 2 liter engine produce awesome levels of power, however. Even the 1999-era Honda S2000's F20C engine made 240 hp with 2 liters, normal pressure EFI, and 11:1 compression. The 2013 FR-S makes 200 hp with the same displacement, Direct Injection and a higher compression ratio. When measured the FA20 is making about 160-170 whp, and the chassis dyno measurement shown below on one of our tester's stock 2013 BRZ is typical. "
cf6mech is offline
Old 06-10-2015, 09:42 PM   #219
Genomaxter
Drives: 2013 firestorm FRS
You need to also compare horsepower rating equivalently. The way engines were measure changed in 2005. Many cars "made less power" under the new regulations due to the way they were tested. Now technically they cant make less power but the way the numbers were achieved was changed to make them more accurate. So 240 crank horsepower pre-2005 may be 220 now. Only testing two cars on the same dyno will tell you what is what.
Genomaxter is offline
Old 06-10-2015, 10:09 PM   #220
ls1ac
ls1ac's Avatar
if you would like to watch an ls7 on a dyno---
this is the you tube search name - I do not know how to link
no radical build numbers but heave duty internals for road racing
put in a AC about 2000 lb.
LS7 620HP ATK HIGH PERFORMANCE ENGINES
ls1ac is offline
Old 06-11-2015, 06:29 PM   #221
ls1ac
ls1ac's Avatar
sorry, thought you might like to see a ls engine run before being swapped in a small sports car. that's all.
looking forward to seeing the final build
just passing time
love the ls engines
ls1ac is offline
Old 06-13-2015, 06:04 PM   #222
Fernan Andrade
Fernan Andrade's Avatar
Drives: FRS
When will the parts be available for sale?
Fernan Andrade is offline
Old 06-14-2015, 04:06 AM   #223
cf6mech
Not sure, I'm the prototype customer. All I can advise would be too check Vorshlags Facebook page or web sight.
cf6mech is offline
Old 06-17-2015, 04:48 PM   #224
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Looks like they have it up and running. Interested to see their results
Edit: Fail on my part. Link below by @civicdrivr
DustinS is offline
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 10:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 11:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 09:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 06:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) — General Topics 3 01-07-2013 02:19 PM
