Old 09-23-2022, 03:47 PM   #23843
new2subaru
Weight Weenie
Drives: 15 FR-S
Went to the track.
I was all over the place and couldn't get it together. Couldn't focus. Left early..
Old 09-23-2022, 05:35 PM   #23844
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Gave it a good wash today
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
Old 09-24-2022, 08:08 PM   #23845
SoCalHANZ86
HANZ
SoCalHANZ86's Avatar
Drives: 2014 frs
changed brake fluid.
SoCalHANZ86 is offline   Reply With Quote
Old 09-25-2022, 08:19 PM   #23846
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Installed STI motor mounts and took out the torque solutions mounts. So much quieter. Feels OEM, very happy
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 09-25-2022, 11:55 PM   #23847
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Full Exterior detail with ceramic coating.
The car is sitting in my friend's garage for a couple days to cure.
Shots from final polish before coating.
https://imgur.com/a/OilkUfA
Post coating shots
Old 09-26-2022, 01:46 PM   #23848
StraightOuttaCanadaEh
Wes
I'm also planning on replacing my perrin engine mounts with the sti mounts. After about 3-4 years on them, it's gotten annoying.
Instagram: @gt86ws
Old 09-26-2022, 03:27 PM   #23849
DarkPira7e
DarkPira7e's Avatar
Go through Nengun, I got mine for like $230 shipped or something and they came quick
Old 09-28-2022, 01:41 AM   #23850
strat61caster
strat61caster's Avatar
Pulled oil pan, looked at sparkles.
ineedyourdiddly
Old 09-28-2022, 01:50 AM   #23851
soundman98
ProCrastinationConsultant
soundman98's Avatar
i always said it's a bad idea to rent out cars on turo. before you know it, they're on stripper poles trying to earn it one buck at a time.
Old 09-28-2022, 09:40 AM   #23852
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Sounds like the voice of experience. Do you do private parties?
Old 09-28-2022, 01:54 PM   #23853
Ultramaroon
not playing cards
Ultramaroon's Avatar
Gonna DIY?
Old 09-28-2022, 03:05 PM   #23854
Old 09-28-2022, 03:07 PM   #23855
Old 09-28-2022, 03:51 PM   #23856
strat61caster
Gonna DIY?
Yeah, most reasonable option to get back on the road seems to be to order an oem shortblock, going to do that today, pull engine over the weekend, hopefully back together by next weekend. Disassemble short block at leisure and see if it’s salvageable to hold onto as a spare. Smells like the typical #3 crank bearing failure, engine died as I was getting my time slip after my 4th autox run, data shows it was pulling power during that run.
Sketchy ‘junkyard’ engines are $3-$4k, slightly less sketchy jdm engines are like $5-6k and my time is cheap right now because I quit my job.
ineedyourdiddly
