Old 07-13-2015, 08:47 AM   #2367
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Originally Posted by willharp360 View Post
So I'm having issues while driving my car. Anytime that I give it throttle the car resists and then jerks back and forth a few times, doesn't matter what gear I am in. That's the best way I can explain it, anyone have the same issue or know what it could be?
I had the same issue but it was fuel delivery on my Turbo Busa. Double & triple check everything with the fuel pump. Did you transfer the factory fuel pump housing o-ring and add 2 more than came with the pump? Idle fuel pressure maybe fine or manageable with a missing o-ring but when its time to give if gas the pig will kick and spit.
Give us a follow up
GsxrMe is offline   Reply With Quote
Old 07-13-2015, 09:55 AM   #2368
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It just started yesterday and I'm still on the basemap right now
First thing I always tell people to check is whether or not the Tial Q BOV is opening up at idle or in high vacuum situations. If it is opening, that is most likely your issue as it causes turbulence in the air flow across the MAF sensor which causes large swings in fuel.
Old 07-13-2015, 04:25 PM   #2369
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Originally Posted by xDBOYx View Post
This is what I'm using. Search atp quick tap. Idk how well it works since my car still isn't up and running yet.
just picked mine up from FRSPORT. going to be installing tomorrow wish me luck.
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 07-13-2015, 07:09 PM   #2370
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
just added my quick tap to the elbow bend for the compressor housing.
Flex Fuel Turbo BRZ
Old 07-13-2015, 08:03 PM   #2371
willharp360
Give us a follow up
LJ sent me a revised map and so far it is running much smoother. Just need to drive it for a few days and make sure everything stays good. Thanks for y'alls help!
willharp360 is offline   Reply With Quote
Old 07-14-2015, 10:51 AM   #2372
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Remember it is just a basemap. You need to get it properly tuned.
Old 07-14-2015, 11:41 AM   #2373
willharp360
Yeah that is definitely next on my list to do
Old 07-14-2015, 05:51 PM   #2374
FullBlown
FullBlown's Avatar
Drives: Scion FRS
That is correct, we leave our maps on the conservative side and recommend a tune to dial her in properly.
FullBlown is offline   Reply With Quote
Old 07-14-2015, 06:10 PM   #2375
King Tut
NASA SpecE30 Racer
King Tut's Avatar
LJ being conservative, never. When you gonna take down that new horsepower record that seems to need so many threads?
Old 07-14-2015, 08:15 PM   #2376
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Uploaded my flash and go tune by delicioustuning and my car stalls at idle or feels like going to stall
4 bar fbm map sensor
550cc injector
91 pump gas
What u guys think?
Flex Fuel Turbo BRZ
Old 07-14-2015, 08:16 PM   #2377
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
The best was you I could describe MAF turbulance on a FBM turbo car is that it would feel like someone was *lightly* tapping on and off the brakes repeatedly.
If you think it may be turbulance and not a fuelling issue the quick look places are the long silicone pipin behind the pass headlamp (is it pinched) On the BRZ they reccomend you unplug the clips that hold the wiring but in the end it still ends up with a slight kink. The second place to check is a the MAF sensor. Unplug and clean it. It is very easy to get a bit of oil/blow by from a fresh install on it (since it is on the underside of the charge piping.) Also tripple check the O-ring around the MAF sensor. You may want to use a bit of RTV to ensure it is 100% sealed around it.
Old 07-14-2015, 08:20 PM   #2378
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
550cc injector
91 pump gas
What u guys think?
If you give it gas and hold the revs at 1500 or 2k is it pretty smooth? Vac leak?
Make sure you have all the vaccuum lines correctly installed. IMO it was easier to run all the lines without the EBCS to make sure the car was running well. Then add the EBCS and tune for it. Start simple and then add to her.
Old 07-14-2015, 10:48 PM   #2379
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
held it at 1500-2000 and it goes down about 500-750rpm then back up
i removed my EBCS and only have the WG/BOV connected to vacuum and
still idles rough as if its misfiring.
i contacted delicious and they told me to check the direct injector black metal covers to make sure its making ground and i removed and check them both and it still does it.
anyone got any idea of what it is?
heres a log of my
rough idle and i stalled right at the end..
http://datazap.me/u/brztoni/log-1436...-9-12-13-14-28
Flex Fuel Turbo BRZ
Old 07-21-2015, 02:47 PM   #2380
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Hey guys. Here are the pics you guys wanted to see.
Sorry it took so long. I took them but tapatalk had issues with my image resolution so I had to do it on a computer.
@mashal @King Tut
Catch can with filter to vent to atmosphere.
Weather stripping to make the seal work better
It's hard to see, but just past the latch and under the metal bracket, you can see a layer there. It's some sort of weather proof material my dad had in his garage. It worked perfect. I'll try to find exactly what it was I used. But it is essentially another layer that makes a seal to stop water from going past the holes underneath the metal bracket.
Rust forming around mounting holes. This car has never seen salt from the winter.
More rust
blackfireball5 is offline   Reply With Quote
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
