Old 10-23-2022, 06:24 PM   #23941
Teseo
Drives: frs
Originally Posted by villainous_frx View Post
First snow day with the car. Didn't have space to store the car or get another, so she's on daily duty for this winter. In ~4" of Calgary slush the car did great with the 215 Kumho Wi31's, no complaints or loss of traction that wasn't self inflicted
Make the habit to "flush" the car underside after driving it
Old 10-23-2022, 06:29 PM   #23942
soundman98
ProCrastinationConsultant
soundman98's Avatar
And the wheel well lips. 90's Chrysler taught me if I let the crud collect there, there will be no fender to care about later!
Old 10-23-2022, 10:15 PM   #23943
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
How are you supposed to get to upgrade anything if you take such good care of the existing things?! Sometimes you need to invest in the future.
"Ah yeah sweetie, look, the car won't pass inspection because of the rust Guess I need to get carbon fiber fenders.."
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 10-23-2022, 11:43 PM   #23944
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Do people not do this already? And if I were to wash it every time I drove it, that would be 3-4 times a day!
Those get so nasty so quickly, every time I have the car in the air I peel back the fender liner and clean them.
Carbon fenders aren't my style, but I like your thinking
villainous_frx is offline   Reply With Quote
Old 10-24-2022, 12:37 AM   #23945
DarkPira7e
DarkPira7e's Avatar
I want the Chargespeed front bumper and fenders so bad. It's a good thing I don't like painting anything
Old 10-25-2022, 05:50 PM   #23946
DarkPira7e
DarkPira7e's Avatar
Replaced some crusty bolts with zinc plated bolts or fresher looking ones (if I didn't have the right size in zinc).
Mostly chassis hardware that wasn't touched when doing the engine. Zinc bolts I got from the AdamLZ drift kit (overpriced, you can get directly from boltsandnuts.com) most other bolts are spares from who knows where/ when
Old 10-25-2022, 11:38 PM   #23947
WildCard600
WildCard600's Avatar
Drives: 2020 86
Did some bracing. (I don't care if they don't "do anything". I think they help.)
WildCard600 is offline   Reply With Quote
Old 10-26-2022, 01:13 AM   #23948
humfrz
Welp, they sure are perty -
Old 10-26-2022, 01:58 AM   #23949
strat61caster
strat61caster's Avatar
I started it.
This is what it looked like about 5 hours before I drove it.
Taking bets on number of oil leaks by the 1,000 mile mark.
ineedyourdiddly
Old 10-26-2022, 02:09 AM   #23950
DarkPira7e
DarkPira7e's Avatar
I started it.
Jesus, quick work. Awesome job!
Old 10-26-2022, 02:28 AM   #23951
strat61caster
I had practice, I had it all together Sunday night and it wouldn’t start, did the timing wrong the first time, turned clockwise instead of counter clockwise. Lesson learned, all the timing marks should line up at the same time at least once.
ineedyourdiddly
Old 10-26-2022, 08:22 AM   #23952
I used to get a season pass for a touchless wash and do it two or three times a week. Didn't help much for the lightly painted parts (as you know) but no doubt made a difference overall.
Mind you it would be just as bad again after 45 minutes on the 401 but I felt better about it!
I see that the big chip in the front fender remains about the same after 8 years of exposure so unlike the roof that will rust at .001% humidity the lower body stands up really well!
Old 10-26-2022, 03:08 PM   #23953
Teseo
Drives: frs
Don't ruin your engine with silicone
Old 10-26-2022, 03:30 PM   #23954
strat61caster
I just remembered, I had a really loud ticking on start up, seemed to go away after 3-4 minutes, right now my assumption is that the valvetrain wasn’t lubricated well enough and it took awhile for oil to find its way into the lifters and roller rockers. Maybe I’m too tight on the valve lash, we ended up on the low end of the spec, will see when I cold start it later today.
ineedyourdiddly
