Old 12-07-2013, 11:45 AM   #2311
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Well, belt got eaten again.
Sent from my VS840 4G using Tapatalk
wrxgoose is offline   Reply With Quote
Old 12-07-2013, 12:48 PM   #2312
DriftEm
DriftEm's Avatar
Originally Posted by Ryan86 View Post
What max oil temps were you hitting after your install?
How did you or anyone determine a oil cooler is now critical to have?
Interesting to see what the decisions are based on.
We tested here thoroughly at 38deg C and oil temps did not exceed 126deg C, which our cars are good to over 130degC.
Now what may help us is Toyota use 5W30 fully synthetic oil, were as you are on 0w20 if I'm not mistaken.
What would be more beneficial to us here is additional water cooling to get the charger temps down.
I was getting to 126degC on aggressive runs up mountain roads, yes, our cars might be good for 130degC, but I have noticed power lost over 115degC.
After installing the oil cooler, with same driving conditions, I'm not getting over 105degC and the engine is very happy.
I'm running 5W30 full synthetic oil already.
DriftEm is offline   Reply With Quote
Old 12-07-2013, 12:57 PM   #2313
DriftEm
DriftEm's Avatar
how many so far? are you using the race belt or just the normal one?
Old 12-07-2013, 01:01 PM   #2314
wrxgoose
WUB WUB
This is the second belt that's eaten itself. This time, it decided to eat a wiring harness too, though. Car won't crank,
Old 12-07-2013, 01:11 PM   #2315
DriftEm
DriftEm's Avatar
That sucks.
I've have one belt fail on mine so far. My installer noticed the idler pulley that comes with the kit is seating too far in so the belt does not seat in middle of this pulley, the front edge of the belt is riding on the edge of the pulley, this could be putting too much stress on the belt and causing failures. I'm not sure if this is just my kit or all kits are like that. We got a call to Innovate for advise. I want to just use a washer to move the pulley forward to have it line up correctly.
Old 12-07-2013, 01:21 PM   #2316
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Definitely sucks. When installing the belt, make sure to properly shim the pulley prior to the supercharger pulley. From what we have seen all the pulleys are slightly different with respect to their offset and because of this they are all not the same.
So with this in mind you will want to shim the pulley so it sits as close to the middle of the pulley as possible while the vehicle is running. Something HG Motorsports has picked up on after multiple installations.
Cheers,
William Knose
Old 12-07-2013, 01:22 PM   #2317
wrxgoose
WUB WUB
Thanks. My friend and I are also thinking about trying to fab up a small plate to act as a bigger lip for the blower pulley
Old 12-07-2013, 01:53 PM   #2318
Touge_ninja
Sending rods to their doo
Touge_ninja's Avatar
Drives: 700HP STi
@DarrenDriven might wanna take me off the list.... could not wait any longer and went with a different kit.
Touge_ninja is offline   Reply With Quote
Old 12-07-2013, 05:18 PM   #2319
wrxgoose
WUB WUB
okay, so basically it's the tensioner that i'm having issues with. it's got too much play in it when i get on it, and that's why the belt is slipping off the pulleys.
this is what happened today:
basically the belt grabbed the harness, tore it up enough so wires touched, and shorted out my EFI fuse.
Old 12-07-2013, 08:55 PM   #2320
xjohnx
Grip>Slip
xjohnx's Avatar
doh, that stinks.
my intercooler comes in this week. any of you guys that have done it already have any install tips?
Old 12-08-2013, 02:40 AM   #2321
sw20kosh
Drives: 2013 Black FR-S
My tensioner has wobble/play too when the motor is spinning. I just assumed that is what a tensioner does when the motor is spinning... How much wobble is standard?
P.S. Anyone know how much a new tensioner costs? Never had any problems with my belts luckily. I did shim my idler pulley so the belt sits in the middle of the pulley.
Old 12-08-2013, 10:24 AM   #2322
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Had a dyno day with Furious & Fast
@Delicious Tuning, Bill has my car tuned in so well.
Here is chart stock 86 vs Delicious Tuned Sprintex
Converted 250whp 206ftlb
I used 95 RON (91 OCT) with a can of Torco Octane Booster
To show you how effective Torco is, we put a stock 86 on the dyno, 119wkw, added Torco ran dyno,again got 129wkw
Ryan86 is offline   Reply With Quote
Old 12-08-2013, 10:26 AM   #2323
Ryan86
Road Warrior
Ryan86's Avatar
All new wind tunnel 4 wd load inertia dyno
Old 12-08-2013, 02:08 PM   #2324
sw20kosh
Impressive! What pulley are you running? What sort of max timing are you seeing during WOT pulls? Should be something like 25 deg towards redline?
I do love my torco. Keep a bottle in the trunk with me. I always use it at the track.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
