Old 11-23-2013, 01:01 PM   #2227
KSpider
KSpider's Avatar
Drives: '14 S4
Originally Posted by jsimon7777 View Post
75mm pulley?
Yes thanks for reminder. I'll update post.
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
KSpider is offline   Reply With Quote
Old 11-23-2013, 01:43 PM   #2228
Team STILLEN
Mark @ STILLEN
Team STILLEN's Avatar
Drives: 2015 Subaru BRZ
Is the blower belt slipping?
| Mark Dorman | Performance Specialist | markd@stillen.com| IG @Mark_STILLEN | www.STILLEN.com
Team STILLEN is offline   Reply With Quote
Old 11-23-2013, 04:21 PM   #2229
KSpider
KSpider's Avatar
Drives: '14 S4
Has anyone been having that issue?
Old 11-23-2013, 04:28 PM   #2230
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
That would probably be pretty obvious with the belt squealing.
I'm eager to see this on a 70mm pulley with E85. Or the mythical 69mm pulley. Seriously, I will have a 69mm pulley.
My hope is that the car can run on stock injectors and pump with a 69mm pulley and e85. Or I'd like to know what the stock pump and injectors will run out on E85.
Old 11-23-2013, 04:58 PM   #2231
Gen
Drives: Scion FR-S
According to Bill (Delicious), he's made well over 300 WHP using stock injectors on E85.
Gen is offline   Reply With Quote
Old 11-23-2013, 07:08 PM   #2232
Kodename47
Kodename47's Avatar
Drives: UK GT86
69mm pulley and E85 will require more than stock injectors.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-23-2013, 07:34 PM   #2233
wrxgoose
WUB WUB
Drives: 2013 Firestorm
on my 93 octane tune, with the 75mm pulley, i had to swap out my stock injectors. i was at almost 100% duty cycle
wrxgoose is offline   Reply With Quote
Old 11-23-2013, 08:12 PM   #2234
EAGLE5
Dismember
EAGLE5's Avatar
I keep hearing different things from different people on what the injectors can handle. I don't know what the whole story is.
Old 11-23-2013, 08:27 PM   #2235
wrxgoose
WUB WUB
My friend John, who helped me install the sc, works at Lexus. He hooked one of their diagnostic tools to the car while I drove around, and it showed about 98% for the injectors, and close to max for the pump. He's here on the site, I can have him chime in.
Sent from my VS840 4G using Tapatalk
Old 11-23-2013, 09:39 PM   #2236
EAGLE5
Dismember
EAGLE5's Avatar
I'm thinking that expert tuning can make it work with the current injectors. You can run them at 100% for a short amount of time or start firing them earlier. When I get the Tactrix cable, I will start seriously logging the car's actual stock behavior. Does the stock map fire the port injector when the valve is closed? Things like that. Fuel sprayed onto a hot valve will vaporize while cooling and cleaning the valve. That's one of the reasons I prefer port and direct injection to just direct injection. Don't wanna seafoam like on a BMW 335i.
Maybe Vishnu will chime in on this?
Old 11-23-2013, 09:42 PM   #2237
lex tech
Drives: 2005 kia spectra 5, 2004ford tauras
Wrxgoose brought his frs by my shop after we installed the super charger and he had it tuned a few times. It still had the stock port injectors and fuel pump. I used the techstream, Toyota's factory scan tool, to look at the engine perameters and the injectors were running at 100% duty cycle at wide open throttle and the pump was at 90%. I haven't looked at the numbers after the new injectors were installed.
lex tech is offline   Reply With Quote
Old 11-23-2013, 10:35 PM   #2238
KSpider
KSpider's Avatar
Drives: '14 S4
Who's tune?
Old 11-23-2013, 10:41 PM   #2239
wrxgoose
WUB WUB
Originally Posted by KSpider View Post
Who's tune?
@JuniorAWD is the one who did my tune, and i think thats the only reason im making as much power as i am. Going to have him retune once ive got the fuel pump in, and i think he'll be able to push me past 270
Old 11-24-2013, 02:16 AM   #2240
sw20kosh
Drives: 2013 Black FR-S
He is obviously not leaning on the direct injectors if you are at 100% port injection already. Bill uses the DI much more and support more hp without swapping in new ports
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
