Old 12-26-2013, 06:29 PM   #2409
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by whataboutbob View Post
Those plastic fittings are BSPT. I've been working on getting my intercooler in over the last week and will be replacing the 2 plastic fittings with new ones without the 90degree bend.
To quote an email I got from Innovate on this:
"The plastice fitting specs are the following brake booster or closest to passenger side is a 1/4BSPT to 10mm barbed 90deg fitting, the EVAP or closest to the drivers side is a 1/4BSPT to 8mm barbed 90deg fitting. If you choose to replace please make sure that the thread specs are replicated as severe damage will occur to threads on the casting if failure to do so."
Thanks for the heads up
Old 12-26-2013, 08:59 PM   #2410
DriftEm
DriftEm's Avatar
I've had the intercooler kit for couple of weeks and today the fuse for the pump blew out. Pump stopped working and the coolant fluid over heated and over flow out of the coolant reservoir. Changed the fuse and it's working, I'll contact Innovate and see what they say. I'm not sure why the pump is over loading the fuse.
DriftEm is offline   Reply With Quote
Old 12-26-2013, 09:00 PM   #2411
brianhj
Drives: 2017 Camaro 1SS
Are they going to fix this thread/forum? I can't see replies
Sent from my SGH-M919 using Tapatalk
brianhj is offline   Reply With Quote
Old 12-27-2013, 03:40 AM   #2412
KSpider
KSpider's Avatar
Drives: '14 S4
Let me know if what you do works well, and then you can help me do it ; )
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
KSpider is offline   Reply With Quote
Old 12-27-2013, 09:25 AM   #2413
xjohnx
Grip>Slip
xjohnx's Avatar
@whataboutbob - I too would love the part #'s you up using.
Old 12-27-2013, 12:12 PM   #2414
Calum
That Guy
Drives: 2013 asphalt FRS MT
British pipe thread, FML.
Guys, when replacing these of course getting the proper thread is important but also be careful of galvanic action between dissimilar materials.
Does anyone know what material the original fittings are made of? I know they won't corrode, I'm just wondering if it would be more prudent to keep them and seal them better.
Old 12-27-2013, 12:35 PM   #2415
Frostyman
Drives: 2013 Raven FRS
The originals are plastic.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Old 12-27-2013, 01:07 PM   #2416
swift996
swift996's Avatar
FWIW, one of mine going to the brake booster came loose on the track. I improvised and slapped a ton of lock-tite around it. When I called tech support at Innovate, they mentioned they couldn't source metal fittings which is why they went with plastic. Not saying you can't find the correct size but seems like they are hard to get a hold of.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 12-27-2013, 01:24 PM   #2417
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by 1010110 View Post
While they were in there I also had them replace the grey plastic fittings (EVAP and brake booster) with brass since the included fittings were stripped and moving freely. Everything is secure back there now :-) Now I just need a catch can.
Any chance you can contact them to find out what fittings were used? Quite a few of us are having trouble finding properly threaded fittings.
Old 12-27-2013, 03:04 PM   #2418
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
There is really nothing wrong with the plastic fittings, all you need to do is remove them and add (plumbing tape) and screw them back in tight before you install.
Make sure the 2 connectors going into the lamina chamber are properly sealed aswell.
Ryan86 is offline   Reply With Quote
Old 12-27-2013, 03:28 PM   #2419
Innovate Motorsports
Drives: Scion FRS, Subaru BRZ, Supercharged
PM sent!
Innovate Motorsports is offline   Reply With Quote
Old 12-27-2013, 03:40 PM   #2420
xxscaxx
Drives: 2013 SWP BRZ
the fittings i used screwed right in. BSPT is British standard pipe taper. You are not going to find those in the states. I know there are differences between BSPT and NPT but the ones I used worked fine.
xxscaxx is offline   Reply With Quote
Old 12-27-2013, 04:41 PM   #2421
Calum
That Guy
There are many different kinds of plastic, I'm wondering which one so I can look up the properties.
Old 12-27-2013, 04:42 PM   #2422
OrbitalEllipses
Drives: Attitude
You. Me. 3D printer. AR15 lower receivers. Let's go.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
