Old 11-17-2014, 04:34 AM   #2255
dkstylezz
dkstylezz's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Trettiosjuan View Post
Stock ECU/mapping? While only the header without a remap works, full header back exhaust mods easily becomes too much for the stock ECU to accomodate over time. Apparently.
Yes its a stock mapping.... As i was driving back home from work earlier, I noticed the CEL was gone. Car drives fine. When the CEL came on i also had a burning smell similar to rubber burning. Nothing like rotten eggs which could indicate a blown cat from what i read on this forum. I made an appointment with a local muffler shop to check for leaks and replace gaskets with new Grimmspeed ones. Will ask them to check the o2plugs and the Catted uel for any possible leaks or cracks.
I'll keep you guys posted as i figure this out.
dkstylezz is offline
Old 11-17-2014, 08:27 PM   #2256
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Has anyone else had a CEL come up, even with a tune? And has anyone had an issue with the cat itself going bad?
Please do!
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline
Old 11-18-2014, 01:23 AM   #2257
EpicNameBro
Drives: Slow...
Although not too common there are others in this thread who have had a similar issue but i don't know if a problem was found. Everyone usually resorts to a tune eventually... I almost pulled the trigger on one until i saw some have a CEL and i held off. And now that JDL is in the process of making a catted UEL it's just a waiting game. Glad these companies are making some great pieces...
Edit: I myself do not want a tune by any means...until the warranty runs out.
EpicNameBro is offline
Old 11-18-2014, 02:10 AM   #2258
dkstylezz
dkstylezz's Avatar
Im on the same boat. didnt want to tune my car until the warranty is over. Well the CEL is not coming back did some canyon driving today. tomorrow morning i have an appointment to check everything so will keep yall posted.
Old 11-18-2014, 03:39 PM   #2259
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
The catted header was only tested ( as that is what the community asked for ) on a stock car to not throw a CEL. If you start adding other bits like intake, exhaust and etc you start to mess with the volume of the air moving through the system now which can throw CEL's at the cat then.
You definitely should get a tune if you are doing multiple mods.
-Jeremy
FT-86 SpeedFactory is offline
Old 11-19-2014, 10:56 AM   #2260
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
-Jeremy
I'm having the same P0420 code with the Catted UEL header. Taking your advice (Jeremy), I have put the airbox back to stock (even the stock filter) and put the tune back to factory. I cleared the code as well. So, if it keeps popping up, it's either the O2 sensor or the cat.
Thanks.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline
Old 11-20-2014, 07:19 PM   #2261
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
My car is running a TRD intake, TRD catback and FT86SF UEL Catted Header. After 4000 miles with no tune and no CEL, I brought it in for a Toyota/Scion 30K service. Since then, I have had a CEL P0420 4 times.
Last week, I installed a Stage 2 OFT UEL/91 Tune. Night and day, folks. NIGHT and DAY. Do yourselves a favor and get a tune if you are running more than one bolt-on engine/exhaust upgrade. Car is smoother, throttle more responsive, better torque cruising and spirited driving. I might need better brakes now as the speed catches me by surprise!
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline
Old 11-20-2014, 09:30 PM   #2262
nunonuna
nunonuna's Avatar
Make sure you do enough data log to see if the stg2 is safe. I went back to stg1 after few weeks of trying stg2 due to FLKC dropped to -1.3 and IAM dropped to -0.83 as well. Gas was good because it never had a know problem on stg 1 with same gas. Car has full engine back exhaust with even secondary cat deleted. Also, as other member told us few comments back, no significant power gain over stg1 tune I can notice. It is still DAY with stg1 and worry free mind~ so I went back.
Take a look at my data log below.
http://www.datazap.me/u/fa20frs/1105...4&zoom=44-2349
The logging was done after few hundreds miles of learning.
nunonuna is offline
Old 11-20-2014, 10:54 PM   #2263
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
After hearing you guys talk I can't wait for my header. Looks like an OFT is next on the menu.
Sent from my Galaxy S4 using Tapatalk
AllStar0419 is offline
Old 11-20-2014, 11:15 PM   #2264
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Originally Posted by RFB View Post
Did, but I may have something better, cheaper, simpler, more effective, especially when coupled with oil coolers.
CERBERUS
Updates?
Sent from my OnePlus One
drewbot is offline
Old 11-20-2014, 11:21 PM   #2265
nunonuna
nunonuna's Avatar
OFT + this header feels very good~ You will love it.
nunonuna is offline
Old 11-21-2014, 01:38 AM   #2266
Re~Mix
Re~Mix's Avatar
At this point I have yet to log anything. I was going off the advice of FT86SF and a local tuner shop, who said to do stage two with full exhaust modification. I can try logging one of these weekends and see if anything odd comes up.
Any other folks having issues on Stage 2 vs Stage 1?
15' 228i MSport
Re~Mix is offline
Old 11-21-2014, 02:47 PM   #2267
nunonuna
nunonuna's Avatar
I even tried to pull Virtual Dyno on OFT logs of each stg1 and stg2 on same road with almost same weather condition. The result is no significant power difference between two. I know its not real Dyno so the number of HP/tq is not accurate but at least good enough to get comparison of two logs.
nunonuna is offline
Old 11-21-2014, 09:24 PM   #2268
chas3wba0
chas3wba0's Avatar
Drives: Yes
I've also run both OFT Stage 1 and 2. No noticeable difference in power, so staying with Stage 1 to be safe.
Here's a random sound clip:
[ame="https://www.youtube.com/watch?v=DiJafC90N08&list=PL-yYtv6mizg6LnXijtKs3sLeSdnZpF2qV&index=11"]BRZ exhaust: Catted UEL header+catted front pipe+catback, Encore - YouTube[/ame]
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
chas3wba0 is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 11:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 01:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 01:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 01:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 11:12 PM
