Old 09-19-2014, 09:50 PM   #211
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by troek View Post
ok, heres a log with the newest tune, ive never been able to realy log flkc before, so maybe ive always had this and never noticed. but theres over -1.0 flkc at top. maybe my afr is too lean? or is this small enough to not worry about. everything else seems perfect.
http://datazap.me/u/troek/v206-pull-...-4-5-6-7-10-12
That amount of knock retard is not really much to worry about. But you can always load the 91oct version of the map instead if you want it completely gone. There is no problem with running the 91oct map on 93oct fuel. If i had my way, I wouldn't even have labeled the two map options 91oct and 93oct. But rather "standard" and "aggressive".
Old 09-19-2014, 10:07 PM   #212
troek
troek's Avatar
Drives: 2012 Toyota 86
i may try rescale the maf to get the afr down a bit, or would that not affect it?
Old 09-19-2014, 11:40 PM   #213
steve99
Mate if it was me i would not touch the MAF scaling it looks spot on 0.7% and 0% throughout rpm range and 2% at idle.
If you want to make it richer/leaner adjust the values in the Primary Open Loop Fuel Table.
or even safer just have a read of the knock correction thread below first post and just pull about half the knock correction amounts from the BASE TIMING B table at the rpm load points where their is knock. If you can get it back to -0.6 or less that fine. Then maybe tweek the IAT vs Ignition retard table to make it slightly more aggressive for hot track days and mabe look at the Engine coolant vs retard for a bit of extra safety.
Old 09-19-2014, 11:55 PM   #214
troek
troek's Avatar
good info steve
Old 09-20-2014, 12:19 AM   #215
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
So if we want to be as safe as possible, should we stick with the 91 oct tune over the 93, even with access to 93?
Annahra is offline   Reply With Quote
Old 09-20-2014, 12:40 AM   #216
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
@Shiv@Openflash,
Shiv, I had chance to datalog 2 runs. would you please take a look at it and i am good?
http://www.datazap.me/u/zc06kissther...ta=1-6-7-11-12
Thanks
Old 09-20-2014, 02:26 AM   #217
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Question for you @Shiv@Openflash , I see a Mac OSX folder, does that mean your OFM nows runs in native mac environement or we still need bootcamp ?
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 09-20-2014, 02:28 AM   #218
s2d4
s2d4's Avatar
Yes.
Old 09-20-2014, 02:29 AM   #219
s2d4
s2d4's Avatar
Virtual machines works fine, no need for boot camp.
He may have just used MAC to do the tune files folder filing.
Old 09-20-2014, 02:39 AM   #220
Simon99
Simon99's Avatar
Im a new mac user and cant seem to run anything in VM, im used to windows evironement for 19 years soswitching over to mac is quite different
Old 09-20-2014, 02:46 AM   #221
s2d4
s2d4's Avatar
You can install windows inside VM so windows environment would be exactly what you get. Plug a usb device, it would ask if it wants to connect to mac or VM (windows) so choose VM, done. OFT connected to OFM in windows and inside VM whilst MAC OS still running.
23 years of windows here, granted mostly for work for the last 8 years.
Old 09-20-2014, 09:36 AM   #222
akyp
Drives: 2012 86
Your LTFT looks far better than mine: http://datazap.me/u/akyp/20140918-a00g-01
Maybe I should do the MAF scaling.
akyp is offline   Reply With Quote
Old 09-20-2014, 10:50 AM   #223
troek
troek's Avatar
Yeah, steve's how to is brilliant. Its pretty east to follow.
Old 09-20-2014, 03:24 PM   #224
KonTheory
Drives: '14 FRS
Im not supprised it bogged down on 17x9 wheels with nitto tyres thats serious rubber on a basicly stock car.
check the mod list in his signiture..... lol
I figured maybe the revs werent high enough, in which case do you know how to raise the rev limiter for the OFT, 5800 doesnt seem high enough... lol
'14 Raven FRS - Toyota Badges - Helix Smoked Side Markers - K&N Drop-in - 3" Nameless Axleback 4" Mufflers - Tinted Back Windows - RCE Yellow Springs - Openflash Tablet - OLM HID Kit - Cusco strut bar - TRD Quickshifter - 17x9 Enkei RPF1's with Nitto NT05's
KonTheory is offline   Reply With Quote
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 10:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 09:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 01:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 04:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 10:02 PM
