#225 |
Drives: 2014 Subaru BRZ LTD 6MT
Couldn't a front engine car still have an ideal rearward bias weight ratio? IE, the LFA. Make the rear end a Trans axle.
#226 |
yeah but its super hard and expensive and then all the weight is all outside of the wheels. nobody is going to spend more money to make a car worse.
Drive upgrades. Don't buy them.
#227 | |
Time Traveller
In comparison to the 86, the 370z, Mustang, Camaro and Genesis, have no excuse to be such fatties and thus deserve 500 and even 1000 lbs of criticism. What besides power do they bring above an 86 (given equal tires)? |
#228 | |
#229 | |
Time Traveller
The Mustang, 370z, Gen coupe, and Camaro are fat because they're built on modified passenger car platforms (some decades old). The Miata and 86 ride on dedicated sports car chassis w/ various degrees of suspension. I get what point you're trying to make, but I don't think your example holds up. I don't believe the test wasn't "rigged" per se. However there was easily detectable advantage provided to the Miata which ran the track with $6500 worth of brand name factory mods, while the BRZ had stock performance and cosmetic mods. Mazda certainly could have provided a base car for the test and Motor Trend could have held off making the comparo and just did a review of the Miata until they found two that more fairly and directly compared. As far as I can tell Mazda is only loaning out upgraded cars to the press. And it looked like Motor Trend got the story they were trying to spin because of it. The negative response to the performance part of the article is in regards to this. |
#230 | |
Plenty of people DD Miata's and have them as their only cars. |
#231 |
Is a Mustang GT just a Mustang V6 with $8k of performance mods?
#232 | |
Time Traveller
A lot of people use a butter knife as a screwdriver, does that mean it was designed to be one? If you're going to argue that Miata's were designed to be practical daily drivers in the same way an 86 was just because some people use them that way I don't know what to tell you that might actually make sense to you. |
#233 |
Drives: '13 BRZ, '06 997, Other Things(TM)
I don't really see the Miata and the BRZ as competitors. They're both cool, though. In my mind, the new Miata's real competition is a used Elise, since they're about the same price and very similar in terms of practicality (or lack thereof).
#234 | |
Time Traveller
Also the full engine upgrade Mustang GT you mentioned is not really comparable to the Club Miata performance variant (with mostly bolt-on's). Yet another transparent reach. Please stop. |
#235 | ||
Drives: 2013 DZE/01 (sold for MX5 ND1)
I've read many posts in this thread about the virtues of the Miata's lightness.
#236 | |
Drives: '23 BRZ
Anyway, you can get rearward weight bias in an FR car without resorting to moving the trans aft. I think it's a bad idea in general, and particularly for a small inexpensive lightweight sports car. You'd end up with a longer wheelbase, more weight, higher yaw inertia/polar moment, and you probably wouldn't move the c.g. aft much if at all. |
#237 |
Drives: 6MT Hot Lava
personally, I am jealous of the miata's lightness and what is said of its transmission. that being said, i still much prefer the styling and size of the twins. if only the frs/brz weighed around 2400-2500lbs.
i think the new miata is awesome. but i also think that its almost "too small". same thing with the lotus elise. i think the size / styling of the frs / brz are perfect except they could be just a tad bit lower. |
#238 |
Drives: AP2 S2000, S14 240sx
| 4th gen ND Mazda MX-5 Miata | Dark | Other Vehicles & General Automotive Discussions | 1392 | 12-16-2021 02:09 PM |
| Twins vs 2016 Miata (ND body style) will be revealed in 15 minutes | glamcem | FR-S / BRZ vs.... | 56 | 09-13-2014 07:11 PM |
| 2016 mazda miata (MX5) reveal 9 PM EST | Ernie L | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-03-2014 09:41 PM |
| Motor Trend Car of the Year... | Dorb | BRZ First-Gen (2012+) — General Topics | 1 | 11-13-2012 08:33 AM |
