Old 06-27-2013, 11:58 AM   #225
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I have no empirical data to back this up as I wasn't monitoring temps, but last month at Road Atlanta in 86 degree ambient temps I could feel my BRZ start to lose power at the end of my sessions on track running without an oil cooler and fresh factory 0W-20. It just felt a little weaker compared to the beginning of each session. 93 octane with Torco Accelerator, Intake and axleback are my only mods that would affect performance otherwise.
Perrin OC kit is on the way to me now. EDIT: Backordered with no ETA. Go figure...
Old 06-27-2013, 12:56 PM   #226
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Dammit, this is the last thing I wanna hear
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 06-27-2013, 02:34 PM   #227
Midtenn
Drives: 1995 Mazda Miata
Spend the money, its cheap insurance and piece of mind. If you're DIY minded, it doesn't take much to setup an oil cooler and come out cheaper than a kit.
Midtenn is offline   Reply With Quote
Old 06-27-2013, 04:34 PM   #228
wootwoot
Drives: FRS
Indeed. But the important question, in my mind, is what temp thermostat is optimal. At this point I am thinking 200F or even 220F given the data we have available.
wootwoot is offline   Reply With Quote
Old 06-27-2013, 04:49 PM   #229
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Will any or all these "cooler" car mods help minimize the awful change in character this car gets into when the AC is on? The overal change in throttle response and shift timing really puts a damper on the drive and snappyness of the car when the compressor is off.
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 06-27-2013, 08:48 PM   #230
deange
Drives: Black 2013 BRZ Limited Automatic
The Perrin kit is backordered because they are having some problems with them. I got mine and this is what happened:
thread
I'll either just piece one together or look elsewhere. I'm wishing I would have just given one of the robispec ones a try since I did the radiator anyhow.
deange is offline   Reply With Quote
Old 06-27-2013, 11:45 PM   #231
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
thread
Uh oh, that's not good.
I will say that one thing that does concern me about an aftermarket oil cooler is adding additional failure points, and any possible strain that might be put on the oil pump to run the fluid through the cooler and lines as well. I'd like to keep this car as stock as possible during the warranty period just in case, and if something were to happen to the motor, I could see this being an issue. Just my opinion though.
smbstyle is offline   Reply With Quote
Old 06-27-2013, 11:51 PM   #232
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
There are additional points of failure for sure. That's why I have my pressure sender immediately after the cooler now so I'll know if there's any failure right away. However, I've had zero issues with the mocal bits and the one pictured looks slightly tweaked.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-29-2013, 09:56 AM   #233
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Just tracked my car last night in 100F + temps for 20 minutes x 3 sessions + 20 minute cooldowns.
Verdict: I didn't log my temps but had no noticeable issues all evening. IMO you don't absolutely *need* an oil coller for casual track use but it'd probably be a good idea if you're going to be tracking often and aggressively.
Particularly the Robispec unit - why mess around?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 06-29-2013, 03:45 PM   #234
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
I'm going to try something different with cooling and put in a Mocal laminar flow system. I know this isn't the best route, but it's not that expensive and easy to install. I'm going to hook to the stock radiator at the hose that feeds the engine in hope of getting the coolest water at the expense of having the oil warmed up as quickly. It will be interesting to see what happens.
I'm thinking that for my DD and a few auto-x here and there this might just be okay. I'll let you know how it works. Any thoughts would be appreciated.
mtimney is offline   Reply With Quote
Old 06-30-2013, 05:45 AM   #235
cf6mech
Drives: FRS Silver LS1 swapped.
Where is it mounted and how obstructed is the airflow?,....curious as I have a Perrin,... mounted on front crash bar and does not have direct airflow to it,...kind of obstructed a bit.
cf6mech is offline   Reply With Quote
Old 06-30-2013, 06:09 PM   #236
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Next time we are both at Sebring we should use your scangauge in my car to compare the OEM reading vs the one from the Defi. I placed the sensor right after the cooler so it will be reading lower, just curious how much lower...
I installed my Defi DIN-Gauge this weekend with a sandwich plate for the oil temp/pressure sensors. I went out for a couple of casual 30 minute drives. The DIN-Gauge and my Scangauge were showing almost the same temp the whole time; within a degree or two of each other.
BatStig is offline   Reply With Quote
Old 06-30-2013, 06:28 PM   #237
swift996
swift996's Avatar
According to the Torque PID, I was hitting about 270 degrees yesterday at the track. Running Motul 300V oil.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-30-2013, 06:59 PM   #238
swift996
swift996's Avatar
Here is a data log from my first session. I was behind a guy who was causing a traffic jam so I pulled into the pits to get some space (you will see my idle before heading out - 1 lap - and then idle in the pit for a couple minutes):
This was the most conservative session I had as it was in the AM and my first time at this track. The next 3 sessions (which I didn't log) I was pushing it a LOT harder. Ambient temps were probably around 75 or so.
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 09:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 05:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 06:42 PM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 10:48 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 01:55 AM
