Old 06-13-2017, 04:46 PM   #2339
armstrom
Drives: none
Originally Posted by 86fun View Post
Mine does this, the battery will be dead in two weeks if I don't charge it or drive a long distance. It's definitely the IC water pump too, I can see the fluid turning in the reservoir. I wondered if it had anything to do with the FOB and keyless entry crap, or maybe the LED lighting on the anniversary edition I have. No clue, but a pain in the ass to keep it on a trickle charger all the time.
The Edelbrock kit taps the EVAP solenoid harness for switched power to drive the water pump relay. I don't have specifics but it is not uncommon for emissions controls to be active at any time, even with the car off. My wife had a leased Scion IQ that I would sometimes hear whirring away hours after it had been turned off. It's possible that some other system that shares the same circuit as the evap solenoid is being turned on. Would have to take a look at the wiring diagram.
Or, you could have a problem with a sticky solenoid.
-Matt
armstrom is offline   Reply With Quote
Old 06-13-2017, 07:54 PM   #2340
FuzzyFunk
Drives: FRS Monogram
This may have been addressed before, but has anyone or Edelbrock state what this sc is capable of with a built motor, e85, smaller pulley, headers, etc. ? What numbers are we looking at?
FuzzyFunk is offline   Reply With Quote
Old 06-13-2017, 09:09 PM   #2341
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
420whp, some youtuber got his engine built with E85 and a smaller pulley tuned by Delicious Tuning
Alltezza is offline   Reply With Quote
Old 06-13-2017, 09:54 PM   #2342
armstrom
Drives: none
Yeah, I still don't get that build. He kept the stock compression ratio so he can't make any significant power on pump gas due to having to retard the crap out of the timing. If it were me I would have built to 10:1 CR and installed the smallest pulley possible. Different strokes I guess...
-Matt
Old 06-14-2017, 12:36 AM   #2343
Icecreamtruk
Drives: Track preped NA FRS
-Matt
You dont, thats why you use E85, because it has a lot more resistance to knock (detonation). Lowering the compression ratio would lower power, as the supercharger itself is pretty maxed out with the smaller pulley. You would lower the compression for a turbo build, where you can just put a bigger turbo and build more boost.
Old 06-14-2017, 12:56 AM   #2344
Alltezza
Alltezza's Avatar
-Matt
I'm unsure, what his thought process was. Tbh I don't think he really had a thought process all he wanted was a "built" engine to support and join the 400whp+ club. And he got what he wanted.
Old 06-14-2017, 02:20 AM   #2345
armstrom
Drives: none
I'm fully aware of the role E85 is playing here. However availability in most places is spotty at best. Boost and compression make power in different ways. A high compression ratio increases the thermal efficiency of the combustion process but you are still ultimately limited by the mass of oxygen (and fuel) the engine can ingest. Forced induction raises the cylinder pressures like increasing CR does, but also greatly increases the available oxygen mass to be burned. Yes, in an ideal world you would have the best of both, but that means you must have high octane fuel to resist preignition at such high cylinder pressures and temperatures. If a compromise must be made to run on pump gas then "pound for pound" you'll make more power safely with higher boost and lower compression.
You can only retard timing so far without skyrocketing EGTs.... Of course, you can fiddle around with valve timing to reduce cylinder pressure also, but why not just build the engine with a better balanced CR to start with?
Sent from my XT1650 using Tapatalk
Old 06-14-2017, 02:30 AM   #2346
armstrom
Drives: none
OK, I went and read the post about his setup... He is already on the smallest pulley so I guess if the goal was only big power on E85 the I suppose I get it... But only making 280 HP on pump gas is a bit disappointing. If you have consistent access to E85 then you can treat that power level as a fallback. I would still trade some of that max power on E85 for some more power on pump gas, but that's purely a personal preference. I don't like to run my cars on the ragged edge all the time.
Old 06-14-2017, 04:51 PM   #2347
280whp on that dyno is no joke.
A stock BRZ dynos 150ish on it. I'll let you do the math.
Old 06-14-2017, 08:01 PM   #2348
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
420HP is nice, but why? I know people love to quote numbers but in reality, my Edelbrock supercharged car makes 323 at the wheels on e-85. That is more than 200 tread wear 255's can handle off the line. 0 to 60 in 4.9. On the track it's a nice balance between power, traction, and my driving skills. I really see no need for more power my self.
Lunatic is offline   Reply With Quote
Old 06-14-2017, 09:16 PM   #2349
armstrom
Drives: none
I'm not saying 280WHP isn't a nice number. But when you consider the car is making ~420WHP at the same boost level on E85. That's a big gap for no increase i boost. To me that means the pump gas tune is leaving a LOT on the table just so it can survive the high compression ratio. I would rather have a car that makes mid 300s on pump and maybe high 300s on E85. Again, just a personal preference. Of course, E85 is nearly impossible to find near me so that might have some influence on what I would do with my own car
-Matt
Old 06-14-2017, 10:43 PM   #2350
Lantana frs
Drives: 13 frs red
E85 allows the cr to be used. Pump gas makes tuning a compromise.
Lantana frs is offline   Reply With Quote
Old 06-14-2017, 10:53 PM   #2351
armstrom
Drives: none
Yep, that's pretty much my point. Clearly E85 is the superior fuel for making power. It lets you "squeeze the balloon at both ends" so to speak. But for many people the "compromise" of pump gas is all that is available to them. With a lower compression ratio you wouldn't have to sacrifice so much power to run on pump gas. Yes, you give up some of your maximum power potential when running on E85 but your power doesn't fall off a cliff just because you can't find corn juice somewhere. I mean, at some point when does E85 become a compromise? If I could just run on pure alcohol I could squeeze out even more power, or how about nitromethane? At some point everything is a compromise.
Old 06-14-2017, 11:21 PM   #2352
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
I believe TJ hunt did this and posted to you tube. Unfortunately you have to deal with that, but the data should still be visible with the volume Muted 👍🏼
Silverfox is offline   Reply With Quote
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
